Replace images
by Nirav Patel
The Framework Laptop supports M.2 2230 WiFi modules. We recommend using one of the modules listed in the Knowledge Base. After installing your new module, make sure to install the necessary drivers. If you’re using the AX210 WiFi module that Framework offers with Windows, you’ll need to install the Framework Laptop Driver Bundle (11th Gen Intel Core or 12th Gen Intel Core).
  2. Using the T5 bit in the Framework Screwdriver, unscrew the fastener on the WiFi module. Remove the fastener and gently lift off the WiFi Bracket. Remove the fastener and gently lift off the WiFi Bracket.
    • Using the T5 bit in the Framework Screwdriver, unscrew the fastener on the WiFi module.
    • Remove the fastener and gently lift off the WiFi Bracket.
  3. Using your fingers gently pull the WiFi module out of the socket. Tip: You may have to lift it up using one finger to properly be able to grip it to fully remove it from the socket. Tip: You may have to lift it up using one finger to properly be able to grip it to fully remove it from the socket.
    • Using your fingers gently pull the WiFi module out of the socket.
    • Tip: You may have to lift it up using one finger to properly be able to grip it to fully remove it from the socket.
  4. Carefully grip the white antenna cable and using a slight amount of force pull it off the module. Repeat for the black antenna.
    • Carefully grip the white antenna cable and using a slight amount of force pull it off the module.
    • Repeat for the black antenna.
  5. Connect the black and white WiFi Antennas into their respective sockets on the module.  You can see a little triangular indicator on the module's label pointing out which color goes where.  Make sure to align them well before applying force to click them into place, as the connectors are small and fragile. If you need a video overview on this, check this out.
    • Connect the black and white WiFi Antennas into their respective sockets on the module. You can see a little triangular indicator on the module's label pointing out which color goes where. Make sure to align them well before applying force to click them into place, as the connectors are small and fragile.
    • If you need a video overview on this, check this out.
    • Once both the black and white WiFi Antenna cables are connected to the module, make sure they are rotated downwards as indicated in the second picture with the blue arrows.
    • While keeping a finger on top of the antennas to hold them in place, insert the WiFi module into the socket on the Mainboard.
  6. Once the module is properly inserted into the Mainboard, carefully route both the black and white WiFi Antenna cables into the black rubber routers as indicated in the first image. Place both the cables behind the metal structure located near the top right of the WiFi module as well. The antenna cables should not touch the Speaker located below.  Use the spudger end of the Framework Screwdriver to carefully push the white cable away from the Speaker if it is touching it.
    • Once the module is properly inserted into the Mainboard, carefully route both the black and white WiFi Antenna cables into the black rubber routers as indicated in the first image. Place both the cables behind the metal structure located near the top right of the WiFi module as well.
    • The antenna cables should not touch the Speaker located below. Use the spudger end of the Framework Screwdriver to carefully push the white cable away from the Speaker if it is touching it.
    • Place the WiFi Bracket over the WiFi module and place the fastener in the hole. Using the T5 bit in the Framework Screwdriver, screw the fastener into place.
  7. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  8. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  9. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    • If you haven't already, make sure to install the Driver Bundle (11th Gen Intel Core or 12th Gen Intel Core) if you're using Windows, as this is needed for AX210 WiFi cards.
20 other people completed this guide.
Jehan Suleman
17 Guides authored
227 Guides authored
6 Comments
Please update this guide to include instructions for the newer, plastic fastener. It took me quite a while to understand how to reattach it. You need to ensure the white and black connectors are angled in such a way as to let you slide the fastener over the end of the WiFi module. The attached picture helped me figure it out.
Kent Richards - Open Reply
My new WiFi 7 module came with a thermal pad, where does that go?
Luke - Open Reply
I have the same question, but on a Framework 16. On the Framework Desktop the thermal pad goes underneath the wifi card (see the ifixit guide at the link). I think that seems reasonable as long as there is space. (https://www.ifixit.com/Guide/Framework+D...).
There is space under the original wifi card. Placing the thermal pad under the wifi card remains a reasonable choice.
With the wifi card removed, align the thermal pad in the square with the plastic side up. After removing the plastic, I was still able to position the thermal pad.
From the shape of Framework 13 wifi thermal pad, it must fit with a specific orientation.
Install the new Wifi7 card.
Paul Wilson -
Hello, but im my wifi module F540L i haven't the black and white cable, only Main cable. Sure your is othe model haven't Good and Clear video for 540L ??????
Max Capo - Resolved on Release Reply
my laptop wifi module wire came out and its long to join it again. Somehow I managed to joined using other spare wire. But now wifi range is not good and feels too slow. Please provide an answer as soon u see this. Thank You
edit: if there is any extender type of thing please let me know
Quereshi - Resolved on Release Reply
Past 30 Days: 1
All Time: 29,054
