Public Release - 1.0
by Iroh
Follow this guide to install a secondary 80mm fan in your Framework Desktop.
The Framework Desktop supports a 80mm fan with a standard 4-pin connector. For detailed fan requirements, click here.
The guide shows installing a Noctua NF-A8 80mm fan. If installing a different fan, mileage may vary.
This fan is completely optional. In thermal simulations, Framework saw that there wasn't a significant difference having the 80mm fan vs not.
No parts specified.
    • Remove the Handle.
    • Remove the Top Panel screw.
  7. Use your fingers to pull the Front Panel off the magnets securing it to the chassis. Use your fingers to pull the Front Panel off the magnets securing it to the chassis. Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
  8. Use your fingers to grip the top of the Right Panel and slide it upward to release its clips. Remove the Right Panel. Remove the Right Panel.
    • Remove the Right Panel.
  9. While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate. While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate. While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
  10. Lift the top plate off the Desktop and remove it. Lift the top plate off the Desktop and remove it.
    • Lift the top plate off the Desktop and remove it.
  11. Lay the right side of the Desktop on your work surface so the Mainboard is facing upward. Lay the right side of the Desktop on your work surface so the Mainboard is facing upward.
    • Lay the right side of the Desktop on your work surface so the Mainboard is facing upward.
  12. Orient the fan so its label is facing away from the chassis fan grille and the cable is pointing up. If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
    • Orient the fan so its label is facing away from the chassis fan grille and the cable is pointing up.
    • If you're using a different fan, orient it such that the fan is blowing into the Desktop, not away.
    • Insert the fan into the chassis and along the front plate, making sure that the screw holes in the chassis and the fan are aligned.
  13. Use your Framework Desktop Screwdriver to install the four screws securing the secondary fan. Most fans of this type use self-tapping screws that will carve threads into your fan's screw holes. This is normal and necessary for the fan to be secured.
    • Use your Framework Desktop Screwdriver to install the four screws securing the secondary fan.
    • Most fans of this type use self-tapping screws that will carve threads into your fan's screw holes. This is normal and necessary for the fan to be secured.
  14. Orient the fan cable so its two vertical lines are facing you. Slide the fan cable over the four-pronged connector labeled "Sys Fan 2," making sure the orange label slots between the vertical lines.
    • Orient the fan cable so its two vertical lines are facing you.
    • Slide the fan cable over the four-pronged connector labeled "Sys Fan 2," making sure the orange label slots between the vertical lines.
    • You can also connect the cable into the "Sys Fan 1" slot depending on the cable's length and orientation.
  15. Move the fan cable underneath the heat sink and tuck it behind the silver screw post. Move the fan cable underneath the heat sink and tuck it behind the silver screw post. Move the fan cable underneath the heat sink and tuck it behind the silver screw post.
    • Move the fan cable underneath the heat sink and tuck it behind the silver screw post.
  16. Rotate the Desktop so it sits upright on your work surface. Rotate the Desktop so it sits upright on your work surface.
    • Rotate the Desktop so it sits upright on your work surface.
  17. Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible. Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
    • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
  18. Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible. Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
    • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
  19. While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate. While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate. While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
  20. Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place. There should be a small gap between the bottom of the Right Panel and the silver base. Push the Right Panel towards the base of the computer to engage the clips.
    • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
  21. Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs. Press the Front Panel flat to the chassis and let it align to the magnets. Press the Front Panel flat to the chassis and let it align to the magnets.
    • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
    • Press the Front Panel flat to the chassis and let it align to the magnets.
  22. Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place. There should be a small gap between the bottom of the Left Panel and the silver base. Push the Left Panel towards the base of the computer to close the gap and engage the clips.
  23. Orient the Top Panel so its arrow is pointing towards the rear of the computer. While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch. There should be a small gap between the Top Panel and the front of the Desktop.
  24. While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips. While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  25. Insert the top panel screw into its hole and twist clockwise until it feels snug. Insert the top panel screw into its hole and twist clockwise until it feels snug. Insert the top panel screw into its hole and twist clockwise until it feels snug.
  26. Repeat the same procedure for the other top panel screw. Repeat the same procedure for the other top panel screw. Repeat the same procedure for the other top panel screw.
  27. Use your finger to close the two D-rings on the top panel screws. Use your finger to close the two D-rings on the top panel screws. Use your finger to close the two D-rings on the top panel screws.
Iroh
88 Guides authored
194 Guides authored
2 Comments
The link to the fan Requirements is wrong (Unauthorized). It should be pointing to Parts Compatibility for building a PC with a Framework Desktop Mainboard (AMD Ryzen™ AI Max 300 Series)
But overall, really nice explanation
paule96 - Open Reply
Hi Paulie!
Sorry to hear you ran into this issue with the URL. Can you share where/ what step the "Unauthorized" URL is? If clicking the URL in the Introduction, it does go to the Knowledgebase page you share when double checking it myself.
Iroh -
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 603
