Replace images
by Nirav Patel
  2. Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force. Avoid disconnecting the Touchpad side of the cable unless you need to replace the Touchpad Cable itself, since that connector is more fragile. Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force.
    • Avoid disconnecting the Touchpad side of the cable unless you need to replace the Touchpad Cable itself, since that connector is more fragile.
    • Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • The Input Cover is now fully disconnected from the Bottom Cover.
  3. Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable. Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover. Locate the loop on the end of the Touchpad Cable and insert your finger into it.
    • Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable.
    • Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover.
    • Locate the loop on the end of the Touchpad Cable and insert your finger into it.
  4. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected.
  5. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  6. Once the Touchpad cable is secured to the Mainboard, flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  7. Close the Framework Laptop and place it upside down to reveal the fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    • Close the Framework Laptop and place it upside down to reveal the fasteners on the Bottom Cover.
16 other people completed this guide.
Jehan Suleman
17 Guides authored
227 Guides authored
3 Comments
I will echo that they really need to point out the fingerprint issue in the guide. I tried to disable and re-enable the reader from the device manager, but that didn't work for me. I had to go into Windows Hello settings, disable it and then scan new prints from scratch. It's not a big deal, but it's important to note this to people. The funny part is that I didn't even look at the guide until I ran into the issue, because anyone who has ever opened up their Framework has already disconnected/connected the input cover.
Brian Murray - Resolved on Release Reply
What's not mentioned here is the fingerprint reader might not work after the new install. I'll save you some Googling. Go to Device Manger > Biometric Devices > Framework Fingerprint Reader. Disable then enable.
Other users on the community forum found this fix.
David Harman - Resolved on Release Reply
I should be added to this guide that finger prints will not be recognize by the new cover.
Also it's a good idea safewise to delete any finger print previously saved in the PC before changing to the new cover.
Xavier Brosseau - Resolved on Release Reply
Past 7 Days: 1
Past 30 Days: 2
All Time: 22,763
