Improve images
by Nirav Patel
Be sure to back up your data before replacing your Storage.
  2. Using the T5 bit in the Framework Screwdriver, unscrew the fastener on the Storage module. The module will rise up at a 20-degree angle. Gently pull the Storage module out of the socket. You might have to use a slight left-right motion.
    • Using the T5 bit in the Framework Screwdriver, unscrew the fastener on the Storage module.
    • The module will rise up at a 20-degree angle.
    • Gently pull the Storage module out of the socket. You might have to use a slight left-right motion.
  3. Align the notch on the Storage module with the notch on the socket and slide the module into the Mainboard. Once properly inserted the module will rise up at a 20-degree angle.
    • Align the notch on the Storage module with the notch on the socket and slide the module into the Mainboard.
    • Once properly inserted the module will rise up at a 20-degree angle.
    • Using one finger gently hold the Storage module down to the Mainboard and use your other hand to screw in the fastener using the T5 bit in the Framework Screwdriver.
  4. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  5. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  6. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
You can follow the Windows 10 installation guide to install a new OS on the new drive if needed.
30 other people completed this guide.
Jehan Suleman
17 Guides authored
238 Guides authored
9 Comments
I have the chromebook with the 12gen Intel. I 'assume' the chromebook is just a 13" model with a different motherboad and keyboard (right/wrong?).
I saw a reference that the 16" laptop has 2 M.2 NVME drives or at least sockets for 2. Does the 13" model have a 2nd M.2 ability?
I've added a 2nd stick of 8GB ram (from Amazon, FW couldn't supply it) mostly to see how easy it was to modify and I'm planning for the day when the stock 256GB of storage isn't enough. Where is ChromeOS kept? If on the storage drive being replaced how does it get moved, or reinstalled on the new empty drive?
Russel Brooks - Resolved on Release Reply
That describes the hardware part. Is there a description of how to initialize the SSD itself? Can it be initialized outside of the frame.work case and then installed or does it need access to the other hardware to install properly? I am having needing to update the BIOS to 3.19 . Is there any way to proceed without installing Windows first?
Fred Eisele - Resolved on Release Reply
Check to see that the M.2 is fully inserted. You may have to push harder than you expect. When you push the M.2 down flat, the contacts should be entirely hidden in the socket and the tab should be fully inside the M.2 notch with no gap. See https://community.frame.work/t/undetecte... (incorrect) and https://community.frame.work/t/undetecte... (correct).
Mark Lanctot - Resolved on Release Reply
Can we get information somewhere on what PCI Express Version is supported by the Mainboard? Also, what is the maximum supported thickness (in millimeters) for an M.2 drive that the case can hold?
Jeremy Jeffery - Resolved on Release Reply
A list of compatible SSDs would not go amiss.
Craig Lewis - Resolved on Release Reply
Past 30 Days: 1
All Time: 21,859
