Once you have your Framework Desktop set up following the Quick Start Guide, you’re ready to install your preferred OS. The Framework Desktop is running some very recent hardware, and we’ve worked with the team at Fedora to improve support. Fedora 45 is one of the Linux distributions we recommend, as it has full hardware support with very little setup required, and it offers a great user experience overall.
First, download the latest Fedora release from the Fedora website. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive.
Download balenaEtcher as a tool to create the USB installer from the ISO. balenaEtcher is available for MacOS. Install it.
If upgrading from Fedora 44, we recommend backing up your home directory and doing a clean installation. If you decide you prefer to upgrade from 44, make absolutely sure your 44 installation is fully up to date first. Should you wish to instead, the DNF System Plugin method remains an option.
Launch balenaEtcher. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the Fedora iso that you downloaded. Click on "Select target" and choose your USB drive. Click "Flash" and wait a minute or two for it to complete.
Once the USB drive creation is complete, you can close balenaEtcher and eject the USB drive from your OS.
First, download the latest Fedora release from the Fedora website. This guide will walk through installing Fedora by automatically using an entire disk.
If upgrading from Fedora 44, we recommend backing up the home directory and doing a clean installation. To minimize risk when upgrading from 44, make absolutely sure everything is fully up to date first.
Possible Upgrade Bugs: Additionally, there are some upgrade notes to be aware of. Systems with WINE installed cannot be updated and Systems with <=1 GB /boot partition may see “need more space” error during system update. See links for workarounds. Clean installs will be the easiest path for some.
Download Rufus as a tool to create the USB installer from the ISO. The first item in this list will be a link to install installer for the latest version. Install Rufus using this. Open Rufus, from the Device drop-down, select the USB flash drive stick.
In order to use devices like external hard drives, external solid state drives, or the Framework Storage Expansion Card to create a live USB, List USB Hard Drives must be enabled under Show advanced drive properties.
Use the Select Button next to Boot selection to choose the downloaded Fedora ISO.
Set Partition scheme to GPT to ensure the live USB is properly recognized at boot.
Click Start. A window will pop up to prompt for a choice between dd image mode and ISOHybrid image mode. Select ISOHybrid image mode then OK.
First, download the latest Fedora Workstation release https://fedoraproject.org/workstation/ from the Fedora website. This Guide assumes a simple installation scenario of a fresh install on a blank drive.
Fedora: Media Writer is already installed on Workstation, so just launch it from the app menu.
Other distro, Flatpak installed: Run flatpak install flathub org.fedoraproject.MediaWriter, then launch it from the app menu or with flatpak run org.fedoraproject.MediaWriter.
Other distro, no Flatpak: Install Flatpak and add Flathub per https://flathub.org/setup
Insert an 8 GB+ USB key. Back up its contents first, since this erases the entire drive.
Open Fedora Media Writer, choose Select .iso file, and pick the Fedora Workstation ISO you downloaded.
Select your USB drive from the device list, double-checking the name and size so you don't wipe the wrong disk.
Click Write, enter your password if prompted, wait for it to finish, then click Finish and safely eject the USB.
Fedora works with Secure Boot out of the box. Fedora Live USBs will boot regardless of whether or not it is disabled. Users who intend to dual-boot with Windows should not disable Secure Boot!
If a user has a reason to disable Secure Boot, such as specialized third party devices that require unsigned drivers:
Boot into BIOS by tapping F2 just before the Framework splash screen.
Arrow down to Administer Secure Boot. Press enter.
Arrow down to Enforce Secure Boot. Press enter, select Disabled, and press enter.
Press F10 to save and reboot. With Yes selected, press Enter.
To enable Secure Boot again, repeat the above steps but select Enable this time.
Boot to Fedora Live USB: Insert the USB drive into the powered-off machine, then power it on.
If an OS is already installed, immediately begin tapping F12 as soon as the power light comes on. Start tapping before the Framework logo appears.
At the Boot Option Menu, use arrow keys to select your USB drive (shown as "EFI USB Device (USB Disk)" or similar) and press Enter. On the black GRUB menu, confirm "Try or Install Ubuntu" is highlighted and press Enter.
If Windows is currently installed, trying to boot a Linux Live USB can result in the "Device is Active" error. This will provide guidance to overcome this error.
Next select Start Fedora Workstation-Live. Hit the enter key.
The installer will start automatically after some time. How long depends on the speed of the USB drive.
Select the keyboard language you'd like to use. On the next screen, click on the Installation Destination button to choose the disk.
If there is an OS already installed on the target drive, you'll need to follow the guided steps in the installer to resize partitions or delete the existing partitions. This is out of scope of this guide, but Fedora has very detailed documentation: https://docs.fedoraproject.org/en-US/qui...
Click Finish Installation and then reboot into your new Fedora install!
The installer will close the window, but not reboot. You can click on the power icon in the top right, click Power Off / Log Out, and click Restart.
This begins the process of completing the initial setup of your Fedora installation.
Connect to Wi-Fi or Skip. If you wish not to connect to wireless just yet, you can skip this and return to connecting to Wi-Fi later on.
Choose your Privacy settings. Here you can decide if you would like to allow Location Services using Mozilla Location Service or not.
Click on Enable Third-Party Repositories. Unless you have a specific reason for not doing so, it's recommended that these repositories are enabled for access to additional drivers and applications.
Set up your user password.
We're almost done. Please follow the links to your Framework Desktop.
Click here for the completion guide for Framework Desktop.
How to check the BIOS version. Go to and click upper left corner where you see the horizontal line, search terminal and launch it. Please follow this link to copy and paste the code into your terminal, then press enter. The output will tell you which Framework Desktop you have and also which BIOS version you're using.
The output will tell you which Framework Desktop BIOS version you're using.
Framework Desktop firmware update link.
IMPORTANT: Per the instructions above, we do NOT recommend updating BIOS and firmware using various GUIs. We recommend using fwupdmgr as provided in the step above. Using GUIs can potentially create issues that would not be present using fwupdmgr directly.
Need help? Please visit our troubleshooting guide first.
If you need additional help, feel free to visit our active support community.
Enjoy using Fedora on your Framework Desktop!
