Ubuntu 24.04 PB Framework Laptop 13 Pro v1.04
by Matt Hartley
Once you have your Framework Laptop 13 Pro set up following the Quick Start Guide, you’re ready to install your preferred OS. The Ubuntu 24.04 LTS OEM ISO works fantastically well. NOTE: This Ubuntu OEM image is certified for Framework Laptop 13 Pro (Intel® Core™ Ultra Series 3). The standard Ubuntu 24.04 images will fail to provide graphics and Wi-Fi support.
Tools
No tools specified.
  1. This guide is for the Ubuntu 24.04 Pre-Built model or DIY model - to run 24.04, you must use the OEM ISO. This guide provides for that ISO. For regular Ubuntu guides, please check here.
    • This guide is for the Ubuntu 24.04 Pre-Built model or DIY model - to run 24.04, you must use the OEM ISO. This guide provides for that ISO. For regular Ubuntu guides, please check here.
    • Pre-Built ships with an OEM image of Ubuntu 24.04 already installed.
    • First boot: power on, you will see a fairly fast memory training screen, followed by the Framework splash screen.
    • You will land on the Welcome Screen with instructions at Step 5.
    • If you are reinstalling the Ubuntu 24.04 OEM image to your pre-built, follow the DIY instructions below.
    • DIY ships with no OS installed — you will write the OEM image to a USB drive and install it. Follow the MacOS and Windows instructions below to create the USB key installer.
    • You will then be presented with the screen shown in Step 4, please follow the steps there.
  2. This process will delete all data from the flash drive being used! Ensure any important data that may be kept on those drives is backed up before continuing. First, download Ubuntu 24.04 Desktop OEM image from Framework's website using this direct link. You will also want to download the checksum to the same directory, as well. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive.
    • First, download Ubuntu 24.04 Desktop OEM image from Framework's website using this direct link. You will also want to download the checksum to the same directory, as well. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive.
    • Verify before installing: | 1. Save the .iso and .sha256sum files in the same folder | 2. Open a terminal there and run: sha256sum --ignore-missing -c *.sha256sum | 3. Confirm it prints "OK" next to the filename | If it says FAILED or "No such file," re-download the ISO before installing.
    • Launch balenaEtcher. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the OEM ISO that you downloaded. Click on "Select target" and choose your USB drive. Click "Flash" and wait a minute or two for it to complete.
  3. This process will delete all data from the flash drive being used! Ensure any important data that may be kept on those drives is backed up before continuing. First, download Ubuntu 24.04 Desktop OEM image from Framework's website using this direct link. You will also want to download the checksum to the same directory, as well. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive.
    • Use the Select Button next to Boot selection to choose the downloaded Ubuntu ISO. Set Partition scheme to GPT to ensure the live USB is properly recognized at boot.
  4. Insert the USB drive, power on the laptop, and tap F12 at the Framework splash screen to select the USB drive. You will land on the menu shown in the first image. Select the Restore Ubuntu to factory state option. Once booted into the GUI installation screen as shown, select the Install button.
    • Insert the USB drive, power on the laptop, and tap F12 at the Framework splash screen to select the USB drive.
    • You will land on the menu shown in the first image. Select the Restore Ubuntu to factory state option.
    • Once booted into the GUI installation screen as shown, select the Install button.
    • Installer runs as normal, shows a slide show as it installs. When it is completed, it will reboot on its own.
    • Next you will be presented with a black screen indicating "We are preparing your system for you" screen. It will reboot on its own when completed.
  5. Ubuntu will greet you with this welcome screen. Select your appropriate system language. Click next. Now select your typing language. Click next.
    • Ubuntu will greet you with this welcome screen.
    • Select your appropriate system language. Click next.
    • Now select your typing language. Click next.
    • Now you will be asked if you would like to connect to Wi-Fi. Connect.
    • Finally, you will be presented with the "All Done" screen.
  6. The next welcome screen provides you with a link to release notes. Click next. Ubuntu Pro enable screen. If you would like to enroll, please do so from here. If not, click skip. Decide if you want to help improve Ubuntu by sending error reports back to them. Click next.
    • The next welcome screen provides you with a link to release notes. Click next.
    • Ubuntu Pro enable screen. If you would like to enroll, please do so from here. If not, click skip.
    • Decide if you want to help improve Ubuntu by sending error reports back to them. Click next.
    • Finish Screen. Here you may either open the application center or click the Finish button.
  7. Let's set up fingerprint login. Click on the horizontal bar in the upper left, search for user. Choose Fingerprint Login. Then select Scan new fingerprint. Select your desired fingerprint. Carefully tap your finger tip on the sensor (power button). You may need to try a few attempts as everyone's prints are different.
    • Let's set up fingerprint login. Click on the horizontal bar in the upper left, search for user.
    • If you're experiencing issues getting your fingerprint reader working, please follow our help guide to get your reader working for you on Ubuntu.
    • How to check the BIOS version. Go to and click upper left corner where you see the horizontal line, search terminal and launch it. Please follow this link to copy and paste the code into your terminal, then press enter.
    • If you have Intel Core Ultra Series 3, you can check (Coming soon) for the latest firmware.
Enjoy using Ubuntu on your Framework Laptop 13 Pro! If you have any questions or run into any issues, we recommend bringing them to the Community in the Ubuntu 24.04 topic. Members of the Framework team participate in discussions there.
Matt Hartley
40 Guides authored
227 Guides authored
Past 7 Days: 1
Past 30 Days: 4
All Time: 100
