Asset Update
by Iroh
    If you are upgrading to an Intel Ultra series, disable Bitlocker before shutting down your old main board if you are upgrading to an Intel Ultra series.
    And for Ultra series, install windows as a fresh installation. This appears to be particularly important if you can't disable Bitlocker because your old main board died.
    Jim Barron - Open Reply
    Before even starting, inspect the new board to be sure all the connectors are ok. Mine had the speaker connector broken off.
    Gary Aitken - Resolved on Release Reply
    @ahappykittycat I wish that I had read your comment before I undertook this…
    Mike Shaver - Resolved on Release Reply
    IMPORTANT: If you plan to install your existing mainboard in a CoolerMaster case, make sure to boot into the BIOS and enable standalone mode before continuing.
    Richard Tango-Lowy - Resolved on Release Reply
    Pretty sure you might want to include a reminder to backup the bitlocker recovery key if it is enabled. The system will definitely boot to the bitlocker recovery screen since it will be a different TPM.
    James Wu - Resolved on Release Reply
    It could be helpful to give the bash terminal command to shutdown such as
    sudo shutdown -h now
    Patrick Corey - Resolved on Release Reply
    Bottom left*
    Vijfhoek - Resolved on Release Reply
    (I had formerly left a long comment here about how you guys 'forgot' to have a bit about removing the expansion cards...and while some official guide on this is probably a good idea to have, it's...not actually necessary to remove them! Even though in the build guide, they go in last, they don't actually need to come out in order to replace the screen! Heh.)
    Eli B - Resolved on Release Reply
    It would be super nice if the lower-left screw were circled in red as the text indicates!
    Thank you for writing the specific detail on the lower left corner screw.
    I thought something was not working correct until re-read this guide.
    Important: Pull the Input Cover off carefully as it is still attached to the Mainboard via the Touchpad Cable. You don't need to disconnect this cable to do most repairs. You can just flip the Input Cover over. If you do want to disconnect it though, make sure to disconnect the Mainboard side using the finger loop over the orange label.
    While that’s true for most repairs, it’s pretty much essential to disconnect that cable for this repair, so I think the guide should probably amend this boilerplate!
    You should flip the keyboard around the x-axis (so that the back edge comes towards you as you flip) and not the z-axis (resulting in the left edge rotating to the right). I started to do the z-axis and the touchpad cable was getting twisted. I am capable of messing up all instructions. This is my anti-super-power... or joker power in the Wild Cards universe.
    Brian - Resolved on Release Reply
  2. Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force. Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard. Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
    • Disconnect the Touchpad Cable from the Mainboard by inserting your finger into the loop and pull directly upward using a slight amount of force.
    • Once the Touchpad Cable is disconnected, remove the Input Cover away from the Mainboard.
  3. Be extremely careful when sliding the Battery connector out, as it is very easy to accidently bend the pins.  Make sure to slide straight down, and avoid letting the connector twist or bend. Gently disconnect the Battery by gripping the connector edges with both fingers and slide the connector straight down from the socket.
    • Be extremely careful when sliding the Battery connector out, as it is very easy to accidently bend the pins. Make sure to slide straight down, and avoid letting the connector twist or bend.
    • Gently disconnect the Battery by gripping the connector edges with both fingers and slide the connector straight down from the socket.
  4. Using the T5 bit in the Framework Screwdriver, unscrew the three fasteners on the battery.
    • Using the T5 bit in the Framework Screwdriver, unscrew the three fasteners on the battery.
    • Note: The screws will come loose after a few revolutions however they will remain attached to the battery.
  5. Use your fingernail to gently Lift the battery up and away from the bottom cover. Carefully lift it out and keep it in a safe place. Warning: Handle the battery by the plastic frame, make sure not to bend, scratch, cut, or puncture it, and keep it away from heat sources
    • Use your fingernail to gently Lift the battery up and away from the bottom cover. Carefully lift it out and keep it in a safe place.
    • Warning: Handle the battery by the plastic frame, make sure not to bend, scratch, cut, or puncture it, and keep it away from heat sources
  6. Using your fingernails disconnect the speaker connector from the Mainboard by gripping the edges of the connector and pulling straight out. Using your fingernails disconnect the speaker connector from the Mainboard by gripping the edges of the connector and pulling straight out.
    • Using your fingernails disconnect the speaker connector from the Mainboard by gripping the edges of the connector and pulling straight out.
  7. Locate one of two pieces of black tape and carefully peel it back to reveal the black and red speaker wires. Do not completely remove the tape from the Bottom Cover, peel it back just enough to reveal the wires. Do not completely remove the tape from the Bottom Cover, peel it back just enough to reveal the wires.
    • Locate one of two pieces of black tape and carefully peel it back to reveal the black and red speaker wires.
    • Do not completely remove the tape from the Bottom Cover, peel it back just enough to reveal the wires.
  8. Locate the other piece of black tape and carefully peel it back to reveal the black and red speaker wires. Do not completely remove the tape from the Bottom Cover, peel it back just enough to reveal the wires. Do not completely remove the tape from the Bottom Cover, peel it back just enough to reveal the wires.
    • Locate the other piece of black tape and carefully peel it back to reveal the black and red speaker wires.
    Turning the wires sideways will make it easier to get them out of the brackets.
    Gary Aitken - Open Reply
  9. Carefully lift the wires out of the wire routers and very gently pull the wires down so that they are free. Carefully lift the wires out of the wire routers and very gently pull the wires down so that they are free.
    • Carefully lift the wires out of the wire routers and very gently pull the wires down so that they are free.
    Benjamin Loison - Resolved on Release Reply
  10. The speakers are now disconnected.  You can lift both the left and right speaker out of the Bottom Cover. The speakers are now disconnected.  You can lift both the left and right speaker out of the Bottom Cover.
    • The speakers are now disconnected. You can lift both the left and right speaker out of the Bottom Cover.
  11. Place both the Left and Right speakers in their respective spaces on the Bottom Cover by aligning the pegs with the rubber gaskets. Note: You'll notice an L and R on both speakers to help you figure out the proper placement. Note: You'll notice an L and R on both speakers to help you figure out the proper placement.
    • Place both the Left and Right speakers in their respective spaces on the Bottom Cover by aligning the pegs with the rubber gaskets.
    • Note: You'll notice an L and R on both speakers to help you figure out the proper placement.
    Be careful not to dislodge either of the two anti-vibration grommets on each speaker when fitting. This had happened to one of the right speaker grommets during assembly of my i5-1135G7(DIY). Quickly spotted while carrying out a visual inspection of the internals and easily remedied by easing out the speaker and sliding the grommet into the cut-out provided for it.
    Steve Burgess - Resolved on Release Reply
  12. Using your fingers and a slight amount of force, insert the speaker connector straight into the Mainboard. Using your fingers and a slight amount of force, insert the speaker connector straight into the Mainboard. Using your fingers and a slight amount of force, insert the speaker connector straight into the Mainboard.
    • Using your fingers and a slight amount of force, insert the speaker connector straight into the Mainboard.
  13. Peel the black tape back and place the wires under it. Cover the wires with same tape. Peel the black tape back and place the wires under it. Cover the wires with same tape. Peel the black tape back and place the wires under it. Cover the wires with same tape.
    • Peel the black tape back and place the wires under it. Cover the wires with same tape.
  14. Place the wires into the wire router next to the other piece of black tape.  Peel the tape back and place the wires under it. Cover the wires with same tape. Place the wires into the wire router next to the other piece of black tape.  Peel the tape back and place the wires under it. Cover the wires with same tape. Place the wires into the wire router next to the other piece of black tape.  Peel the tape back and place the wires under it. Cover the wires with same tape.
    • Place the wires into the wire router next to the other piece of black tape. Peel the tape back and place the wires under it. Cover the wires with same tape.
  15. Route the wires through each of the wire routers. You can use your fingernail to secure the wires in place.
    • Route the wires through each of the wire routers. You can use your fingernail to secure the wires in place.
    • The Speakers are now fully installed.
    • Make sure the Speaker is not touching the white or black antenna from the WiFi Module.
  16. Using your fingertips, gently handle the Framework battery with the plastic frame, slide it into the Bottom Cover.  Use the first image as a reference.
    • Using your fingertips, gently handle the Framework battery with the plastic frame, slide it into the Bottom Cover. Use the first image as a reference.
    • Warning: Handle the battery by the plastic frame, make sure not to bend, scratch, cut, or puncture it, and keep it away from heat sources.
    Pay attention to put the 4 bottom parts in the corresponding motherboard slots and not above them.
  17. Before plugging the Battery connector back in, double check the pins on the Battery receptacle on the Mainboard, and make sure none of them look bent. Don't plug the Battery connector in if pins look bent, as that will bend them even further.  Reach out to Framework Support for guidance.
    • Before plugging the Battery connector back in, double check the pins on the Battery receptacle on the Mainboard, and make sure none of them look bent.
    • Don't plug the Battery connector in if pins look bent, as that will bend them even further. Reach out to Framework Support for guidance.
    • If you feel resistance when plugging in the Battery connector, stop, slide the connector back out, and make sure that no pins are being bent.
    • Carefully slide the Battery connector back into the mainboard, gripping both edges of the connector and sliding in straight without letting the connector twist or bend.
  18. Using the T5 bit in the Framework Screwdriver, screw the three fasteners into place.
    • Using the T5 bit in the Framework Screwdriver, screw the three fasteners into place.
  19. Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable. Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover. Locate the loop on the end of the Touchpad Cable and insert your finger into it.
    • Gently place the Input Cover keyboard side down on the Bottom Cover as indicated on the image. The cover should be about an inch and a half away from the bottom of the Mainboard so that you can comfortably install the Touchpad Cable.
    • Note: The orientation of the Input Cover matters. Study the first image in this step to ensure you are properly attaching the cover.
    • Locate the loop on the end of the Touchpad Cable and insert your finger into it.
  20. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected. Using slight force, connect the Touchpad Cable by aligning it to the socket on Mainboard. You should hear it click into place once properly connected.
  21. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  22. Once the Touchpad cable is secured to the Mainboard, flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  23. Close the Framework Laptop and turn it upside down to reveal the empty Expansion Card bays and fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    • Close the Framework Laptop and turn it upside down to reveal the empty Expansion Card bays and fasteners on the Bottom Cover.
  • To purchase a Framework Laptop visit the Framework website.
  • Want to learn more about the Framework Laptop? Take a look at our blog.
  • If you have any questions or concerns, feel free to reach out to Framework Support.
17 other people completed this guide.
Jehan Suleman
17 Guides authored
222 Guides authored
7 Comments
Replaced my speakers on my FW13 intel 11th gen (batch 5). The new speakers are loud and clear but lack some bass. This guide was super detailed, fun and easy to follow along.
Emil Larsson - Resolved on Release Reply
This speaker replacement guide is incredibly detailed and easy to follow. It was exactly what I needed to successfully replace my laptop speakers. Thank you for providing such clear instructions!
Bajrang Waghmare - Resolved on Release Reply
The Speaker Replacement Guide is very detailed and easy to follow. It's great to have such a clear resource for DIY repairs—this information is definitely useful for anyone looking to replace their laptop speakers.
Shiv Teckchandani - Resolved on Release Reply
The step-by-step instructions in this speaker replacement guide are incredibly clear and practical. This information is very useful for anyone looking to perform their own laptop repairs.
This speaker replacement guide is incredibly clear and easy to follow. It provided the exact steps I needed to successfully replace my laptop's speakers.
I went through this guide to upgrade my speakers today!
The guide was very easy and I was successful in replacing my speakers.
The wire is a little odd to get back into the little captivate slots, so I turned it sideways to get it in them.
Keenan Barnes - Resolved on Release Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 8,489
