Replacing images
by Nirav Patel
  2. Using your fingernail or the spudger end of the Framework Screwdriver, flip up the black latch on the connector. Slide the cable straight out of the connector. Slide the cable straight out of the connector.
    • Using your fingernail or the spudger end of the Framework Screwdriver, flip up the black latch on the connector.
    • Slide the cable straight out of the connector.
  3. Using the T5 bit in the Framework Screwdriver, unscrew the two fasteners on the Audio Board. Using your finger or the spudger end of the Framework Screwdriver gently lift up the Audio Module from the right-hand side and pull it away from the headphone jack. Using your finger or the spudger end of the Framework Screwdriver gently lift up the Audio Module from the right-hand side and pull it away from the headphone jack.
    • Using the T5 bit in the Framework Screwdriver, unscrew the two fasteners on the Audio Board.
    • Using your finger or the spudger end of the Framework Screwdriver gently lift up the Audio Module from the right-hand side and pull it away from the headphone jack.
  4. Place the Audio Board down by aligning the holes on the Audio Board with the alignment pins on the Bottom Cover and insert the headphone connector through the hole on the left hand side of the Bottom Cover. Place the Audio Board down by aligning the holes on the Audio Board with the alignment pins on the Bottom Cover and insert the headphone connector through the hole on the left hand side of the Bottom Cover. Place the Audio Board down by aligning the holes on the Audio Board with the alignment pins on the Bottom Cover and insert the headphone connector through the hole on the left hand side of the Bottom Cover.
    • Place the Audio Board down by aligning the holes on the Audio Board with the alignment pins on the Bottom Cover and insert the headphone connector through the hole on the left hand side of the Bottom Cover.
  5. Using the T5 bit in the Framework Screwdriver screw in the two fasteners. Using the T5 bit in the Framework Screwdriver screw in the two fasteners.
    • Using the T5 bit in the Framework Screwdriver screw in the two fasteners.
  6. Insert the Audio Cable back into the Mainboard. Make sure the black latch is flipped up so that you can slide the cable into the connector. Slide the cable in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable in place.
    • Insert the Audio Cable back into the Mainboard. Make sure the black latch is flipped up so that you can slide the cable into the connector.
    • Slide the cable in until the white line is almost at the edge of the connector.
    • Flip the black latch down to secure the cable in place.
    • The Audio Board is now installed.
  7. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  8. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  9. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
7 other people completed this guide.
Jehan Suleman
17 Guides authored
236 Guides authored
Past 30 Days: 0
All Time: 6,630
