Rephrased head specs for clarity
by Sandy Qualey-Dobson
In case you ever mix up or lose the fasteners in your Framework Laptop, this guide goes over the different sizes and types used. All of the fasteners we use have either a T5 or PH0 head, making the Framework Screwdriver the only tool you need for them. Unless otherwise noted, all of the fasteners use ISO standard thread pitches and shaft diameters.
There are also five spare fasteners screwed into the inside of the bottom cover of the Framework Laptop for some of the more common ones.
No parts specified.
  1. In the first image, marked with pink markers, we have the gold colored fastener that is used for WiFi, Storage, and the Audio Board.  This is an M2 3.0mm fastener with a T5 head which is 4.5mm  in diameter and 0.7mm thick.  The right-most fastener in the top three spares above the Mainboard is an extra of these. In the second image, marked with yellow markers, we have the gray colored fastener that is used for the Mainboard.  This is an M1.6 1.5mm fastener with a T5 head which is 5.5mm in diameter and 0.6mm thick.  The left-most fastener in the top three spares above the Mainboard is an extra of these.  These are also used for the Webcam. In the third image, marked with blue markers, we have the silver colored fastener that is used for the Hinges where they attach to the Bottom Cover.  This is an M2 4.0mm fastener with a  T5 head which is 4.6mm in diameter and 0.6mm thick.  The middle fastener in the top three spares above the Mainboard is an extra of these.
    • In the first image, marked with pink markers, we have the gold colored fastener that is used for WiFi, Storage, and the Audio Board. This is an M2 3.0mm fastener with a T5 head which is 4.5mm in diameter and 0.7mm thick. The right-most fastener in the top three spares above the Mainboard is an extra of these.
    • In the second image, marked with yellow markers, we have the gray colored fastener that is used for the Mainboard. This is an M1.6 1.5mm fastener with a T5 head which is 5.5mm in diameter and 0.6mm thick. The left-most fastener in the top three spares above the Mainboard is an extra of these. These are also used for the Webcam.
    • In the third image, marked with blue markers, we have the silver colored fastener that is used for the Hinges where they attach to the Bottom Cover. This is an M2 4.0mm fastener with a T5 head which is 4.6mm in diameter and 0.6mm thick. The middle fastener in the top three spares above the Mainboard is an extra of these.
    • The five fasteners that attach the Bottom Cover to the Input Cover are captive (meaning they don't come out), but in case you somehow pulled out and lost one, they are M2 5.75mm with a T5 head which 4.6mm diameter and 0.8mm thick.
    Just a quick note for anyone in the situation where one of the bottom case screws is stripped and needs to be replaced. In our case, the screw stripped upon initial assembly by my teen. I contacted support and was sent a replacement screw but no instructions on how to remove the "captive" screw; and nothing listed on the support pages. I didn't want to force it and risk damaging the case, but support would not provide guidance, other than to take it to a repair shop. This is not the one of the five that is held by an e/c clip; this one was one of the other four. I was able to use a very small, blunt tipped tool from the inside of the case and pop the screw out the back/external side using light to moderate force, without damaging the case. I was then able to pop the replacement screw in with light force using my finger, and it has held in place (is captive again). I believe there is a non-metal piece (maybe a plastic washer) that keeps it captive. Pliers to pull it out probably would have worked, too
    John L - Resolved on Release Reply
    Is the screw for storage (M.2 SSD slot) really a golden one?
    I lost mine and believe it was a black one, maybe same thread but different color?
    Michael Meier - Resolved on Release Reply
    It is a golden one.
    Nirav Patel -
    Hi, it looks like the screws are not https://en.wikipedia.org/wiki/ISO_metric.... Which type of screws was used? Specifically the Bottom Cover ones? Thanks and be carefull with the Bottom Cover screw heads they are touchy.
    Maximilian Müller - Resolved on Release Reply
    This was an error on our guide, now corrected. The fasteners use the ISO standard pitch.
    Nirav Patel -
  2. In the first image, marked with pink markers, we have the silver colored fastener that is used for the Fingerprint Reader Bracket.  This is an M1.4 3.5mm fastener with a T5 head which is 3.0mm in diameter and 0.6mm thick.  These are also used as part of the Expansion Card bracket in the Bottom Cover. In the second image, marked with yellow markers, we have the gray colored fastener that is used for the Fingerprint Reader, Touchpad, and Touchpad Bracket.  This is an M1.4 1.8mm fastener with a PH0 head which is 4.0mm diameter and 0.4mm thick.
    • In the first image, marked with pink markers, we have the silver colored fastener that is used for the Fingerprint Reader Bracket. This is an M1.4 3.5mm fastener with a T5 head which is 3.0mm in diameter and 0.6mm thick. These are also used as part of the Expansion Card bracket in the Bottom Cover.
    • In the second image, marked with yellow markers, we have the gray colored fastener that is used for the Fingerprint Reader, Touchpad, and Touchpad Bracket. This is an M1.4 1.8mm fastener with a PH0 head which is 4.0mm diameter and 0.4mm thick.
  3. These are the fun ones (for some definitions of fun).  The 48 silver fasteners that hold the keyboard in (one is circled in red in the first image) are M1.2 1mm with a PH0 head which is 4.4mm in diameter and 0.25mm thick.  There is a spare in the Bottom Cover to the lower left of the battery connector. The 25 black fasteners (one is circled in blue in the second image) hold the Keyboard Bracket.  These are M1.2 1.3mm with a PH0 head which is 3.2mm in diameter and 0.3mm thick.  There is a spare in the Bottom Cover to the lower left of the battery connector.  These are also used for the Expansion Card brackets in the Bottom Cover.
    • These are the fun ones (for some definitions of fun). The 48 silver fasteners that hold the keyboard in (one is circled in red in the first image) are M1.2 1mm with a PH0 head which is 4.4mm in diameter and 0.25mm thick. There is a spare in the Bottom Cover to the lower left of the battery connector.
    • The 25 black fasteners (one is circled in blue in the second image) hold the Keyboard Bracket. These are M1.2 1.3mm with a PH0 head which is 3.2mm in diameter and 0.3mm thick. There is a spare in the Bottom Cover to the lower left of the battery connector. These are also used for the Expansion Card brackets in the Bottom Cover.
    According to this comment in the keyboard replacement guide, these fasteners are supposed to be PH000 head instead of PH0.
    林博仁(Buo-ren, Lin) - Open Reply
  4. In the first image, marked with pink markers, we have the gray colored fastener that is used for the Webcam Module.  This is an M1.6 1.5mm fastener with a T5 head which is  5.5mm in diameter and  0.6mm thick.  These are also used for the Mainboard, and so there is a spare in the Bottom Cover (the left-most of the top three fasteners). In the second image, marked with yellow markers, we have the gray colored fastener that is used for the Display and for the Hinges where they attach to the Top Cover.  This is an M2 2.0mm fastener with a T5 head which is  4.5mm in diameter and 0.5mm thick. In the third image, marked with blue markers, we have the silver colored fastener that is used for the Antenna Module and for the Hinges where they attach to the Top Cover.  This is an M1.6 3.0mm fastener with a T5 head which is  3.0mm in diameter and 0.65mm thick.
    • In the first image, marked with pink markers, we have the gray colored fastener that is used for the Webcam Module. This is an M1.6 1.5mm fastener with a T5 head which is 5.5mm in diameter and 0.6mm thick. These are also used for the Mainboard, and so there is a spare in the Bottom Cover (the left-most of the top three fasteners).
    • In the second image, marked with yellow markers, we have the gray colored fastener that is used for the Display and for the Hinges where they attach to the Top Cover. This is an M2 2.0mm fastener with a T5 head which is 4.5mm in diameter and 0.5mm thick.
    • In the third image, marked with blue markers, we have the silver colored fastener that is used for the Antenna Module and for the Hinges where they attach to the Top Cover. This is an M1.6 3.0mm fastener with a T5 head which is 3.0mm in diameter and 0.65mm thick.
  5. You'll probably never need to open an Expansion Card, but if you do and one of the tiny fasteners goes "poof!", here are the specs.  In the first image, marked in red, there are two silver M1.2 3.0mm fasteners with a 2.9mm T5 head. In the second image, marked in orange, are the two black M1.6 3.0mm fasteners with a 3.0mm T5 head.
    • You'll probably never need to open an Expansion Card, but if you do and one of the tiny fasteners goes "poof!", here are the specs. In the first image, marked in red, there are two silver M1.2 3.0mm fasteners with a 2.9mm T5 head.
    • In the second image, marked in orange, are the two black M1.6 3.0mm fasteners with a 3.0mm T5 head.
    What is the head thickness of both screws?
    Josh Cook - Resolved on Release Reply
If you ever find that you’ve lost the fastener you need and it isn’t one of the five spares that are included in the Framework Laptop, reach out to our Support team and we’ll do what we can to help you.
Nirav Patel
18 Guides authored
227 Guides authored
16 Comments
I have partially stripped one of the screws on the bottom cover of the framework 13. I was wondering what were the specifications for the screw as well as the washer that holds it captive and are there any recommended sellers for the EU?
Maxime Muller - Open Reply
If you are looking for how to change one of the captive screws from the bottom cover, look at my comment under step 1 above.
"There are also five spare fasteners screwed into the inside of the bottom cover of the Framework Laptop for some of the more common ones."
By my count, there's only 3 spare fasteners? where are the other 2?
Mike Bridge - Resolved on Release Reply
Big +1 to the requests for fastener kits... there are numerous reports across the Guides, Community, and Reddit without a proper solution. Framework have provided neither a kit in the Marketplace nor a link to an external supplier (which they have in other cases, e.g. recommended thermal pads from Digi-Key to address the throttling issues with storage expansion modules). This has a significant impact to long-term repairability of these devices (accidents happen, even in an appropriate environment technicians strip screw head and drop tiny components from time to time).
It's a bit bold of me as an outsider to make this statement, but I find the decision to use virtually unsourceable fasteners highly questionable in light of the goal of end-user repairability (I realize a decision to go with different fasteners is in tension with a compact laptop as well as the one-tool DIY experience, but it has led to a situation that isn't reasonable for end users to solve by themselves).
Vince Cali - Resolved on Release Reply
Inevitably, right after posting this I see one of the Community threads received an update today from a Framework team member :) (the reply: https://community.frame.work/t/has-anyon...)
Vince Cali -
In my case specifically, the 11th Gen mainboard replacement I just received lacks the M.2 NVMe fastener. This isn't an issue for the OEM laptop case I'm swapping it into, but is a blocker for repurposing the original mainboard. Relatedly, the official mainboard printable case on Github lists these same fasteners too (thankfully, I can almost certainly find alternatives because the dimensions of the printable case allow for more flexibility. It would be really nice if Framework addressed this for the printable case plans however, and provided a design that uses commonly available fasteners. I think it's fair for them to assume, if you're going through the process of 3D printing a custom encolsure, then you almost certainly possess a variety of hand tools already... and if not, you can buy a set a heck of a lot easier than you can track down the recommended parts).
Vince Cali -
Hello, Just got a new bottom cover to install my old Gen11 mainboard into and Yep. I have the same issue of needing fasteners. A set of fasteners in the marketplace would be a good idea. I'm currently stalled with my plan to assemble a complete machine from parts using my old mainboard.
Steve Jowett - Resolved on Release Reply
This guide may be “lo-tech” but it’s hugely valuable and a testament to Framework’s ethos.
Steve Burgess - Resolved on Release Reply
Any ideas where to source the fasteners? I tried searching Home Depot and can’t find any of them. And definitely not with the T5 star head which would be really nice.
Ian Cody Harrison -
I would very much appreciate it if framework sold a set of fasteners on the marketplace because I can’t seem to find the mainboard screws anywhere. Has anyone had any luck sourcing these?
Dana - Resolved on Release Reply
I wish they would respond to us… Seem like pretty reasonable questions.
Ian Cody Harrison -
Hi Dana, we’ve gotten a few requests around this. We’re investigating how we can get these packaged by our manufacturer.
Nirav Patel -
Where do people typically source these fasteners from?
Ian Cody Harrison - Resolved on Release Reply
The screws for the battery are not defined in this guide, but it’s printed on the battery itself: M2x4.2L (3x). According to this guide, those would be the only three screws of this size.
ParticleCannon - Resolved on Release Reply
What fastener do I need for the M.2 SSD? I received my mainboard that didn’t come with this fastener and the fasteners I have from other motherboards for mounting an M.2 SSD don’t fit.
aaron - Resolved on Release Reply
Hi Aaron, could you write into support about the missing fastener? We will want to determine why it was not installed from the factory. The fastener is the one marked in pink in this step, and there is an extra in the laptop: Fasteners Guide
Nirav Patel -
Past 30 Days: 2
All Time: 6,874
