Ubuntu 26.10 Framework Laptop 13 Pro v1.0
Major VersionM
by Matt Hartley
Once you have your Framework Laptop 13 Pro set up following the Quick Start Guide, you’re ready to install your preferred OS. you’re ready to install your preferred OS. Ubuntu 26.10 works fantastically well.
  1. There is a known issue affecting folks doing a clean install of Ubuntu 26.10. We are working to drill down on the cause, as our 24.04 OEM ISO and Fedora ISOs are not affected. Our recommendation at this time to get past this issue is to verify your date is set correctly in the BIOS. Power on your laptop, as you see the Framework logo splash screen, repeatedly tap the F2 key to bring up the BIOS settings.
    • There is a known issue affecting folks doing a clean install of Ubuntu 26.10. We are working to drill down on the cause, as our 24.04 OEM ISO and Fedora ISOs are not affected.
    • Our recommendation at this time to get past this issue is to verify your date is set correctly in the BIOS.
    • Power on your laptop, as you see the Framework logo splash screen, repeatedly tap the F2 key to bring up the BIOS settings.
    • Using your keyboard arrows, navigate over to Setup Utility. Click enter.
    • Next, you will be presented with what you see in the second image. Click the right arrow key, then arrow down until you see system date.
    • With the word "date" selected, click enter and follow the onscreen instructions to set the correct date.
    • Once you have the date set, click your F10 key and choose save changes.
  2. This process will delete all data from the flash drive being used! Ensure any important data that may be kept on those drives is backed up before continuing. First, download Ubuntu Desktop image from Ubuntu's website. Scroll down to Ubuntu 26.10 and click the green Download button next to "Intel or AMD 64-bit architecture". We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive.
    • First, download Ubuntu Desktop image from Ubuntu's website. Scroll down to Ubuntu 26.10 and click the green Download button next to "Intel or AMD 64-bit architecture". We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive.
    • Launch balenaEtcher. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the ubuntu-desktop-amd64.iso that you downloaded. Click on "Select target" and choose your USB drive. Click "Flash" and wait a minute or two for it to complete.
  3. This process will delete all data from the flash drive being used! Ensure any important data that may be kept on those drives is backed up before continuing. First, download Ubuntu Desktop image from Ubuntu's website. Scroll down to Ubuntu 26.10 and click the green Download button next to "Intel or AMD 64-bit architecture". This guide will follow a basic setup that automatically uses the entire disk.
    • First, download Ubuntu Desktop image from Ubuntu's website. Scroll down to Ubuntu 26.10 and click the green Download button next to "Intel or AMD 64-bit architecture". This guide will follow a basic setup that automatically uses the entire disk.
    • Use the Select Button next to Boot selection to choose the downloaded Ubuntu ISO.
  4. First, download Ubuntu Desktop image from Ubuntu's website. Scroll down to Ubuntu 26.10 and click the green Download button next to "Intel or AMD 64-bit architecture". We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive. Fedora: Media Writer is already installed on Workstation, so just launch it from the app menu. Meaning, you are creating Ubuntu USB install media, but creating the media from a Fedora installation elsewhere. Other distro, Flatpak installed: Run flatpak install flathub org.fedoraproject.MediaWriter, then launch it from the app menu or with flatpak run org.fedoraproject.MediaWriter.
    • Fedora: Media Writer is already installed on Workstation, so just launch it from the app menu. Meaning, you are creating Ubuntu USB install media, but creating the media from a Fedora installation elsewhere.
    • Other distro, Flatpak installed: Run flatpak install flathub org.fedoraproject.MediaWriter, then launch it from the app menu or with flatpak run org.fedoraproject.MediaWriter.
    • Other distro, no Flatpak (like Ubuntu being used for USB media creation): Install Flatpak and add Flathub per https://flathub.org/setup
    • Insert an 8 GB+ USB key. Back up its contents first, since this erases the entire drive.
    • Open Fedora Media Writer, choose Select .iso file, and pick the Ubuntu Desktop ISO you downloaded.
    • Select your USB drive from the device list, double-checking the name and size so you don't wipe the wrong disk.
    • Click Write, enter your password if prompted, wait for it to finish, then click Finish and safely eject the USB.
  5. Ubuntu works with Secure Boot out of the box. Ubuntu Live USBs will boot regardless of whether or not it is disabled. Users who intend to dual-boot with Windows should not disable Secure Boot! If a user has a reason to disable Secure Boot, such as specialized third party devices that require unsigned drivers: Boot into BIOS by tapping F2 just before the Framework splash screen.
    • Ubuntu works with Secure Boot out of the box. Ubuntu Live USBs will boot regardless of whether or not it is disabled. Users who intend to dual-boot with Windows should not disable Secure Boot!
  6. Boot to Live Ubuntu USB:  Insert the USB drive into the powered-off machine, then power it on. If there is already an OS installed on the internal storage, enter the Boot Manager by tapping F12 after pressing the power button to turn the laptop on. Tap the F12 key until the message "F12 is pressed. Go to Boot Manager." is displayed or until the Boot Manager appears.
    • If there is already an OS installed on the internal storage, enter the Boot Manager by tapping F12 after pressing the power button to turn the laptop on. Tap the F12 key until the message "F12 is pressed. Go to Boot Manager." is displayed or until the Boot Manager appears.
    • In the Boot Manager, use arrow keys to select your USB drive (shown as "EFI USB Device (USB Disk)" or similar) and press Enter. On the black GRUB menu, confirm "Try or Install Ubuntu" is highlighted and press Enter.
  7. Language: Select your preferred language. Click next. Accessibility:  Adjust Seeing, Hearing, Typing, Pointing and clicking, or Zoom settings if needed. All accessibility options can be changed later in the Settings app. Click Next when done. Keyboard layout:  Select your keyboard layout from the list (default is English US). Choose a matching variant from the dropdown on the right. Test the layout in the "Type here to test your keyboard" field. Click Next.
    • Language: Select your preferred language. Click next.
    • Accessibility: Adjust Seeing, Hearing, Typing, Pointing and clicking, or Zoom settings if needed. All accessibility options can be changed later in the Settings app. Click Next when done.
    • Keyboard layout: Select your keyboard layout from the list (default is English US). Choose a matching variant from the dropdown on the right. Test the layout in the "Type here to test your keyboard" field. Click Next.
    • Internet connection: Choose wired connection, Wi-Fi network, hidden Wi-Fi network, or Do not connect. An internet connection improves the install with compatibility checks and extra software packages. Click Next.
  8. Try or install Ubuntu:  Select "Install Ubuntu" to begin installation. Click Next. Type of installation:  Select "Interactive installation" for the guided step-by-step setup. Click Next. Applications:  Select "Default selection" for essentials plus a web browser and basic utilities. Select "Extended selection" if you want an offline-friendly set of office tools included. Click Next.
    • Try or install Ubuntu: Select "Install Ubuntu" to begin installation. Click Next.
    • Type of installation: Select "Interactive installation" for the guided step-by-step setup. Click Next.
    • Applications: Select "Default selection" for essentials plus a web browser and basic utilities. Select "Extended selection" if you want an offline-friendly set of office tools included. Click Next.
  9. Optimize your computer:  Check "Install third-party software for graphics and Wi-Fi hardware." Check "Download and install support for additional media formats" for MP3, MP4, MOV, and similar. Click Next. Disk setup:  Select "Erase disk and install Ubuntu" for a clean install. Warning: this wipes all data and partitions on the target drive. Other options: install alongside an existing OS, erase only an existing Ubuntu install, or manual partitioning. Click Next. If an external hard drive is connected, you may be prompted to choose the installation drive: Select the target drive from the "Select drive" dropdown, for example nvme0n1. Confirm the Ubuntu entry below shows the correct drive name and size. Click Next.
    • Optimize your computer: Check "Install third-party software for graphics and Wi-Fi hardware." Check "Download and install support for additional media formats" for MP3, MP4, MOV, and similar. Click Next.
    • Disk setup: Select "Erase disk and install Ubuntu" for a clean install. Warning: this wipes all data and partitions on the target drive. Other options: install alongside an existing OS, erase only an existing Ubuntu install, or manual partitioning. Click Next.
    • If an external hard drive is connected, you may be prompted to choose the installation drive: Select the target drive from the "Select drive" dropdown, for example nvme0n1. Confirm the Ubuntu entry below shows the correct drive name and size. Click Next.
    • Encryption and file system: Select "No encryption" for an unencrypted install. Select "Encrypt with a passphrase" to require a passphrase at every boot. Click Next.
  10. Create your account:  Enter your name in the "Your name" field. Enter a hostname in the "Your computer's name" field. Enter a username in the "Your username" field. Enter a password, then enter it again in the "Confirm password" field. Leave "Require my password to log in" checked unless you want auto-login. Check "Use Active Directory" only if joining an AD domain. Click Next.
    • Create your account: Enter your name in the "Your name" field. Enter a hostname in the "Your computer's name" field. Enter a username in the "Your username" field.
    • Enter a password, then enter it again in the "Confirm password" field. Leave "Require my password to log in" checked unless you want auto-login. Check "Use Active Directory" only if joining an AD domain. Click Next.
    • Select your timezone: Confirm the Location field matches your city or region. Confirm the Timezone field matches your zone. Click on the map to adjust if the values are wrong. Click Next.
  11. Review your choices: Verify Type of installation, Installation disk, and Applications under General. Verify Disk encryption and Proprietary software under Security & more. Verify the Partitions list. Click Install to begin. Installation runs: The installer copies files and displays a slideshow while it works. When finished, there will be a prompt to "Continue testing" or "Restart now". Choose "Restart now". When the Live USB attempts to shut down, it should display a screen prompting the user to remove the USB drive and press enter to restart. If the shutdown process appears to get stuck, remove the USB drive and press enter.
    • Review your choices: Verify Type of installation, Installation disk, and Applications under General. Verify Disk encryption and Proprietary software under Security & more. Verify the Partitions list. Click Install to begin.
    • Installation runs: The installer copies files and displays a slideshow while it works. When finished, there will be a prompt to "Continue testing" or "Restart now". Choose "Restart now".
    • When the Live USB attempts to shut down, it should display a screen prompting the user to remove the USB drive and press enter to restart. If the shutdown process appears to get stuck, remove the USB drive and press enter.
  12. First boot - log in:  At the GDM login screen, click your username. Enter the password you set during installation. Press Enter or click Sign In. Welcome to Ubuntu:  The setup assistant opens with "Welcome to Ubuntu !" Click "View release notes" if you want to read what's new. Click Next to continue. Location Services:  Toggle "Location Services" on if you want apps to determine your geographical location. Leave it off to keep location access disabled. Click Next. This can be changed later in the Settings app.
    • First boot - log in: At the GDM login screen, click your username. Enter the password you set during installation. Press Enter or click Sign In.
    • Welcome to Ubuntu: The setup assistant opens with "Welcome to Ubuntu !" Click "View release notes" if you want to read what's new. Click Next to continue.
    • Location Services: Toggle "Location Services" on if you want apps to determine your geographical location. Leave it off to keep location access disabled. Click Next. This can be changed later in the Settings app.
    • Help Improve Ubuntu: Toggle "Share system data with the Ubuntu team" on or off (hardware info, language, timezone). Toggle "Share error reports with the Ubuntu team" on or off (crash reports and related system logs).
    • Appearance: Select "Default" for a light window style or "Dark" for a dark window style. Choose an accent color from the row of colored circles. Click Next. This can be changed later in the Settings app.
    • Ready to go: The final "Get started with more applications" screen appears. Click "Open App Center" to browse additional apps now, or skip it. Click Finish to close the setup assistant.
  13. Click here for the completion guide for the Framework Laptop 13 Pro. AMD and Intel.
    • How to check the BIOS version. Go to and click upper left corner where you see the horizontal line, search terminal and launch it. Please follow this link to copy and paste the code into your terminal, then press enter.
    • The output will tell you which Framework Laptop 13 you have and also which BIOS version you're using.
    • If you have Framework Laptop 13 Pro Intel Core Ultra Series 3, you can check here for the latest firmware.
    • If you have Framework Laptop 13 Pro AMD Ryzen AI 300 Series, you can check here for the latest firmware.
Enjoy using Ubuntu on your Framework Laptop 13 Pro! If you have any questions or run into any issues, we recommend bringing them to the Community in the Framework Laptop 13 Pro Linux tag.. Members of the Framework team participate in discussions there.
Matt Hartley
51 Guides authored
238 Guides authored
Past 30 Days: 0
All Time: 16
