Replace images
by Nirav Patel
This is one of the more challenging repairs on the Framework Laptop, but in the event you have hinges that have worn through their cycle life, you can resolve this by replacing them.
    adddad dadadadadad
    Henry Smithwa - Open Reply
    If you are upgrading to an Intel Ultra series, disable Bitlocker before shutting down your old main board if you are upgrading to an Intel Ultra series.
    And for Ultra series, install windows as a fresh installation. This appears to be particularly important if you can't disable Bitlocker because your old main board died.
    Jim Barron - Open Reply
    Before even starting, inspect the new board to be sure all the connectors are ok. Mine had the speaker connector broken off.
    Gary Aitken - Resolved on Release Reply
    @ahappykittycat I wish that I had read your comment before I undertook this…
    Mike Shaver - Resolved on Release Reply
    IMPORTANT: If you plan to install your existing mainboard in a CoolerMaster case, make sure to boot into the BIOS and enable standalone mode before continuing.
    Richard Tango-Lowy - Resolved on Release Reply
    Pretty sure you might want to include a reminder to backup the bitlocker recovery key if it is enabled. The system will definitely boot to the bitlocker recovery screen since it will be a different TPM.
    James Wu - Resolved on Release Reply
    It could be helpful to give the bash terminal command to shutdown such as
    sudo shutdown -h now
    Patrick Corey - Resolved on Release Reply
    Bottom left*
    Vijfhoek - Resolved on Release Reply
    (I had formerly left a long comment here about how you guys 'forgot' to have a bit about removing the expansion cards...and while some official guide on this is probably a good idea to have, it's...not actually necessary to remove them! Even though in the build guide, they go in last, they don't actually need to come out in order to replace the screen! Heh.)
    Eli B - Resolved on Release Reply
    It would be super nice if the lower-left screw were circled in red as the text indicates!
    Thank you for writing the specific detail on the lower left corner screw.
    I thought something was not working correct until re-read this guide.
    Important: Pull the Input Cover off carefully as it is still attached to the Mainboard via the Touchpad Cable. You don't need to disconnect this cable to do most repairs. You can just flip the Input Cover over. If you do want to disconnect it though, make sure to disconnect the Mainboard side using the finger loop over the orange label.
    While that’s true for most repairs, it’s pretty much essential to disconnect that cable for this repair, so I think the guide should probably amend this boilerplate!
    You should flip the keyboard around the x-axis (so that the back edge comes towards you as you flip) and not the z-axis (resulting in the left edge rotating to the right). I started to do the z-axis and the touchpad cable was getting twisted. I am capable of messing up all instructions. This is my anti-super-power... or joker power in the Wild Cards universe.
    Brian - Resolved on Release Reply
  2. Open the Framework Laptop 180 degrees to remove the Bezel. Be careful to check that the back left and right fasteners that you unscrewed earlier don't get caught on the lid as you open it to 180 degrees. The Framework Bezel is attached by magnets so you will not require any tools to remove it. Just use your fingernail and pry the Bezel away from the display from one of the top corners of the Framework Laptop.
    • Open the Framework Laptop 180 degrees to remove the Bezel.
    • Be careful to check that the back left and right fasteners that you unscrewed earlier don't get caught on the lid as you open it to 180 degrees.
    • The Framework Bezel is attached by magnets so you will not require any tools to remove it. Just use your fingernail and pry the Bezel away from the display from one of the top corners of the Framework Laptop.
    • Once the Bezel starts peeling off towards the bottom of the Display, lift it up using caution. You might feel a little resistance due to the adhesive at the bottom of the display.
    The 2 screw nail bag that come with Hinger Kits 4.0kg are not fit well.
    Elvis - Resolved on Release Reply
  3. Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab. Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab.
    • Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Free the Display Cable from the Bottom Cover and carefully remove it from any routing pegs. It will remain connected to the display.
  4. Using the T5 bit in the Framework Screwdriver, unscrew the 4 fasteners connecting the Display to the Top Cover. The Display is now fully unattached to the Top Cover, you can gently lift it up from the corner using your fingernail. Be sure to only handle the Display by the side edges and avoid touching the bottom area.
    • Using the T5 bit in the Framework Screwdriver, unscrew the 4 fasteners connecting the Display to the Top Cover.
    • The Display is now fully unattached to the Top Cover, you can gently lift it up from the corner using your fingernail.
    • Be sure to only handle the Display by the side edges and avoid touching the bottom area.
  5. Rotate the lid back up to a 90 degree angle to make it easier to remove and install the Hinges.
    • Rotate the lid back up to a 90 degree angle to make it easier to remove and install the Hinges.
    • With the T5 bit in your Framework Screwdriver, unscrew the four fasteners that hold the Hinges into the Bottom Cover.
    • Note that these fasteners are longer than the ones used to attach the Display and Hinges into the Top Cover. Make sure to keep them separate from those.
    • With the Top Cover assembly now unfastened from the Bottom Cover assembly, lift it up and lay it flat, being careful to not pull on the cables too much.
    Please be aware that in most cases you must first move the cables out of the routing on the chassis first before trying to lay it flat. Do not use a lot of force! Trying to lay it flat without this will pull on the cables and most likely break them
    Xam - Resolved on Release Reply
  6. Move the Antenna and Webcam cables out of the way carefully to make sure you have easy access to the fasteners on the right Hinge. Unscrew the three fasteners on the right Hinge using the T5 bit in your Framework Screwdriver, and then remove the Hinge from the Top Cover.
    • Move the Antenna and Webcam cables out of the way carefully to make sure you have easy access to the fasteners on the right Hinge.
    • Unscrew the three fasteners on the right Hinge using the T5 bit in your Framework Screwdriver, and then remove the Hinge from the Top Cover.
    • Repeat this for the three fasteners on the left Hinge and remove the Hinge from the Top Cover.
    I wish I would have read these comments before completing this step. I snapped off both of the inner small screws too. Like Yegor says above take out the two small inner screws first, then go for the larger set of two outside screws on either side; like Richard says the magnet on the right is particularly tough to deal with; and like Xenophon says I just rolled with it and will deal with any issues later as they happen.
    I'm going to open a support case to see if the instructions can be updated.
    Kurt Kleinschmidt - Open Reply
    The small screw snapped on both sides of the hinges in my laptop. I urge anyone removing their hinges to be especially careful with that screw in particular.
    I suspect it might be best to unscrew the small screw first on each side before unscrewing the other two bigger screws so as to avoid subjecting it to unnecessary forces, such as bearing the weight of the top cover alone.
    Yegor Kuznetsov - Open Reply
    Note when you come to replace the screws, the small screw on the right hand hinge is next to a small magnetized component, which will tend to pull the screw to itself. It's a bit of a pain. If you bring the screw to the hole not from above, but from the side, keeping the screw as far away from the magnetized component, that works.
    I found it hard to get the screwdriver tip into the small screw, and used the zoom function on my mobile phone camera to be able to clearly see, and then it was fine.
    Xenophon - Open Reply
    Of the three screws, two are larger (the two which are close together) and one is smaller.
    The small screw's head can have fractured and be resting on, but not be attached to, the shaft of the screw. This happened to me with the screw on the left hinge. I've read on the framework forums of others having the same experience.
    This screw is very small; extracting the stripped screw shaft looks as if it will be difficult.
    On the forums, one chap wrote he had installed the stronger hinges, and had them for two years, using the laptop daily, and then discovered the head had come away from the shaft of the screw.
    I am fitting the stronger hinges, and I've simply rolled with it - the stripped screw remains in place.
    I'm more or less thinking that when I upgrade the screen, I'll buy a new top as well, as get rid of the stripped screw that way.
    Take care—these screws are **not** all the same size. The inner screw on each side is slightly small. Also, there’s a magnet just left of the inner screw on the right hinge, making it slightly trickier to get the screw out and back in.
  7. Pre-rotate the new Hinges to a 90 degree angle to make them easier to install. Place the left and right Hinges into the Top Cover and fasten them into place with the three fasteners each that you previously removed.
    • Pre-rotate the new Hinges to a 90 degree angle to make them easier to install.
    • Place the left and right Hinges into the Top Cover and fasten them into place with the three fasteners each that you previously removed.
    • Carefully place the Top Cover assembly with the Hinges installed onto the Bottom Cover assembly and fasten the left and right Hinges into the Bottom Cover using two fasteners each that you previously removed.
    Keep in mind the magnet on the right hinge is going to instant attract the screw, I spent 5mins trying to get the screw to reach the hole without the magnet nicking the screw before saying bugger it and pulled out the tweezers 👍
  8. Stick the antenna cables down onto the new Hinge. Route the antenna cables through the hinge area, with the white and black cables sitting flat against the bottom of the Bottom Cover as much as possible.  Avoid letting the cables twist or overlap, as this will interfere with the Input Cover and power button.  You can use the spudger end of the Framework Screwdriver to help push the cables. Route the antenna cables through each of the channels and rubber brackets.
    • Stick the antenna cables down onto the new Hinge.
    • Route the antenna cables through the hinge area, with the white and black cables sitting flat against the bottom of the Bottom Cover as much as possible. Avoid letting the cables twist or overlap, as this will interfere with the Input Cover and power button. You can use the spudger end of the Framework Screwdriver to help push the cables.
    • Route the antenna cables through each of the channels and rubber brackets.
    Note that the hinge itself forms something like a bridge, rather than being flush to the top cover. Where the small screw goes in, is one side of the bridge, then the hinge/bridge goes right, with space underneath it for the flat-to-begin-with-cable, and then finally comes down where the two larger, near to each other, screws are.
    The flat-to-begin-with cable come out, down toward the keyboard/base unit, once it runs out of space under the hinge/bridge.
    Okay, there's a a lot to say here. I had to repeat this step many times, trial and error, until I had it right. The photos did not help.
    There are three cables. Two of the cables are normal round cables, but one of them is flat along the final part of its length.
    The flat cable goes under the hinge for the flat part of its length, and then emerges, coming out downwards, towards the keyboard. The two round cables are alongside the hinge, not under it.
    Then, and this is critical, the two round cables go OVER the hinge - you need to hook the "arm" of the hinge under those cables to get them in the correct place. The flat-to-begin-with cable stays low, and does not go over the hinge.
    If you route the cables incorrectly, you will find you cannot properly seat the bottom of the bezel. The sheath-like part of the bezel, at its base, must have the cable routed correctly - which means the cables are as far over to the right as possible - to fit correctly.
    Don't neglect this step. I had an issue with a non-functioning display after the upgrade, and only after revisiting this step did I restore functionality to the screen. Thankfully, Framework support was able to guide me through it.
    Lime - Resolved on Release Reply
  9. There are four alignment pins located on the Top Cover.  They are located right next to the four fastener slots.  Place the silver brackets connected to Display directly over the pins. Be sure to only handle the Display by the side edges and avoid touching the bottom area.
    • There are four alignment pins located on the Top Cover. They are located right next to the four fastener slots. Place the silver brackets connected to Display directly over the pins.
    For those with the cnc cover or more recent 12th gen laptops onwards these will be all metal, just look for the metal version of it 😉
  10. Using the T5 bit in the Framework Screwdriver screw the four fasteners into place. Be sure to not over tighten the fasteners.
    • Using the T5 bit in the Framework Screwdriver screw the four fasteners into place.
    • Be sure to not over tighten the fasteners.
    I can attest to the comment of @xam, improperly routing these cables caused my display to fail, and only after routing them exactly like in step 11 was functionality restored. Strange issue, but Framework support was able to help me resolve it.
    Please do not place wifi cable under the tape as pictured in frameworks picture here, this isn’t the way it comes from the factory. See step 7. It will likely cause failure of the display after repeated opening and closing of the shell
  11. Route the black Display Cable through the routing channel as indicated in the picture. Secure the silver grounding tape as indicated in the first image.
    • Route the black Display Cable through the routing channel as indicated in the picture.
    • Secure the silver grounding tape as indicated in the first image.
    • Using the black pull tab, align the Display Cable connector with the connection on the Mainboard and firmly press down.
    • The Display installation is now complete.
    Framework might want to consider sending a new strip of silver grounding tape with each hinge replacement. Mine wasn’t particularly sticky when I tried to reattach it.
  12. Open the Framework Laptop 180 degrees to attach the Bezel.  Make sure the fasteners in the top left and right corners of the Bottom Cover aren't interfering with the opening. Align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place.
    • Open the Framework Laptop 180 degrees to attach the Bezel. Make sure the fasteners in the top left and right corners of the Bottom Cover aren't interfering with the opening.
    • Align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place.
    • Make sure that all of the corners and edges of the Bezel are fully connected to the Top Cover. If the corners are not aligned. carefully lift up the part of the bezel and guide it into place.
    Have you seen the bottom corners (near the hinge) of the Bezel not seat correctly into place. There is a small gap left at the bottom of my screen between the bezel and the frame. It doesn’t seem to seat correctly and I’ve repeated the process a few times with the same result. Additionally, there was some glue on the bezel center bottom connecting to the display. Was that part of the earlier models?
    Ian Cleary - Resolved on Release Reply
  13. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  14. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  15. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
34 other people completed this guide.
Nirav Patel
18 Guides authored
238 Guides authored
9 Comments
Like some others, I was also unsure about how the cables route around the right hinge.
You can see it more clearly in the "Remove the Bezel" video which is present on other guides, but for some reason this one has that as just a still image.
Display Replacement Guide > "Remove the Bezel"
Attached is a screenshot from there.
Cracked my screen, presumably when pulling away the bezel adhesive as it deformed quite a bit. This Laptop is costing me way too much money, I will never recommend the Framework laptop to others again -.-
Oskar - Open Reply
This hinge replacement guide is incredibly detailed and easy to follow. It's exactly what I needed to fix my laptop—thanks for the clear instructions.
Shiv Teckchandani - Resolved on Release Reply
This hinge replacement guide is incredibly helpful and straightforward. It's great to have a resource that makes such a complex repair process feel manageable—thank you for this!
Bajrang Waghmare - Resolved on Release Reply
I need some better pictures of how the cables route around the right hinge. I cant get teh screen bezzle to completely click all the way down. The wires are somehow stacked wrong or routed the wrong way.
mikkowus - Resolved on Release Reply
NOTE: I ended up stretching and partly damaging my webcam cable, by routing it under instead of over the right hinge. The instructions should be clearer / more explicit to prevent this from happening to others.
Myles Dear - Resolved on Release Reply
I agree mate, more detail is needed. I had to look at a bunch of different upgrades and YT videos to figure it out.
Dillon -
This was my first major upgrade, and it feels like a new laptop! Yay Framework!
descrip - Resolved on Release Reply
To be fair, this repair was definitely a bit more complex than the original DIY install, but the directions were clear. It might help to know that the screws you remove in the process are *not* all the same size, but it’s good form to keep them separated in any case. Also, take care with the silver grounding tape, as mine wasn’t really suitable for re-use (I suspect and hope it’s non-critical).
Past 30 Days: 1
All Time: 10,629
