Assets Updated
by Iroh
    Before even starting, inspect the new board to be sure all the connectors are ok. Mine had the speaker connector broken off.
    Gary Aitken - Resolved on Release Reply
    @ahappykittycat I wish that I had read your comment before I undertook this…
    Mike Shaver - Resolved on Release Reply
    IMPORTANT: If you plan to install your existing mainboard in a CoolerMaster case, make sure to boot into the BIOS and enable standalone mode before continuing.
    Richard Tango-Lowy - Resolved on Release Reply
    Pretty sure you might want to include a reminder to backup the bitlocker recovery key if it is enabled. The system will definitely boot to the bitlocker recovery screen since it will be a different TPM.
    James Wu - Resolved on Release Reply
    It could be helpful to give the bash terminal command to shutdown such as
    sudo shutdown -h now
    Patrick Corey - Resolved on Release Reply
    Bottom left*
    Vijfhoek - Resolved on Release Reply
    (I had formerly left a long comment here about how you guys 'forgot' to have a bit about removing the expansion cards...and while some official guide on this is probably a good idea to have, it's...not actually necessary to remove them! Even though in the build guide, they go in last, they don't actually need to come out in order to replace the screen! Heh.)
    Eli B - Resolved on Release Reply
    It would be super nice if the lower-left screw were circled in red as the text indicates!
    Thank you for writing the specific detail on the lower left corner screw.
    I thought something was not working correct until re-read this guide.
    Important: Pull the Input Cover off carefully as it is still attached to the Mainboard via the Touchpad Cable. You don't need to disconnect this cable to do most repairs. You can just flip the Input Cover over. If you do want to disconnect it though, make sure to disconnect the Mainboard side using the finger loop over the orange label.
    While that’s true for most repairs, it’s pretty much essential to disconnect that cable for this repair, so I think the guide should probably amend this boilerplate!
    You should flip the keyboard around the x-axis (so that the back edge comes towards you as you flip) and not the z-axis (resulting in the left edge rotating to the right). I started to do the z-axis and the touchpad cable was getting twisted. I am capable of messing up all instructions. This is my anti-super-power... or joker power in the Wild Cards universe.
    Brian - Resolved on Release Reply
  2. Using the T5 bit in the Framework Screwdriver, remove the three fasteners on the silver bracket holding the Fingerprint Reader in place. Gently lift the silver bracket off the module and move it away. Gently lift the silver bracket off the module and move it away.
    • Using the T5 bit in the Framework Screwdriver, remove the three fasteners on the silver bracket holding the Fingerprint Reader in place.
    • Gently lift the silver bracket off the module and move it away.
  3. Disconnect the Fingerprint Cable from the Fingerprint Reader.  Flip the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out. Disconnect the Fingerprint Cable from the Fingerprint Reader.  Flip the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out. Disconnect the Fingerprint Cable from the Fingerprint Reader.  Flip the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out.
    • Disconnect the Fingerprint Cable from the Fingerprint Reader. Flip the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out.
  4. Using the PH0 bit in the Framework Screwdriver unscrew the fastener on the Fingerprint Module. Your Framework Screwdriver has a double-sided bit!  One end is the T5 bit, the other end is the PH0 bit. To switch from the T5 bit to the PH0 bit, pull the bit out using your fingers, flip it around, and place it back into the screwdriver! Gently lift the Fingerprint Reader out of the Input Cover.
    • Using the PH0 bit in the Framework Screwdriver unscrew the fastener on the Fingerprint Module.
    • Your Framework Screwdriver has a double-sided bit! One end is the T5 bit, the other end is the PH0 bit. To switch from the T5 bit to the PH0 bit, pull the bit out using your fingers, flip it around, and place it back into the screwdriver!
    • Gently lift the Fingerprint Reader out of the Input Cover.
  5. Find the notch on the end of the Fingerprint Reader Module as indicated in the first image. Find the alignment notch on the Bottom Cover as indicated in the second image. Gently place the module on the Bottom Cover making sure to align the notch in the module with the notch on the Bottom Cover as indicated in the third image.
    • Find the notch on the end of the Fingerprint Reader Module as indicated in the first image.
    • Find the alignment notch on the Bottom Cover as indicated in the second image.
    • Gently place the module on the Bottom Cover making sure to align the notch in the module with the notch on the Bottom Cover as indicated in the third image.
    I think the instructions mean to say Input Cover instead of Bottom Cover here.
    Radon Rosborough - Resolved on Release Reply
  6. Using the PH0 bit in your Framework Screwdriver, screw the fastener into the Fingerprint Reader. Using the PH0 bit in your Framework Screwdriver, screw the fastener into the Fingerprint Reader.
    • Using the PH0 bit in your Framework Screwdriver, screw the fastener into the Fingerprint Reader.
  7. Make sure the black latch on the connector is flipped up so that you can slide the Fingerprint Cable into the connector. Slide the cable straight in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable.
    • Make sure the black latch on the connector is flipped up so that you can slide the Fingerprint Cable into the connector.
    • Slide the cable straight in until the white line is almost at the edge of the connector.
    • Flip the black latch down to secure the cable.
  8. Place the silver bracket over the Fingerprint Reader so that the three fastener holes align with the fastener holes on the module. Using the T5 bit in the Frameworks Screwdriver screw the three fasteners into place. The Fingerprint Reader is now completely installed.
    • Place the silver bracket over the Fingerprint Reader so that the three fastener holes align with the fastener holes on the module.
    • Using the T5 bit in the Frameworks Screwdriver screw the three fasteners into place.
    • The Fingerprint Reader is now completely installed.
  9. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  10. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  11. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    How to set up the fingerprint reader in software (Linux)?
    Dima - Resolved on Release Reply
  • To purchase a Framework Laptop visit the Framework website.
  • Want to learn more about the Framework Laptop? Take a look at our blog.
  • If you have any questions or concerns, feel free to reach out to Framework Support.
8 other people completed this guide.
Jehan Suleman
17 Guides authored
9 Members
169 Guides authored
2 Comments
What changed with the 2nd release of this module for the 13 inch model?
Caleb Morche - Open Reply
How can I test (from the terminal, in linux (fedora)) that my fingerprint reader is installed and recognized? What is the driver name? Does the presence of lsusb` -> 'Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC' mean that the hardware is installed?
Fred Eisele - Resolved on Release Reply
Past 24 Hours: 13
Past 7 Days: 59
Past 30 Days: 229
All Time: 10,233
