Public Release - 1.11
by Iroh
IMPORTANT: For Framework Laptop 13, please update to the latest BIOS before swapping to the Pro Display to ensure full functionality of the Touchscreen Display after booting.
    adddad dadadadadad
    Henry Smithwa - Open Reply
    If you are upgrading to an Intel Ultra series, disable Bitlocker before shutting down your old main board if you are upgrading to an Intel Ultra series.
    And for Ultra series, install windows as a fresh installation. This appears to be particularly important if you can't disable Bitlocker because your old main board died.
    Jim Barron - Open Reply
    Before even starting, inspect the new board to be sure all the connectors are ok. Mine had the speaker connector broken off.
    Gary Aitken - Resolved on Release Reply
    @ahappykittycat I wish that I had read your comment before I undertook this…
    Mike Shaver - Resolved on Release Reply
    IMPORTANT: If you plan to install your existing mainboard in a CoolerMaster case, make sure to boot into the BIOS and enable standalone mode before continuing.
    Richard Tango-Lowy - Resolved on Release Reply
    Pretty sure you might want to include a reminder to backup the bitlocker recovery key if it is enabled. The system will definitely boot to the bitlocker recovery screen since it will be a different TPM.
    James Wu - Resolved on Release Reply
    It could be helpful to give the bash terminal command to shutdown such as
    sudo shutdown -h now
    Patrick Corey - Resolved on Release Reply
    Bottom left*
    Vijfhoek - Resolved on Release Reply
    (I had formerly left a long comment here about how you guys 'forgot' to have a bit about removing the expansion cards...and while some official guide on this is probably a good idea to have, it's...not actually necessary to remove them! Even though in the build guide, they go in last, they don't actually need to come out in order to replace the screen! Heh.)
    Eli B - Resolved on Release Reply
    It would be super nice if the lower-left screw were circled in red as the text indicates!
    Thank you for writing the specific detail on the lower left corner screw.
    I thought something was not working correct until re-read this guide.
    Important: Pull the Input Cover off carefully as it is still attached to the Mainboard via the Touchpad Cable. You don't need to disconnect this cable to do most repairs. You can just flip the Input Cover over. If you do want to disconnect it though, make sure to disconnect the Mainboard side using the finger loop over the orange label.
    While that’s true for most repairs, it’s pretty much essential to disconnect that cable for this repair, so I think the guide should probably amend this boilerplate!
    You should flip the keyboard around the x-axis (so that the back edge comes towards you as you flip) and not the z-axis (resulting in the left edge rotating to the right). I started to do the z-axis and the touchpad cable was getting twisted. I am capable of messing up all instructions. This is my anti-super-power... or joker power in the Wild Cards universe.
    Brian - Resolved on Release Reply
  2. Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force. Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard. The Input Cover is now fully disconnected from the Bottom Cover.
    • Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force.
    • Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • The Input Cover is now fully disconnected from the Bottom Cover.
    • Open the Framework Laptop 180 degrees to remove the Bezel.
    • The Framework Bezel is attached by magnets so you will not require any tools to remove it. Just use your fingernail and pry the Bezel away from the display from one of the top corners of the Framework Laptop.
    • Once the Bezel starts peeling off towards the bottom of the Display, lift it up using caution. You might feel a little resistance due to the adhesive at the bottom of the display.
    The bottom of the screen is held together by something absolutely indestructible . I found there's a way you need to wiggle and lift, but this instruction is not included in this spec
    Paul M Kovac - Open Reply
    Same as above, in my case three of the four bezel adhesevies were so stuck that they eventually remained on the screen frame. Wiggling or softly using the spludger in order to lift the bottom of the Bezel are two ways of removing it, but mind not to scratch the screen!
    Pascal Belin - Open Reply
    This is NOT true in my last screen replacement process, the bezel adhesive stuck to the display firmly and I used quite amount of wiggling to successfully separate the bezel and the (supposed to be fragile) bottom part of the display. The original display thankfully didn't end up damaged because of it, however, please be careful.
    林博仁(Buo-ren, Lin) - Resolved on Release Reply
  3. Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab. Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab.
    • Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Free the Display Cable from the Bottom Cover and carefully remove it from any routing pegs. It will remain connected to the display.
    • Using the T5 bit in the Framework Screwdriver, unscrew the 4 fasteners connecting the Display to the Top Cover.
    • The Display is now fully unattached to the Top Cover, you can gently lift it up from the corner using your fingernail.
    • Be sure to only handle the Display by the side edges and avoid touching the bottom area.
    • There are four alignment pins located on the Top Cover. They are located right next to the four fastener slots. Place the silver brackets connected to Display directly over the pins.
    Same as Scott, the part I felt most worried in the process was when removing the tape that maintained the display cable stuck to the back of the new display kit. My main concern was no to bend the brand new display... Hopefuly you can use the spludger to lift a corner of the tape, and once it's done you can genlty peel it off.
    Before installing the display, should mention to detach the display cable from where it is taped to the back of the new panel, being careful to not damage the permanent connector at the panel end.
    Scott Rabinow - Resolved on Release Reply
    My screen came with a protective layer on it. The screen removal tip/sticker is hard to spot. It's on the upper right corner and could wrapped so you need to peel it out carefully.
    Rob Verduijn -
  4. Using the T5 bit in the Framework Screwdriver screw the four fasteners into place. Be sure to not over tighten the fasteners.
    • Using the T5 bit in the Framework Screwdriver screw the four fasteners into place.
    • Be sure to not over tighten the fasteners.
    Make sure also, to be sure no loose screws are on the magnets which attach the bezel. I cracked my old screen by not looking out for those.
    Noelle - Open Reply
    • Route the black Display Cable through the routing channel as indicated in the picture.
    • Secure the silver grounding tape as indicated in the first image.
    • Using the black pull tab, align the Display Cable connector with the connection on the Mainboard and firmly press down.
    • The Display installation is now complete.
    The directions talk about images for this step, but at least for me on mobile there is only a video which does not show how to use the silver grounding tape which was attached with the default display
    codea - Resolved on Release Reply
    @Maxr1998 I believe the tape that was used to secure the cable on the backside of the panel wasn't used during assembly and should be peeled off and discarded.
    The display panel peel must be removed before replacing the bezel.
    Maybe the image from step 7 should be added on this step, too. Also, I noticed a piece of tape on the cable, which is probably used to secure it to the top cover, but it isn't mentioned in this guide. How to attach it properly?
    Maxr1998 - Resolved on Release Reply
  5. If installing a new Bezel, remove the liner pieces on the bottom of the Bezel to expose the adhesive (if present).
    • If installing a new Bezel, remove the liner pieces on the bottom of the Bezel to expose the adhesive (if present).
    The bezel i got had no "glue" tabs -- so, that's a big miss imho
    Shawn Cicoria - Open Reply
    That is not a big miss, that is a big win. This adhesive was completely pointless at the magnets are more than enough. The adhesive would stick so %#*@ firmly that people (myself included) were breaking their bezels trying to remove them.
    Kirill Elagin -
    Applying the bezel on the display can take multiple tries, especially if you encounter the problem(s) mentioned in the previous and the next section. Just in case you get worried about the glue drying or whatever, I placed and removed the bezel multiple times, as well as letting it sit for a good while with the adhesive covers removed, and nothing bad happened.
    Gelert - Resolved on Release Reply
    It seems almost all of the comments here belong in the next section about actually installing the bezel - only a few of them (if any?) are pertinent to removing the liner pieces to expose the adhesive on the bezel, which is the only action taken here. It's a bit bonkers there's 17 comments before mine in this section about removing liner pieces and only 4 comments at the time of writing in the next section about bezel installation, the latter of which is clearly an order of magnitude more difficult it seems.
    Richard Lloyd - Resolved on Release Reply
    There should be some mention of the removable plastic on the switches at the top of the input cover for (en/dis)abling the camera and microphone.
    David P - Resolved on Release Reply
    My bezel seemed to install well but the lower left hand corner ended up becoming quite stuck and warped for some reason (perhaps how a particular cable was positioned near the microphone).
    It jammed and was almost impossible to open. I have had to detach the lower hinge of the bezel for now and will need a replacement.
    Not the best experience.
    Nicholas - Resolved on Release Reply
    Also had issues with the left corner of the bezel. What happened was I was trying to route the left corner cable below the hinge! That was stupid of me, but it seemed like the appropriate place for the cable to go without much knowledge of laptop bezels. I did fully read and follow the guide, and had the right cable properly fitted; but for some reason it seemed the left cable was supposed to fit under the hinge.
    For anyone who might run into the same problem like I did, here is a picture of how the left cable is supposed to be properly seated:
    https://imgur.com/a/3JcA0xh
    Also, to be fair, the cable was already a bit seated under the hinge when I first opened the laptop, which led me to assume that was how it was supposed to be.
    Ciaran Sanders - Resolved on Release Reply
    the guide says "the ezel" instead of "the bezel" at the end of the 4th bullet point.
    Chickenman - Resolved on Release Reply
    For me this was really simple and took about 30 seconds.
    installed the bezel carefully, or so i thought, when i was finished closed the lid (top cover still off) and the captive screws levered the screen which caused the hinge cover at the bottom of the bezel to just shear off - awesome...i had to re-separate the bezel completely and install from the hinge cover first and then tip the laptop so the captive screws didn't catch in order to check the function again, working now but i've also got half a hinge cover separated from the bezel. Kind of took the shine off my laptop i've been waiting 4 months for
    RJ P - Resolved on Release Reply
    Surprisingly, the bezel was by far the hardest item to install for me. I found that it's easier if done without the top cover, however, be very careful to keep the screws fully seated in when moving the hinge - they can lodge themselves in the wrong spot and cause damage otherwise. This was also pointed out in a comment below, but it should really be a warning at the top of each guide.
    As many have noted, the difficult part is getting the lower corners to sit flush. After a lot of tries the best technique I found is:
    - release tension from the cables by taking them out from some of their holding brackets
    - route them so that, with the laptop sitting flat and horizontal, their highest point is no higher than the hinge's. The picture in the guide shows how to do that - the hinge edges are skinnier than the rest, and you're trying to wrap around that tiny bit of space that they leave.
    Even then it's not perfect and my bottom right corner wants to sit a hair higher than the others.
    Demetrio Girardi - Resolved on Release Reply
    I also had an issue when placing the bottom left of the bezel onto the screen. A cable connecting to the display was causing the the bezel to just not sit flush once it was closed. If you opened it with the cable misaligned it would cause the bottom left side of the bezel to jut out and really look like it would snap. If this guide could provide a picture on how the wiring of the bottom left should look it would be super helpful.
    I managed to figure out how to position it after some troubleshooting, I just removed the bezel and kept closing the lid with the cable in a new spot. When the cable didn't pop out the back I tried it with the bezel installed, then closed the lid, then checked the back of the casing. I still noticed the bezel wasn't flush but after just pushing it up against the case it managed to snap into position and now seems to work fine after opening/closing the lid.
    Vincent Becerra - Resolved on Release Reply
    I had problems with the cable on the left side which caused the lower left corner of the bezel to slightly stick out. You should definitely show a picture of how the left cable should be aligned. Similar to the picture for the Antenna and Camera.
    gbid - Resolved on Release Reply
    If the corners are not aligned. carefully lift up the part of the ezel and guide it into place.
    Can I get a comma and a "b" please... ;)
    Todd - Resolved on Release Reply
    If the new bezel being aligned was not black it would more clearly demonstrate how to attach the new bezel.
    I incurred two problems.
    When installing my new purple bezel, I removed the left adhesive completely from the bottom of the Bezel when removing the liner piece. I was able to REapply it as it was sticky both sides.
    I had more issues with the left hinge, in fact it snapped when I initially closed it. I was terrified but was thankfully able to dislodge it. I bloody well hope this will not effect the performance.
    Very poor quality indeed, cheap flimsy plastic.
    I did not trust myself to continue setting up my Framework Laptop 13 (13th Gen Intel Core) and put it away until I had more confidence.
    Loretta Bozelle - Resolved on Release Reply
    The bezel is cheap plastic and will break easy… if it happens to break it will start to cause issues. Will update with a pic, bezel definitely needs to be redesigned or done already assembled.
    Cameron W Downie - Resolved on Release Reply
    Two captive screws on the bottom of the laptop, near hinges, can mess with opening the screen fully if they are extended too far. Try to push them up (towards the motherboard) to avoid interference. In my case they even left a dent on the inner edge of the screen metal lid.
    https://imgur.com/a/IoeMZeK
    Andrew Bond - Resolved on Release Reply
    On your picture, you already have installed the keyboard, which would be the next step in the process. Do the screws still stick out without the keyboard installed?
    Jonathan Haas -
    Same issue here, it somehow fixed itself after pressing the bezel a bit. It does click when I open the lid, though. I think the wire might need some tape?
    Yochai Gal - Resolved on Release Reply
    I was having issues as well. Check the wires that are tucked in on each side and make sure they are flush with the hinge. There was some tension with the wires and you can use the flat chisel side of the screwdriver tool to gently press the wires down into the chassis grooves.
    Dwalla - Resolved on Release Reply
    The bottom right corner of my bezel is not fully pressed down along the display. It's only 1 or 2 mm raised, but it is noticeable when looking at the display from a side view.
    Do not be alarmed if this happens to you as it seems others have experienced something similar based on posts in the community. I spent way too long repeatedly taking off and placing off the bezel to try and resolve it. All other edges of the bezel lay perfectly.
    Sam Mikell - Resolved on Release Reply
    • Open the Framework Laptop 180 degrees to attach the Bezel.
    • Starting with the bottom of the Bezel which covers the hinges and cables, align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place.
    • We recommend feeling along each edge of the Bezel to make sure it is seated correctly before proceeding, if it doesn't seem to be sitting flush, lift it back up and try lowering it into place again.
    • Do not try to install the Bezel without first opening the Laptop fully, doing so could damage the Bezel and potentially the Display.
    • If the bottom of the Bezel doesn't seem to fit, lift it back off and check that the cables are seated correctly on both sides. If the Bezel doesn't seem to fit at all, please contact support and do not force it into place.
    I also had some issues w/ the bottom left corner of the bezel catching on the display cable, that didn't present any issues until I tightened the screws on the baseplate, but since I opted for the transparent bezel, I could see where the problem was and resolve it. Just make sure the cable is not on top of and to the side of the hinge, like the other side, and that the adhesive on the cable isn't sticking it to the bezel, pulling it up.
    Fair warning though, the transparent bezel is made of much more rigid and less flexible plastic than the normal one, and you will know when it's caught on something.
    Jonathan Divall - Open Reply
    Same issue on mine. Your comment was a big help
    Rick Vidal -
    We had four Laptop 13 Intel 13th Gen and now an AMD AI300 (Batch 4):
    All of them had the glue cable patch on the left hinge not attached, so you really need to check this! Otherwise you will break the bezel (best case), the cable, or the hinge (worst case).
    You have maximum force leverage at this point, so be really careful!
    Yes I wrote this to frame.work, after I was lucky to only break the bezel on our first framework laptop :-S
    Sad to see that this issue is still not fixed on their supply chain.
    Torsten Dörschel - Open Reply
    I join Five Yankees on this unreported control, because of the cable, at the first opening, it unclipped me 1 good centimeter at the level of the Framework logo.
    ADAM - Open Reply
    Bottom right corner is weird for me. At 180 its ever so slightly not flush, but outside that angle it seems okay. Decided I could live with that (might be related to the issues I had in the previous step). Also had the left bottom corner issue but like other comments said just tuck the cable in.
    Babafunmise - Open Reply
    I also had lots of trouble with the lower left corner, my display cable had popped out of the little guides and kept the bezel from being seated. Really the only tricky part of the whole process!
    Toby Boyd - Open Reply
    The bottom-left of my bezel would not attach fully no matter what I did, and at one point it nearly snapped when trying to open the laptop and the lid would not open more than ~45-70 degrees. What I ended up doing is unfastening the bottom, gently removing the input cover, laying the laptop flat upside down for a while, and then re-opening it. I don't know why, but at this point I was able to remove the bezel (be gentle and do NOT try to force it as it's plastic). The reason my bezel would not sit flush is because the cable was routed incorrectly. It was underneath the hinge rather than above, and it also wasn't slotted into the red rectangle in this image. Make sure your cable is not sitting below or on top of the metal hinge and that it's correctly slotted here: https://imgur.com/a/TmDva6J
    Aleksandr Hovhannisyan - Open Reply
    Thank you for the picture man, that really helped. Everything was routed correctly, except that one spot you highlighted and it caused my bezel to not sit flush. I had the same problem where I almost snapped the bezel after seating it the first time. Appreciate you bro!
    Anthony S -
    Also struggling here but with the bottom left corner instead. Photos here. Haven't figured it out yet.
    Sam Burns - Resolved on Release Reply
    Even after dealing with the cable thing, the bezel would give me problems. Very often it would bulge on the center or the right of the bottom side, especially when bringing the display to a 90degree angle. I found that it is kind of flexible, meaning that, with the other corners fit, i gently dragged it like a rubberband towards the last corner, forcing it to stay flat on its sides while snapping. It takes multiple tries and patience, just be very careful not to drag it too hard because I can tell from other people that it breaks fairly easily.
    If the bottom right corner of the bezel won't click into place for you, or pops out of place when you open/close the lid, use the spudger end of your FW screwdriver to lift the webcam cable connecter over the righthand hinge, like this image. Don't worry about damaging the webcam cable, it's flexible, just be gentle.
    Dalton Wood - Resolved on Release Reply
    Just echoing the comments of David P and others below that a diagram and checkpoint on the display cable routing would be helpful here, as the cable routing arriving neat but passing the wrong side of the left hinge (ie on the input side of the hinge instead of the display side) ended up splitting the bezel on trying to close the laptop lid.
    Luke Rule - Resolved on Release Reply
    Second the cable routing check. Ours came with a bit of adhesive sticker on it, we removed and stuck it down behind the hinge.
    Harry Hart - Resolved on Release Reply
    If you have trouble getting the bezel to fit flush all the way around:
    If there's a consistent place the bezel is usually unable to sit flush, try seating that point first and working your way around the rest of the bezel. Be gentle, but don't be afraid to take the bezel off and try again (it took a good number of attempts for mine to seat nicely). Gentle force is okay, but if it's not seating take it off and try again
    Cris E - Resolved on Release Reply
    NOTE regarding clicking while closing:
    if the screws on the underside of the laptop, closest to the hinge, are held captive by the laptop body but dangling loose, when you try to close the laptop you may hear a crunchy click sort of sound as the bottom edge face of the bezel interferes with the screws. For me, picking up the laptop and orienting it so that the screws weren't dangling and sat more flush allowed me to close the laptop without issue, confirming this seemed to be my issue. You may also be able to screw in those screws ever so slightly so they're held more flush with the laptop body before putting the bezel on, but inspect the laptop and make sure you're not causing any problems before attempting, as this is not the recommend order of operations in the guide. You may not want to close the laptop all the way if you do this as the bezel may help to protect the screen
    I think adding a clear picture of how the bottom cables should be dressed, or a diagram, would be helpful. With black cables on a black frame, it's hard to see what is supposed to happen and you can break your bezel easily.
    Scott Thomphson - Resolved on Release Reply
    Before installing the bezel, check the display cable is routed correctly as per this picture.
    Lima Yankee - Resolved on Release Reply
    At the left hinge, the cable seems to belong on the side closer to the display. Mine was on the opposite side, causing the bezel not to fit well, and after closing and reopening the lid, the bezel tore in this corner. It took a lot of wiggling and adjusting to free the bezel and move the cable to its correct position before the lid could be closed and opened easily.
    I feel it's easier to start with the top of the bezel. It's easier to feel the corner with fingers and let the bezel snap into place, than having it taped to bottom first and potentially having misalignment at the top later.
    cyan - Resolved on Release Reply
    "Starting with the bottom of the Bezel which covers the hinges and cables, align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place."
    But the "bottom of the Bezel which covers the hinges and cables" is the bent/angled, part with the "framework" logo on it, no?
    abc - Resolved on Release Reply
    • Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable.
    • Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover.
    • Locate the loop on the end of the Touchpad Cable and insert your finger into it.
  6. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
    And be careful to not accidentally pull out the other end of the Touchpad Cable, the one you just plugged in in the previous step!
    Jrambow - Resolved on Release Reply
    • Close the Framework Laptop and place it upside down to reveal the fasteners on the Bottom Cover.
    FYI. Additional care should be taken when fastening the screw below the power button. It is easy to "over-tightening" and will prevent the power button from functioning correctly. Such that you the power light will come on but the system will not. Only after adjusting this screw was I able to feel the click of the button and the system start up as expected.
    Zach - Open Reply
    I thought I wasn't making them too tight, just using two fingers, but it made the keyboard and power button malfunction. If you're reading this, really don't give it much force. Way less than a torque wrench- the screws are captive, so if they come loose it'll be okay.
    Owen - Open Reply
    Once I got the Input Cover and Bezel mounted and fastened the screws, I neither felt nor heard any clicking when closing my laptop. Opening and closing the laptop was smooth and noiseless. I didn't get it right the first time, so I had to disassemble in reverse order and ensure the end of the Bezel near the hinge was fully seated, maybe to get out of the way of the display cable.
    Curious George - Resolved on Release Reply
    Should I hear clicking when closing the laptop?
    Ramon - Resolved on Release Reply
42 other people completed this guide.
Jehan Suleman
17 Guides authored
11 Members
236 Guides authored
19 Comments
Quick reminder to those upgrading from the base display and also using GNOME, if you had enabled experimental fractional scaling so you can choose something like 150% scaling, I highly recommend removing that experimental feature. With it removed and on 200% scaling everything becomes super crisp. Even legacy windowing (x11) apps like Spotify, Slack, and whatnot look much better.
How to reset experimental fractional scaling is below. Note, you may want to fetch your experimental settings first in case you have any others you'd like to keep.
# enable fractional scaling
gsettings set org.gnome.mutter experimental-features "['scale-monitor-framebuffer']"
# fetch experimental features
gsettings get org.gnome.mutter experimental-features
# reset experimental features i.e. disable fractional scaling
gsettings reset org.gnome.mutter experimental-features
After that simply log out, log back in, and enjoy maximum crisp. 😁
Nicholas La Roux - Open Reply
Also recommend setting variable refresh rate experimental feature so that you're not burning through battery running at 120hz all the time. Can do so with the following command, which will give you variable refresh between 30hz and 120hz. :)
gsettings set org.gnome.mutter experimental-features "['variable-refresh-rate']"
Nicholas La Roux -
Is there a recommended way or place to recycle the old screen?
Aaron Wilson - Resolved on Release Reply
Is there a way to recycle the old screen or recommended vendor?
Hey I have a question: is a new Bezel needed when replacing the screen or can I reapply the old one without problems? Just asking because of the adhesive. Does anyone have a recommendation?
Martin Klejewski - Resolved on Release Reply
I talked with a support agent who reports to the head of support, as I had an issue with my display being damaged, which I believe in part was due to the adhesive on the bezel. They said that keeping the old bezel is fine, and when I asked whether I should keep the adhesive or remove it (I lean heavily towards the latter), they said "If you want to remove the adhesive on the Bezel you currently have - you are more than welcome to."
Additionally, they have phased out adhesive on new bezels entirely in favor of magnets alone:
"As for if the adhesive is on our current bezels, it will be removed starting at the end of July as it is no longer needed. Some stock may still have it as it has already been manufactured."
As I have personally had many bad experiences with adhesives, I would recommend removing it entirely, even on a new bezel should it be part of the old stock.
Gramdalf The Gray -
No new bezel is needed. The instructions above are accurate, except for the details I wrote in my previous comment on this page dated May 26, 2023.
Adam Spiers -
Just swapped the screen on my 11th gen chassis from the original shiny to the new matte display. The process was trivial and took less than 10 minutes.
The display replacement guide provided by Framework guides is incredibly useful for individuals looking to repair or upgrade their laptop screens. The step-by-step instructions and detailed explanations make the process easy to follow, even for those with limited technical experience. This resource empowers users to perform screen replacements confidently and efficiently. Thank you for sharing this valuable guide.
Shiv Teckchandani - Resolved on Release Reply
I have not yet studied the specifications in sufficient detail and maybe I can find the answer myself, but if somebody helps me, I can quickly decide to order this laptop for myself.
I'm interested in the possibility of replacing the matrix with another one if I suddenly manage to find a suitable size. I want to find a 3840x2400 led display (or maybe even a screen from my 16" laptop will do, then I won’t even think about it lol).
Tell me, what should I pay attention to besides the dimensions?
Konstantin - Resolved on Release Reply
After installing the matte display, the screen is now set on a very low brightness and I can barely see anything. I can tell the screen is on, but it is not bright enough to navigate the OS so I can troubleshoot. Before I started the display swap I made sure the screen brightness was set to maximum in windows. Using the on keyboard display brightness buttons does not increase display brightness. What are my options besides having to wait until nighttime?
jeff - Resolved on Release Reply
The back-light on my brand-new framework initially didn't work.
Thought I had a DOA for 3 hours straight, whilst not wanting to give up getting it to work. Then it suddenly started to work, after I gently pressed on the display-to-cable connection... So not the display connector on the motherboard, but the other side underneath the bezel.
Not sure if I should be wary about a possible bad connection, or if the display reed-sensor is somewhere in that area causing a bad reading...
TimDV -
I agree with the other commenter – the screen is perfectly readable even at the lowest brightness (in fact, I keep it on the first or second brightness step for the vast majority of the time and very rarely need to go above that).
Kirill Elagin -
The screen might not be connected properly. It looks like you have no (or only very low) backlight power. Please ensure that the connector is connected properly and there are no pins bent or damaged.
Jonathan Haas -
There were 3 important steps missing from this guide when replacing my original glossy 13" display for the new matte one. As mentioned, one was peeling the backing off the silver grounding tape. This is presumably a fairly serious omission, assuming that without peeling the backing off, the display can never be properly grounded?
The other two omissions were:
1. peeling off the white tape which was securing the display cable to the back of the display (presumably for protection during shipping) - best done between steps 7 and 8
2. peeling off the protective cover from the front of the display, using the black tab near the top-right corner - best done between steps 10 and 11.
Finally, in step 4 the video shows the input cover being lifted first from the top corners; however the text says "Carefully lift the cover up from the bottom right corner." I found this confusing, so it would have been good if the guidance in the text matched the video.
Other than those , I found the whole process very straightforward!
Adam Spiers - Resolved on Release Reply
I was a little confused about the silver tape, it didn’t seem sticky, was there a backing I was supposed to remove?
Alexander Schokking - Resolved on Release Reply
There is a fibre backing on the new grounding tape that you have to peel off.
Katherine Reynolds -
Any timeline on when we’ll be able to purchase replacement displays?
Dale Harper - Resolved on Release Reply
Past 30 Days: 5
All Time: 39,768
