Asset Updates
by Iroh
    • Close your laptop completely and turn it over so you can access the Expansion Cards.
    • While keeping the release button pressed, use your other fingers to slide the Expansion Card away from the laptop.
    • Important: You may have to use a little bit of force to fully disconnect the Expansion Card.
    • Make sure each Expansion Card is fully removed before proceeding to the next step.
Finish Line
Nirav Patel
20 Guides authored
180 Guides authored
Past 30 Days: 1
All Time: 33
