Replace images
by Nirav Patel
    If you are upgrading to an Intel Ultra series, disable Bitlocker before shutting down your old main board if you are upgrading to an Intel Ultra series.
    And for Ultra series, install windows as a fresh installation. This appears to be particularly important if you can't disable Bitlocker because your old main board died.
    Jim Barron - Open Reply
    Before even starting, inspect the new board to be sure all the connectors are ok. Mine had the speaker connector broken off.
    Gary Aitken - Resolved on Release Reply
    @ahappykittycat I wish that I had read your comment before I undertook this…
    Mike Shaver - Resolved on Release Reply
    IMPORTANT: If you plan to install your existing mainboard in a CoolerMaster case, make sure to boot into the BIOS and enable standalone mode before continuing.
    Richard Tango-Lowy - Resolved on Release Reply
    Pretty sure you might want to include a reminder to backup the bitlocker recovery key if it is enabled. The system will definitely boot to the bitlocker recovery screen since it will be a different TPM.
    James Wu - Resolved on Release Reply
    It could be helpful to give the bash terminal command to shutdown such as
    sudo shutdown -h now
    Patrick Corey - Resolved on Release Reply
    Bottom left*
    Vijfhoek - Resolved on Release Reply
    (I had formerly left a long comment here about how you guys 'forgot' to have a bit about removing the expansion cards...and while some official guide on this is probably a good idea to have, it's...not actually necessary to remove them! Even though in the build guide, they go in last, they don't actually need to come out in order to replace the screen! Heh.)
    Eli B - Resolved on Release Reply
    It would be super nice if the lower-left screw were circled in red as the text indicates!
    Thank you for writing the specific detail on the lower left corner screw.
    I thought something was not working correct until re-read this guide.
    Important: Pull the Input Cover off carefully as it is still attached to the Mainboard via the Touchpad Cable. You don't need to disconnect this cable to do most repairs. You can just flip the Input Cover over. If you do want to disconnect it though, make sure to disconnect the Mainboard side using the finger loop over the orange label.
    While that’s true for most repairs, it’s pretty much essential to disconnect that cable for this repair, so I think the guide should probably amend this boilerplate!
    You should flip the keyboard around the x-axis (so that the back edge comes towards you as you flip) and not the z-axis (resulting in the left edge rotating to the right). I started to do the z-axis and the touchpad cable was getting twisted. I am capable of messing up all instructions. This is my anti-super-power... or joker power in the Wild Cards universe.
    Brian - Resolved on Release Reply
  2. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Touchpad Cable by flipping up the black latch up on the connector located on the Touchpad Module.  This will fully disconnect the Input Cover from the Mainboard. Grip the brown tab and slide the cable straight out. The Input Cover is now completely disconnected from the Bottom Cover.  You can safely move it away and begin working on removing the rest of the cables.
    • Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Touchpad Cable by flipping up the black latch up on the connector located on the Touchpad Module. This will fully disconnect the Input Cover from the Mainboard.
    • Grip the brown tab and slide the cable straight out.
    • The Input Cover is now completely disconnected from the Bottom Cover. You can safely move it away and begin working on removing the rest of the cables.
    The replacement touchpad I was shipped came with a pre-connected cable here, so I didn't actually need to do this step: it's way easier to disconnect the other end, the one connected to the main board, that you can just pull from.
    anarcat - Open Reply
  3. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard backlight cable by flipping up the black latch up on the connector located on the Touchpad Module. Grip the black pull tab on the cable and pull it straight out. Grip the black pull tab on the cable and pull it straight out.
    • Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard backlight cable by flipping up the black latch up on the connector located on the Touchpad Module.
    • Grip the black pull tab on the cable and pull it straight out.
  4. Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Membrane from the Touchpad Module by fliping the black latch up. Grip the blue pull tab on the cable and pull it straight out. Grip the blue pull tab on the cable and pull it straight out.
    • Using the spudger end of the Framework Screwdriver or your fingernail, disconnect the Keyboard Membrane from the Touchpad Module by fliping the black latch up.
    • Grip the blue pull tab on the cable and pull it straight out.
  5. Next, disconnect the Fingerprint Cable from the Touchpad Module. Lift the black latch up using your fingernail or spudger end of the Framework Screwdriver. Grip the cable and pull it straight out. Grip the cable and pull it straight out.
    • Next, disconnect the Fingerprint Cable from the Touchpad Module. Lift the black latch up using your fingernail or spudger end of the Framework Screwdriver.
    • Grip the cable and pull it straight out.
  6. Using the PH0 bit in the Framework Screwdriver, unscrew the two fasteners holding the Touchpad Module Bracket in place as indicated in red in the first image, and remove the Bracket. Then unscrew the two fasteners holding the Touchpad Module, indicated in orange. Your Framework Screwdriver has a double-sided bit!  One end is the T5 bit, the other end is the PH0 bit. To switch from the T5 bit to the PH0 bit pull the bit out using your fingers, flip it around, and place it back into the screwdriver!
    • Using the PH0 bit in the Framework Screwdriver, unscrew the two fasteners holding the Touchpad Module Bracket in place as indicated in red in the first image, and remove the Bracket.
    • Then unscrew the two fasteners holding the Touchpad Module, indicated in orange.
    • Your Framework Screwdriver has a double-sided bit! One end is the T5 bit, the other end is the PH0 bit. To switch from the T5 bit to the PH0 bit pull the bit out using your fingers, flip it around, and place it back into the screwdriver!
    This is a very good tip as I did not know the bit can be pulled out.
  7. The Touchpad Module is now fully detached from the Input Cover. You can now remove the module by lifting up the Input Cover and gently pushing the module up so that it is easier to grab in image one.
    • The Touchpad Module is now fully detached from the Input Cover.
    • You can now remove the module by lifting up the Input Cover and gently pushing the module up so that it is easier to grab in image one.
  8. The new Touchpad comes with a clear film attached which is used for to help make sure the alignment is correct.
    • The new Touchpad comes with a clear film attached which is used for to help make sure the alignment is correct.
    • There are six tabs, outlined in red, two on the bottom, and two on each side. Fold these tabs over the edge of the Touchpad.
    • Note the green arrow on the film, this indicates the top of the Touchpad which will be the side closest to the keyboard.
  9. The Touchpad Module has a black spacer on the top left and right corners. The larger hole is for the fastener. The smaller hole is for the alignment pin which allows you to properly seat the module on the Bottom Cover.
    • The Touchpad Module has a black spacer on the top left and right corners.
    • The larger hole is for the fastener.
    • The smaller hole is for the alignment pin which allows you to properly seat the module on the Bottom Cover.
    • Find the alignment pegs on the Bottom Cover.
    • Gently place the Touchpad module on the Bottom Cover so that the alignment pegs and holes fit into one another.
    • Be careful not to pinch the cables when inserting the new touchpad into place.
  10. While holding the Touchpad firmly in place to make sure it is aligned,  use the PH0 bit in the  Framework Screwdriver to fasten the top two fasteners into place.
    • While holding the Touchpad firmly in place to make sure it is aligned, use the PH0 bit in the Framework Screwdriver to fasten the top two fasteners into place.
    • It is important that this step is carried out on a flat surface as the purpose of holding the touchpad down firmly in this step is to make sure that the alignment film tabs are keeping the Touchpad centered in the opening. If the touchpad is not pressed down flat, it could end up misaligned.
    • Make sure not to overtighten the fasteners at this step.
  11. Fit the long black bracket on the bottom of the Touchpad Module as indicated in the image. Using the PH0 bit in the Framework Screwdriver, fasten the two remaining fasteners back into place.
    • Fit the long black bracket on the bottom of the Touchpad Module as indicated in the image.
    • Using the PH0 bit in the Framework Screwdriver, fasten the two remaining fasteners back into place.
    • Do not overtighten the fasteners when attaching this bracket.
    Notably, the small metal tabs protruding from the bracket fit into slots on the Input Cover (where the little black wide-U bits are in the picture, below the tabs themselves).
  12. Now that the Touchpad is fastened to the input cover, turn the Input Cover over and gently remove the film guide.
    • Now that the Touchpad is fastened to the input cover, turn the Input Cover over and gently remove the film guide.
    • You can now check that the Touchpad appears to be aligned, i.e. that the space around the sides and bottom of the Touchpad appears even.
    • If at this stage the Touchpad appears to be misaligned simply remove the fasteners in steps 13 and 14, adjust and refasten them.
  13. When inserting cables into their respective connectors, always make sure the black latch is flipped up so that you can slide the cable into or out of the connector. Image one shows a black latch that is flipped up allowing cables to be inserted or removed.
    • When inserting cables into their respective connectors, always make sure the black latch is flipped up so that you can slide the cable into or out of the connector.
    • Image one shows a black latch that is flipped up allowing cables to be inserted or removed.
    • Image two shows a black latch that is flipped down which secures a cable into place. If the connector latch is secure, you will not be able to insert a cable into it.
  14. Use the black pull tab and connect the Keyboard Backlight Cable into the Touchpad. Make sure the black latch is flipped up so that you can slide the cable into the connector. Make sure to slide the cable in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable
    • Use the black pull tab and connect the Keyboard Backlight Cable into the Touchpad. Make sure the black latch is flipped up so that you can slide the cable into the connector.
    • Make sure to slide the cable in until the white line is almost at the edge of the connector.
    • Flip the black latch down to secure the cable
    On my FW13 using an August 2024 touchpad replacement kit, the cable wasn’t long enough to slide it in until the white line was almost at the edge, and indeed some of the connectors were still visible. I tried to unstick the cable at the bend but it wasn’t easy enough that I was confident that I could do it without damaging something.
    Happily, everything still worked fine after I reassembled it! (In fact, worked better, because my previous touchpad was a bit wonky.)
  15. Grip the blue pull tab and connect the Keyboard Membrane cable into the Touchpad. Make sure the black latch is flipped up so that you can slide the cable into the connector. Slide the cable in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable.
    • Grip the blue pull tab and connect the Keyboard Membrane cable into the Touchpad. Make sure the black latch is flipped up so that you can slide the cable into the connector.
    • Slide the cable in until the white line is almost at the edge of the connector.
    • Flip the black latch down to secure the cable.
  16. Grip the Fingerprint Cable and connect it  into the Touchpad Module. Make sure the black latch is flipped up so that you can slide the cable into the connector. Slide the cable in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable.
    • Grip the Fingerprint Cable and connect it into the Touchpad Module. Make sure the black latch is flipped up so that you can slide the cable into the connector.
    • The Touchpad Module is now connected to the Input Cover.
  17. With the black latch lifted , carefully insert the Touchpad cable. The cable should be inserted far enough that the white line almost touches the receptacle as in the first image. Once inserted, close the black latch to secure  the connector as in the second image.
    • With the black latch lifted , carefully insert the Touchpad cable. The cable should be inserted far enough that the white line almost touches the receptacle as in the first image.
    • Once inserted, close the black latch to secure the connector as in the second image.
    This step was not necessary as the replacement trackpad came with a new Touchpad cable already connected (Order from Canada, Sep 2024)
    Uriel Zajaczkovski - Resolved on Release Reply
  18. Gently peel off the blue film on the underside of the Touchpad cable as shown in the first image. Attach the Touchpad cable to the Input cover by pressing gently on the cable so it sticks.
    • Gently peel off the blue film on the underside of the Touchpad cable as shown in the first image.
    • Attach the Touchpad cable to the Input cover by pressing gently on the cable so it sticks.
    This step was not necessary (or indeed possible!) on a touchpad replacement kit for the FW13 purchased from the Framework Canada store in August 2024, FWIW. The cable was already adhered to the touchpad.
  19. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
    If you disconnected the Touchpad Cable from the Mainboard during disassembly (which makes this process much much easier), you’ll need to attach it now.
  20. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    • Be sure to not overtighten the fasteners.
9 other people completed this guide.
Jehan Suleman
17 Guides authored
194 Guides authored
5 Comments
Not sure if it's just the tools I got from B&H photo, but the PH00 bit from them was the far better size vs PH0.
B&H T5 worked like a charm, so good that I have it as a backup.
John Veenstra - Open Reply
Excellent guide! Thank you, took me just a few min!
Giorgi Maghlakelidze - Resolved on Release Reply
This guide is extremely useful for anyone looking to replace their laptop touchpad. The clear instructions and detailed images made the process straightforward and easy to follow for me.
Bajrang Waghmare - Resolved on Release Reply
This guide is extremely useful for anyone needing to replace their touchpad. The clear instructions and detailed images made the replacement process straightforward and manageable.
Shiv Teckchandani - Resolved on Release Reply
The touchpad replacement guide provided in this blog is incredibly useful. As someone who values being able to repair and maintain my devices, having access to clear instructions on how to replace a touchpad is invaluable. The detailed explanations and step-by-step instructions offered here give me confidence in tackling such repairs effectively. Thank you for sharing this valuable resource.
Past 24 Hours: 5
Past 7 Days: 54
Past 30 Days: 217
All Time: 14,332
