Replace images
by Nirav Patel
Here it is, the Framework Keyboard replacement guide! Before you proceed with the keyboard replacement, here is a helpful tip: It is highly recommended that you store each screw in a dedicated space (such as a cup) as you are removing them. It is important to not mix up or lose any screws.
The keyboard is screwed into the Input Cover. The only tool you'll need is your Framework Screwdriver to completely remove the keyboard.
This is one of the few repairs that is time consuming on the Framework Laptop. A quicker but more expensive alternative is to replace the Input Cover which contains the keyboard instead.
  2. You will be disconnecting the following cables:
    • You will be disconnecting the following cables:
    • Fingerprint Cable (from both ends)
    • Keyboard Membrane
    • Keyboard Backlight
    • In this image, the Touchpad Cable is also removed, but we recommend keeping it attached, since there is likely adhesive holding it in place. You'll just need to hold that cable out of the way when accessing the fasteners that are near it.
  3. The Fingerprint Cable will be completely disconnected from both ends.  Start by disconnecting it from the actual Fingerprint Module. Lift the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out. Lift the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out.
    • The Fingerprint Cable will be completely disconnected from both ends. Start by disconnecting it from the actual Fingerprint Module.
    • Lift the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out.
  4. Next, disconnect the Fingerprint Cable from the Touchpad Module. Lift the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out. Use caution when lifting it up the Fingerprint Cable as there is some adhesive holding it to the bracket. Remove the Fingerprint Cable away and keep it in a safe place as you'll need to connect it back when you install the replacement Keyboard.
    • Next, disconnect the Fingerprint Cable from the Touchpad Module. Lift the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out.
    • Use caution when lifting it up the Fingerprint Cable as there is some adhesive holding it to the bracket.
    • Remove the Fingerprint Cable away and keep it in a safe place as you'll need to connect it back when you install the replacement Keyboard.
  5. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Membrane from the Touchpad Module by switching the black latch up and sliding the cable straight out. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Membrane from the Touchpad Module by switching the black latch up and sliding the cable straight out. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Membrane from the Touchpad Module by switching the black latch up and sliding the cable straight out.
    • Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Membrane from the Touchpad Module by switching the black latch up and sliding the cable straight out.
  6. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Backlight cable from the Touchpad Module by switching the black latch up and sliding the cable straight out. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Backlight cable from the Touchpad Module by switching the black latch up and sliding the cable straight out. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Backlight cable from the Touchpad Module by switching the black latch up and sliding the cable straight out.
    • Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Backlight cable from the Touchpad Module by switching the black latch up and sliding the cable straight out.
  7. All the necessary cables are now disconnected but before proceeding with removing the fasteners it is important to know the difference between the two types of fasteners you are going to be working with. The smaller black fasteners are to be used only on the silver bracket on top of the Keyboard.
    • All the necessary cables are now disconnected but before proceeding with removing the fasteners it is important to know the difference between the two types of fasteners you are going to be working with.
    • The smaller black fasteners are to be used only on the silver bracket on top of the Keyboard.
    • The larger silver fasteners are used to hold the actual Keyboard in place. You should fasten these only where it reads "For KB."
    • Tip: It is very important to not mix up the two screws together - they are magnetic and very easy to lose. Find a dedicated space for each fastener type. Two small cups would be the best option.
    • We've included a few spare fasteners that you'll be able to find right in the Bottom Cover as indicated in the second picture.
  8. Using the PH0 bit in Framework Screwdriver, unscrew all  black fasteners on the silver keyboard bracket. Your Framework Screwdriver has a double-sided bit!  One end is the T5 bit, the other end is the PH0 bit. To switch from the T5 bit to the PH0 bit, pull the bit out using your fingers, flip it around, and place it back into the screwdriver!
    • Using the PH0 bit in Framework Screwdriver, unscrew all black fasteners on the silver keyboard bracket.
    • Your Framework Screwdriver has a double-sided bit! One end is the T5 bit, the other end is the PH0 bit. To switch from the T5 bit to the PH0 bit, pull the bit out using your fingers, flip it around, and place it back into the screwdriver!
    • The fasteners are magnetic and very small. To avoid losing them gather them in a dedicated safe space (such as a cup) as you are removing them. Remember to not mix these fasteners with the "For KB" fasteners you are removing next.
    • Lift the silver keyboard bracket away from the keyboard bracket.
  9. Using the PH0 bit in the Framework Screwdriver, unscrew all "For KB" fasteners holding the keyboard in place. One of the fasteners is hidden under the Keyboard Backlight cable , it must be removed as well. Lift the cable up to expose the fastener and unscrew it.  See the second image for more details. Once all screws are removed use the spudger end of the Framework Screwdriver or your fingernail to lift any corner of the keyboard off the Input Cover. The keyboard is now fully removed from the Input Cover.
    • Using the PH0 bit in the Framework Screwdriver, unscrew all "For KB" fasteners holding the keyboard in place.
    • One of the fasteners is hidden under the Keyboard Backlight cable , it must be removed as well. Lift the cable up to expose the fastener and unscrew it. See the second image for more details.
    • Once all screws are removed use the spudger end of the Framework Screwdriver or your fingernail to lift any corner of the keyboard off the Input Cover. The keyboard is now fully removed from the Input Cover.
  10. Gently place the new Keyboard into the Input Cover by aligning the edges of the keyboard with the Input Cover as indicated in the first image. The keys should be facing down. Using the PH0 bit in the Framework Screwdriver, screw all the silver fasteners into the slots marked  "For KB" that hold the keyboard in place.
    • Gently place the new Keyboard into the Input Cover by aligning the edges of the keyboard with the Input Cover as indicated in the first image. The keys should be facing down.
    • Using the PH0 bit in the Framework Screwdriver, screw all the silver fasteners into the slots marked "For KB" that hold the keyboard in place.
    • Do not attempt to screw any fasteners into a slot that is not marked with "For KB."
    • Do not overtighten the fasteners. They are very small and don’t need much force. Only screw in until you feel some resistance.
  11. Once all the silver fasteners are in place on the Keyboard, find the silver bracket and place it over the keyboard by aligning it as indicated in the first image. Screw all the black fasteners into place in the silver bracket.
    • Once all the silver fasteners are in place on the Keyboard, find the silver bracket and place it over the keyboard by aligning it as indicated in the first image.
    • Screw all the black fasteners into place in the silver bracket.
  12. Connect the Keyboard Backlight Cable into the Touchpad.  Make sure the black latch is flipped up so that you can slide the cable into the connector. Make sure to slide the cable in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable.
    • Connect the Keyboard Backlight Cable into the Touchpad. Make sure the black latch is flipped up so that you can slide the cable into the connector.
    • Make sure to slide the cable in until the white line is almost at the edge of the connector.
    • Flip the black latch down to secure the cable.
  13. Connect the Keyboard Membrane cable into the Touchpad. Make sure the black latch is flipped up so that you can slide the cable into the connector. Slide the cable in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable.
    • Connect the Keyboard Membrane cable into the Touchpad. Make sure the black latch is flipped up so that you can slide the cable into the connector.
    • Slide the cable in until the white line is almost at the edge of the connector.
  14. Connect the Fingerprint Cable into the Fingerprint Module. Make sure the black latch is flipped up so that you can slide the cable into the connector. Slide the cable in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable.
    • Connect the Fingerprint Cable into the Fingerprint Module. Make sure the black latch is flipped up so that you can slide the cable into the connector.
  15. Connect the other end of the Fingerprint Cable into the Touchpad Module. Make sure the black latch is flipped up so that you can slide the cable into the connector. Slide the cable in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable.
    • Connect the other end of the Fingerprint Cable into the Touchpad Module. Make sure the black latch is flipped up so that you can slide the cable into the connector.
  16. Place the Input Cover on the Bottom Cover Keyboard Side down as indicated in the first Image. Connect the Touchpad Cable. Make sure the black latch is flipped up so that you can slide the cable into the connector. Slide the cable in until the white line is almost at the edge of the connector.
    • Place the Input Cover on the Bottom Cover Keyboard Side down as indicated in the first Image.
    • Connect the Touchpad Cable. Make sure the black latch is flipped up so that you can slide the cable into the connector.
  17. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  18. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  19. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
38 other people completed this guide.
Jehan Suleman
17 Guides authored
227 Guides authored
25 Comments
I skipped steps 7 and 18. Like the touchpad cable, the fingerprint cable can remain attached to the touchpad on one side and be held out of the way when needed.
Caution! In step 11, two of the screws to be loosened are not marked in the pictures.
As other commenters have already noted, the screws (both types) are very small and delicate. A magnetic tray was very helpful in preventing me from losing any. It's also crucial to be careful not to overtighten the screws. Even very low torque can cause damage. Ideally, tighten them only until you feel initial resistance – and no further.
Otherwise, a good and detailed guide.
Phönix - Open Reply
Is this the same for the framework 17? I'm confused by all these steps, since I thought the 17 just popped the keyboard out?
Dan Ginovker - Open Reply
I just performed this on a Ryzen AI 300. It was fairly straight forward. There was one screw that was stripped out from framework and it was on the outer most edge of the keyboard. I was able to slide the keyboard out and install the new one. I found out my Control keys no longer register (left or right) I double checked the connections 3 times and even ended up cleaning the connections with 99% isopropyl and still the Ctrl keys do not work. Not sure what to do from here.
Jason Mangano - Open Reply
Successfully performed on the Framework 13. Three of the silverhead screws were stripped, so I used a power drill to extract them. Currently using the laptop without the missing screws, both the keyboard and laptop are functioning perfectly.
On that note, I’d recommend Framework consider using stronger screws if possible. I’m pretty new to DIY, so I’m not sure how feasible that might be, but it could help avoid issues like this for beginners.
Ashfaque Ahbab - Open Reply
Did this over the course of about an hour, found out that the keyboard fastener underneath the backlight cable was partially stripped (of course it's the one right under an unremovable cable lol). Ended up having to remove the touchpad cable and put the input cover on a flat surface to get the right pressure to get the screw out. Go slow if you have to remove the touchpad cable, there's a good amount of adhesive under it that will release bit by bit with steady pressure.
Bryn - Open Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 31,332
