Asset Update
by Iroh
You can also follow this guide if you want to re-paste (apply new thermal paste) your Framework Laptop. However, we don’t necessarily recommend doing that unless needed, since this operation requires exposing and handling the bare CPU die, which is somewhat delicate.
Make sure to follow the steps in this guide carefully, including unscrewing and rescrewing the fasteners in the right order on the heatsink and fan.
  2. Warning: Make sure the Framework Laptop has been powered off for at least 5 minutes prior to Heat Sink and Fan removal. This component can be extremely hot. Using the Framework T5 bit in the Framework Screwdriver, unscrew the two fasteners on the Fan first.
    • Warning: Make sure the Framework Laptop has been powered off for at least 5 minutes prior to Heat Sink and Fan removal. This component can be extremely hot.
    • Using the Framework T5 bit in the Framework Screwdriver, unscrew the two fasteners on the Fan first.
  3. Next, unscrew the fasteners labeled 3, then 2, then 1 (in this order). The screws will come loose after a few revolutions, they will remain captive (attached) in the fan.
    • Next, unscrew the fasteners labeled 3, then 2, then 1 (in this order).
    • The screws will come loose after a few revolutions, they will remain captive (attached) in the fan.
  4. Gently lift up the Heat Sink and Fan module and move it over slightly so that you can unplug the power cable. The thermal paste may be holding the module in place, you may have to apply a slight rotating motion to break the hold of the grease. Using your fingernail, disconnect the Fan cable from the Mainboard by sliding it straight out. The Heat Sink and Fan component is now fully detached.
    • Gently lift up the Heat Sink and Fan module and move it over slightly so that you can unplug the power cable. The thermal paste may be holding the module in place, you may have to apply a slight rotating motion to break the hold of the grease.
    • Using your fingernail, disconnect the Fan cable from the Mainboard by sliding it straight out.
    • The Heat Sink and Fan component is now fully detached.
  5. Before installing a brand new Heatsink and Fan module, be sure to carefully wipe off the excess thermal paste from the CPU using a clean, lint-free tissue, cloth, or cotton swab.  The new module has new thermal paste on it. Look for any thermal pads that might have remained stuck on the Mainboard.   They are light in color and very soft to the touch.  If you notice any, gently peel them off.
    • Before installing a brand new Heatsink and Fan module, be sure to carefully wipe off the excess thermal paste from the CPU using a clean, lint-free tissue, cloth, or cotton swab. The new module has new thermal paste on it.
    • Look for any thermal pads that might have remained stuck on the Mainboard. They are light in color and very soft to the touch. If you notice any, gently peel them off.
    • Also make sure all of the thermal pads are properly in place in the new Heatsink. If a thermal pad is missing, there is risk of power regulators overheating.
  6. Place the Heatsink and Fan module on the Mainboard aligning it carefully with the processor. The new module comes with thermal paste so there is no need to any additional paste.
    • Place the Heatsink and Fan module on the Mainboard aligning it carefully with the processor.
    • The new module comes with thermal paste so there is no need to any additional paste.
    • Make sure that the white or pink thermal pads stay in the spots they were originally on on the heatsink, and if any stayed stuck to the mainboard from the old heatsink, peel those off to avoid doubling them up.
  7. Check the plug for the Fan, and note that there is a black dot on one side.  The black dot should face upwards away from the Mainboard.   With the black dot facing upwards, plug the cable back into the Mainboard by sliding it straight into the receptacle. Make sure the plug is in the right orientation.  Inserting it upside down can permanently damage the receptacle. Starting with the fastener slot marked 1 on the Heatsink, start screwing the fasteners back into place using the T5 bit in the Framework Screwdriver.  Next fasten number 2, followed by 3.
    • Check the plug for the Fan, and note that there is a black dot on one side. The black dot should face upwards away from the Mainboard. With the black dot facing upwards, plug the cable back into the Mainboard by sliding it straight into the receptacle.
    • Make sure the plug is in the right orientation. Inserting it upside down can permanently damage the receptacle.
    • Starting with the fastener slot marked 1 on the Heatsink, start screwing the fasteners back into place using the T5 bit in the Framework Screwdriver. Next fasten number 2, followed by 3.
    • Be sure to not over tighten the fasteners.
    • Screw the two fasteners on the Fan back into place.
    • The Heatsink and Fan module is now fully installed.
  8. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  9. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  10. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
19 other people completed this guide.
Jehan Suleman
17 Guides authored
8 Members
151 Guides authored
7 Comments
Going to post this for whomever needs this in the future. DO NOT OVER TIGHTEN THE SCREWS. I followed the steps in this guide. Took 5 minutes. All was good and then my laptop started overheating so badly that I had to take the whole thing apart again and re-apply the thermal paste. Turns out I tightened the screws way too much and it pushed out the thermal paste (my guess of course, but it's running fine now). As soon as you feel that the screws don't move anymore, just stop turning. Learned the hard way. Don't repeat my mistake. A word of caution on top of the article for people who don't work on the internals of computers every day would probably do wonders.
JohnD - Open Reply
My laptop had been overheating for a long time, even after I replaced the thermal paste. It had also become quite noisy over the past few months. I finally decided to invest in this new module, and it made a huge difference! The temperature is now much lower, and the fan is significantly quieter, even compared to the original version that came with the laptop.
Senamaud - Resolved on Release Reply
I think I might have screwed up the plug in on the power supply during this step :/ I tried seating it with a normal amount of pressure (just with my finger, guiding it with some thin-tipped tweezers), and it wasn't turning on when I finished up and closed up my laptop. So I then used some more pressure to get it seated normally, but it still didn't turn on. I tried a few more ways of plugging it in and out, making sure the pins are aligned, but no dice.
I even tried putting the old fan assembly back in (it wasn't completely broken, just having noise/efficiency issues), but the old assembly no longer turns on either.
Not sure how to proceed. Trying to troubleshoot how to fix the fan port :/
Daniel Podlovics - Resolved on Release Reply
Were you able to resolve this? I am having the exact same problem
Michael -
Sorry for nitpicking, but is there a reason why the screws for the fans are +, while those of the CPU heat sink are * ?
Given the high likelihood that they both have to be removed at the same time, might as well use the same type of screws ?
It is easy to work on either the fan or the CPU heat sink, then forget to switch the driver head, which can lead to threading, especially when using the + head on the * screws.
Rousslan Dossa - Resolved on Release Reply
Past 24 Hours: 16
Past 7 Days: 116
Past 30 Days: 603
All Time: 17,360
