Follow this guide to replace the Mid Plate in your Framework Laptop 16.
Tools
Unplug all cables and fully shut down your laptop.
Use your fingernail to pull out the two Input Module latches and unlock them.
The latch will show red if it's unlocked.
Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
Lift the Touchpad Spacer off the laptop and remove it.
Repeat the same procedure for the other touchpad spacer.
Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
If you're having trouble, check if the Input Module latches are properly unlocked.
Lift the Touchpad Module and remove it.
The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
Remove the keyboard.
Your Input Module(s) might be different, but the procedure to remove them is the same.
Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
Remove the Input Module.
Repeat for any remaining Input Modules.
Grip the black pull tab on the Mid Plate cable press connector and lift up to disconnect it.
This step skips over removing the keyboard module. Can't see the mid plate cable without moving that first.
Tom Marciniak - Open Reply
The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
Maybe you should also mention that we are NOT supposed to REMOVE the screws, just make them loose.
For somebody that did some (albeit crappy) DIY laptop disassembly in the past, that fact is VERY easy to glance over. Usually, when told to loosen the screws, it is somewhat implicitly expected to remove them as well.
I was wondering why the first screw I tried to remove just wouldn't come off even when loose (some of them do, some of them don't), and I hope that I didn't damage something by attempting to remove the loose screw by force (after rechecking multiple times that it is indeed loose).
I even had a place prepared to put the screws into... 👀
Use your fingers to lift the Mid Plate off the laptop and remove it.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off.
My 16-inch model is much newer (June 2026) and therefore doesn't have the blue foil, but it does have the grey thermal pad. Is that intentional?
Markus Ursprung - Open Reply
Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
Use your Framework Screwdriver to tighten the 16 T5 Torx captive screws in order (starting with 2) to secure the Mid Plate evenly.
Align the Mid Plate cable press connector over its socket and press down to connect it.
Align the top edge of the Input Module with the top edge of the laptop.
Lay the Input Module on the laptop and let the magnets pull the keyboard into place
Make sure the Input Module is seated properly on its alignment pegs and sits flush with the edges of the laptop.
This step is about installing the modules again, but the very first sentence mentions ".. to remove them...". That should say: "... to install them..."
Thijs Marinussen - Open Reply
Align the top edge of the keyboard with the top edge of the laptop.
Lay the keyboard on the laptop and let the magnets pull the keyboard into place
Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
Place the Touchpad Module flat on its cutout so its clips are properly aligned.
Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
Slide the Touchpad Spacer towards the top of the laptop to secure it.
Repeat the same procedure for the other Touchpad Spacer.
Push the Input Module latches back into place to lock them.
Cancel: I did not complete this guide.
10 other people completed this guide.
3 Comments
There was no blue liner and it's still saying "input module connector board not connected"
Jim howard - Open Reply
