Category
by Nirav Patel
On the earliest Framework Laptops that went out in Batch 1 and early in Batch 2, we found a manufacturing issue on the Touchpad that could result in the Touchpad Cable shorting if it gets misaligned in the receptacle. We’ve added steps in every guide noting to double check the cable alignment, but a more permanent fix is to apply a piece of tape to prevent movement. This guide walks through the steps to do that.
  2. Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force. Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard. The Input Cover is now fully disconnected from the Bottom Cover.
    • Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force.
    • Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • The Input Cover is now fully disconnected from the Bottom Cover.
  3. Before taping the cable, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
    • Before taping the cable, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle.
  4. Note, if your double-sided tape wasn't provided by Framework, it may be a different shape or color than what is in the image.  The instructions should remain the same though.  If you are bringing your own tape, we recommend a 12mmx12mm (about 0.5"x0.5") square of 3M 9495LE. Peel the paper or plastic backing film off of the bottom side of the piece of double sided tape. Lift up the Touchpad Cable carefully, and stick the piece of double sided tape onto the Touchpad cable in an area where it will only touch the metal bracket on the Touchpad when pressed back down.
    • Note, if your double-sided tape wasn't provided by Framework, it may be a different shape or color than what is in the image. The instructions should remain the same though. If you are bringing your own tape, we recommend a 12mmx12mm (about 0.5"x0.5") square of 3M 9495LE.
    • Peel the paper or plastic backing film off of the bottom side of the piece of double sided tape.
    • Lift up the Touchpad Cable carefully, and stick the piece of double sided tape onto the Touchpad cable in an area where it will only touch the metal bracket on the Touchpad when pressed back down.
    • Press on the tape to ensure it bonds well to the Touchpad Cable.
  5. Peel up the paper or plastic backing film on the tape. Making sure the Touchpad Cable is aligned, press it down onto the Touchpad, applying a little force to form a good bond.
    • Peel up the paper or plastic backing film on the tape.
    • Making sure the Touchpad Cable is aligned, press it down onto the Touchpad, applying a little force to form a good bond.
  6. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected.
  7. Once the Touchpad cable is secured to the Mainboard, flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  8. Close the Framework Laptop and place it upside down to reveal the fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    • Close the Framework Laptop and place it upside down to reveal the fasteners on the Bottom Cover.
13 other people completed this guide.
Nirav Patel
18 Guides authored
11 Members
236 Guides authored
Past 30 Days: 0
All Time: 7,921
