added pre-built nomenclature for consistency
by Sandy Qualey-Dobson
How exciting, you finally got your hands on a Framework Laptop 13! This guide will walk you through each step from unboxing to powering on your laptop so you can start using it right away. As with all our guides, make sure you read the directions in each step and view the images before starting.
  1. Unbox your Framework Laptop. Hold off on powering it on until you complete the rest of the guide.
    • Unbox your Framework Laptop. Hold off on powering it on until you complete the rest of the guide.
  2. Locate the Framework Screwdriver in the package underneath the Framework Laptop and keep it handy - it's the only tool you'll need replace or upgrade any part of the product!
    • Locate the Framework Screwdriver in the package underneath the Framework Laptop and keep it handy - it's the only tool you'll need replace or upgrade any part of the product!
  3. After unboxing it, assemble the Power Adapter.  Connect the AC cable and the USB-C cable to the Power Adapter body.
    • After unboxing it, assemble the Power Adapter. Connect the AC cable and the USB-C cable to the Power Adapter body.
    • You can plug the USB-C cable in from either end of the cable. Choose whether you want the right angle connector plugged into the adapter or into your laptop.
  4. Insert the Expansion Cards of your choice into any of the empty bays. If you have a Framework Laptop 13 (AMD Ryzen™ 7040 Series) please see this article showing which Expansion Cards are compatible with each port.
    • Insert the Expansion Cards of your choice into any of the empty bays.
    • If you have a Framework Laptop 13 (AMD Ryzen™ 7040 Series) please see this article showing which Expansion Cards are compatible with each port.
    • Slide the Expansion card into the bay, pushing until it clicks.
    • The first few times you insert or remove a card, it'll take a little more force.
    • Connect the USB-C cable from the Power Adapter into the USB-C Expansion Card. Connect the AC Cable to a power source.
    • The Framework Laptop ships in a mode where the battery is disabled until power is first plugged in, so you really do have to plug in power at this step!
  5. Turn the Framework Laptop over and open it.
    • Turn the Framework Laptop over and open it.
    • Power on the laptop by pressing the power button, and get ready to start using your Framework Laptop!
    • The first boot may take a bit longer (10-30 seconds) while the system recalibrates the installed memory.
  6. Follow the on-screen instructions to set up Windows and log in.
    • Follow the on-screen instructions to set up Windows and log in.
    • Once you are set up, make sure to run Windows Update to get the latest security and functionality updates from Microsoft.
    • We also recommend updating to the latest BIOS and Drivers for the Framework Laptop to make sure the system runs optimally.
93 other people completed this guide.
Nirav Patel
18 Guides authored
11 Members
236 Guides authored
12 Comments
Good morning,
Got my laptop, assembled it, got the Windows 11 ISO -> created USB Key. On install, it does not recognise the SSD. Are there any additional drivers I need to add to the USB to allow Windows to install?
Thank you in advance
A.
Aristeidis Koliopoulos - Open Reply
The install image is having issues seting up windows 11, it keeps getting stuck at the donwloading windows update and at 0%
How can I get it to restart without trying to update?
Tim Moore - Open Reply
I received my new laptop but it didn't come with expansion card. What do I need to do to start the laptop?
Alex - Open Reply
How to remove a USB-C expansion card.
Manuel de Francisco Fabre - Resolved on Release Reply
The default card, supporting USB4, 20V/5A charging, and DisplayPort Alt Mode for connecting monitors, all on either side of the notebook.
Does the USB-C together with AMD 7040 Framework Laptop support USB4 Data + 100W + DisplayPort Alt Mode all at once? I would like to connect the laptop to the external monitor, charge it from the monitor, use data devices connected to the monitor, all through the single cable between the monitor and the laptop.
Miroslav Šimko - Resolved on Release Reply
Past 30 Days: 2
All Time: 49,341
