Replace images
by Nirav Patel
This is one of the more challenging repairs on the Framework Laptop, but in the event you have hinges that have worn through their cycle life, you can resolve this by replacing them.
  2. Open the Framework Laptop 180 degrees to remove the Bezel. Be careful to check that the back left and right fasteners that you unscrewed earlier don't get caught on the lid as you open it to 180 degrees. The Framework Bezel is attached by magnets so you will not require any tools to remove it. Just use your fingernail and pry the Bezel away from the display from one of the top corners of the Framework Laptop.
    • Open the Framework Laptop 180 degrees to remove the Bezel.
    • Be careful to check that the back left and right fasteners that you unscrewed earlier don't get caught on the lid as you open it to 180 degrees.
    • The Framework Bezel is attached by magnets so you will not require any tools to remove it. Just use your fingernail and pry the Bezel away from the display from one of the top corners of the Framework Laptop.
    • Once the Bezel starts peeling off towards the bottom of the Display, lift it up using caution. You might feel a little resistance due to the adhesive at the bottom of the display.
  3. Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab. Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Find the black Display Cable that connects the display to the mainboard. Unplug the cable by pulling it directly upwards using the black pull tab.
    • Carefully lift up the silver grounding tape that is holding the Display Cable to the hinge.
    • Free the Display Cable from the Bottom Cover and carefully remove it from any routing pegs. It will remain connected to the display.
  4. Using the T5 bit in the Framework Screwdriver, unscrew the 4 fasteners connecting the Display to the Top Cover. The Display is now fully unattached to the Top Cover, you can gently lift it up from the corner using your fingernail. Be sure to only handle the Display by the side edges and avoid touching the bottom area.
    • Using the T5 bit in the Framework Screwdriver, unscrew the 4 fasteners connecting the Display to the Top Cover.
    • The Display is now fully unattached to the Top Cover, you can gently lift it up from the corner using your fingernail.
    • Be sure to only handle the Display by the side edges and avoid touching the bottom area.
  5. Rotate the lid back up to a 90 degree angle to make it easier to remove and install the Hinges.
    • Rotate the lid back up to a 90 degree angle to make it easier to remove and install the Hinges.
    • With the T5 bit in your Framework Screwdriver, unscrew the four fasteners that hold the Hinges into the Bottom Cover.
    • Note that these fasteners are longer than the ones used to attach the Display and Hinges into the Top Cover. Make sure to keep them separate from those.
    • With the Top Cover assembly now unfastened from the Bottom Cover assembly, lift it up and lay it flat, being careful to not pull on the cables too much.
  6. Move the Antenna and Webcam cables out of the way carefully to make sure you have easy access to the fasteners on the right Hinge. Unscrew the three fasteners on the right Hinge using the T5 bit in your Framework Screwdriver, and then remove the Hinge from the Top Cover.
    • Move the Antenna and Webcam cables out of the way carefully to make sure you have easy access to the fasteners on the right Hinge.
    • Unscrew the three fasteners on the right Hinge using the T5 bit in your Framework Screwdriver, and then remove the Hinge from the Top Cover.
    • Repeat this for the three fasteners on the left Hinge and remove the Hinge from the Top Cover.
  7. Pre-rotate the new Hinges to a 90 degree angle to make them easier to install. Place the left and right Hinges into the Top Cover and fasten them into place with the three fasteners each that you previously removed.
    • Pre-rotate the new Hinges to a 90 degree angle to make them easier to install.
    • Place the left and right Hinges into the Top Cover and fasten them into place with the three fasteners each that you previously removed.
    • Carefully place the Top Cover assembly with the Hinges installed onto the Bottom Cover assembly and fasten the left and right Hinges into the Bottom Cover using two fasteners each that you previously removed.
  8. Stick the antenna cables down onto the new Hinge. Route the antenna cables through the hinge area, with the white and black cables sitting flat against the bottom of the Bottom Cover as much as possible.  Avoid letting the cables twist or overlap, as this will interfere with the Input Cover and power button.  You can use the spudger end of the Framework Screwdriver to help push the cables. Route the antenna cables through each of the channels and rubber brackets.
    • Stick the antenna cables down onto the new Hinge.
    • Route the antenna cables through the hinge area, with the white and black cables sitting flat against the bottom of the Bottom Cover as much as possible. Avoid letting the cables twist or overlap, as this will interfere with the Input Cover and power button. You can use the spudger end of the Framework Screwdriver to help push the cables.
    • Route the antenna cables through each of the channels and rubber brackets.
  9. There are four alignment pins located on the Top Cover.  They are located right next to the four fastener slots.  Place the silver brackets connected to Display directly over the pins. Be sure to only handle the Display by the side edges and avoid touching the bottom area.
    • There are four alignment pins located on the Top Cover. They are located right next to the four fastener slots. Place the silver brackets connected to Display directly over the pins.
  10. Using the T5 bit in the Framework Screwdriver screw the four fasteners into place. Be sure to not over tighten the fasteners.
    • Using the T5 bit in the Framework Screwdriver screw the four fasteners into place.
    • Be sure to not over tighten the fasteners.
  11. Route the black Display Cable through the routing channel as indicated in the picture. Secure the silver grounding tape as indicated in the first image.
    • Route the black Display Cable through the routing channel as indicated in the picture.
    • Secure the silver grounding tape as indicated in the first image.
    • Using the black pull tab, align the Display Cable connector with the connection on the Mainboard and firmly press down.
    • The Display installation is now complete.
  12. Open the Framework Laptop 180 degrees to attach the Bezel.  Make sure the fasteners in the top left and right corners of the Bottom Cover aren't interfering with the opening. Align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place.
    • Open the Framework Laptop 180 degrees to attach the Bezel. Make sure the fasteners in the top left and right corners of the Bottom Cover aren't interfering with the opening.
    • Align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place.
    • Make sure that all of the corners and edges of the Bezel are fully connected to the Top Cover. If the corners are not aligned. carefully lift up the part of the bezel and guide it into place.
  13. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  14. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  15. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
34 other people completed this guide.
Nirav Patel
18 Guides authored
238 Guides authored
9 Comments
Like some others, I was also unsure about how the cables route around the right hinge.
You can see it more clearly in the "Remove the Bezel" video which is present on other guides, but for some reason this one has that as just a still image.
Display Replacement Guide > "Remove the Bezel"
Attached is a screenshot from there.
Yegor Kuznetsov - Open Reply
Cracked my screen, presumably when pulling away the bezel adhesive as it deformed quite a bit. This Laptop is costing me way too much money, I will never recommend the Framework laptop to others again -.-
Oskar - Open Reply
This hinge replacement guide is incredibly detailed and easy to follow. It's exactly what I needed to fix my laptop—thanks for the clear instructions.
Shiv Teckchandani - Resolved on Release Reply
This hinge replacement guide is incredibly helpful and straightforward. It's great to have a resource that makes such a complex repair process feel manageable—thank you for this!
Bajrang Waghmare - Resolved on Release Reply
I need some better pictures of how the cables route around the right hinge. I cant get teh screen bezzle to completely click all the way down. The wires are somehow stacked wrong or routed the wrong way.
mikkowus - Resolved on Release Reply
Past 30 Days: 1
All Time: 10,629
