Public Release - 1.01
by Iroh
Follow this guide to replace the Mid Plate in your Framework Laptop 16.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  12. If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off. If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off. If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off.
    • If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off.
  13. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  14. Use your Framework Screwdriver to tighten the 16 T5 Torx captive screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 T5 Torx captive screws in order (starting with 2) to secure the Mid Plate evenly.
    • Use your Framework Screwdriver to tighten the 16 T5 Torx captive screws in order (starting with 2) to secure the Mid Plate evenly.
  15. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  16. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  17. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  18. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  19. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  20. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
10 other people completed this guide.
Iroh
112 Guides authored
238 Guides authored
3 Comments
There was no blue liner and it's still saying "input module connector board not connected"
Jim howard - Open Reply
I have the same issue, how did you go about resolving it?
Angelo -
Why is my mouse pad not working please help 😭
Cephas - Resolved on Release Reply
Past 30 Days: 6
All Time: 6,291
