Fedora 42 Framework Desktop v3.2
by Matt Hartley
Once you have your Framework Desktop set up following the Quick Start Guide, you’re ready to install your preferred OS. The Framework Desktop is running some very recent hardware, and we’ve worked with the team at Fedora to improve support. Fedora 42 is one of the Linux distributions we recommend, as it has full hardware support with very little setup required, and it offers a great user experience overall.
Tools
No tools specified.
    • If upgrading from Fedora 41, we recommend backing up your home directory and doing a clean installation. If you decide you prefer to upgrade from 41, make absolutely sure your 41 installation is fully up to date first.
  2. First, download the latest Fedora release from the Fedora website. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive. Download Rufus as a tool to create the USB installer from the ISO - select the top download option from the link provided. Rufus is available for Windows. Install it.
    • Launch Rufus. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the Fedora iso that you downloaded. Click on "SELECT" and choose your USB drive. Click "START" and wait a minute or two for it to complete.
  3. Secure Boot is optional: Enabling secure boot is completely optional and not necessary for normal operation, it's a personal choice - but there are trade offs to be aware of. Follow this link if you wish to enable it before installing Fedora. More about secure boot here. If you have decided to disable secure boot. You will do so by booting into the BIOS menu: Power on, then tap F2 rapidly at the Framework splash screen
    • Secure Boot is optional: Enabling secure boot is completely optional and not necessary for normal operation, it's a personal choice - but there are trade offs to be aware of. Follow this link if you wish to enable it before installing Fedora. More about secure boot here.
    • Insert the USB drive into your powered off Framework Desktop, and then power on. If you have an existing OS installed on the Storage drive in your desktop, immediately after the power light comes on begin rapidly tapping (continuously ) the F12 key - you must begin tapping well before you see the Framework logo.
    • Select the USB drive. Press the enter key.
    • Next select Start Fedora Workstation-Live 42. Hit the enter key.
    • After a few seconds, you're in! If you just want to try Fedora out, you can click on the Try Fedora button and browse through the live USB version of it without touching the internal storage drive. If you do want to install Fedora to the internal storage drive, go on to the next step.
  4. Click on the Install Fedora button. Select the keyboard language you'd like to use.  On the next screen, click on the Installation Destination button to choose the disk.  Note that you can install Fedora onto a USB drive or a Storage Expansion Card as an alternative to installing it onto your internal drive. If there is an OS already installed on the target drive, you'll need to follow the guided steps in the installer to resize partitions or delete the existing partitions.  This is out of scope of this guide, but Fedora has very detailed documentation: https://docs.fedoraproject.org/en-US/qui...
    • Click on the Install Fedora button.
    • Looking for hibernate support (save state to disk, powers off) - open this guide in a new tab. Once completed, return to step 5, the fingerprint reader section.
  5. Click on preferred language, again for your preferred keyboard. This begins the process of completing the initial setup of your Fedora installation. Connect to Wi-Fi or Skip. If you wish not to connect to wireless just yet, you can skip this and return to connecting to Wi-Fi later on. Choose your Privacy settings. Here you can decide if you would like to allow Location Services using Mozilla Location Service or not.
    • We're almost done. Please follow the links to your Framework Desktop.
    • Click here for the completion guide for Framework Desktop.
    • Go to and click upper left corner where you see the horizontal line, search terminal and launch it. Please follow this link to copy and paste the code into your terminal, then press enter.
    • The output will tell you which Framework Desktop BIOS version you're using.
    • Framework Desktop firmware update link.
  6. Need help? Please visit our troubleshooting guide first.
Enjoy using Fedora on your Framework Desktop!
4 other people completed this guide.
Matt Hartley
29 Guides authored
194 Guides authored
2 Comments
Any ideas how to get access to my Cooler Master Mobius 120p ARGB? :) Seems like it's not supported in Fedora 42?
$ sudo openrgb -l
Connection attempt failed
[i2c_smbus_linux] Failed to read i2c device PCI device ID
Late Wheel - Open Reply
I would like to know if the fedora recommendation applies to other fedora based distros such as Nobara? thanks in advance
Guillermo - Open Reply
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 96
All Time: 3,609
