Fedora 43 Framework Desktop 4.0
by Matt Hartley
Once you have your Framework Desktop set up following the Quick Start Guide, you’re ready to install your preferred OS. The Framework Desktop is running some very recent hardware, and we’ve worked with the team at Fedora to improve support. Fedora 43 is one of the Linux distributions we recommend, as it has full hardware support with very little setup required, and it offers a great user experience overall.
Tools
No tools specified.
    • If upgrading from Fedora 42, we recommend backing up your home directory and doing a clean installation. If you decide you prefer to upgrade from 42, make absolutely sure your 42 installation is fully up to date first. Should you wish to instead, the DNF System Plugin method remains an option.
    • Current Upgrade Bugs: Additionally, there are some upgrade notes to be aware of. Systems with WINE installed cannot be updated and Systems with <=1 GB /boot partition may see “need more space” error during system update. See links for workarounds.
  2. First, download the latest Fedora release from the Fedora website. This guide will walk through installing Fedora by automatically using an entire disk. Download Rufus as a tool to create the USB installer from the ISO. The first item in this list will be a link to install installer for the latest version. Install Rufus using this. Open Rufus, from the Device drop-down, select the USB flash drive stick.
    • First, download the latest Fedora release from the Fedora website. This guide will walk through installing Fedora by automatically using an entire disk.
    • Download Rufus as a tool to create the USB installer from the ISO. The first item in this list will be a link to install installer for the latest version. Install Rufus using this. Open Rufus, from the Device drop-down, select the USB flash drive stick.
    • Current Upgrade Bugs: Additionally, there are some upgrade notes to be aware of. Systems with WINE installed cannot be updated and Systems with <=1 GB /boot partition may see “need more space” error during system update. See links for workarounds. Clean installs will be the easiest path for some.
    • Launch Rufus. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the Fedora iso that you downloaded. Click on "SELECT" and choose your USB drive. Click "START" and wait a minute or two for it to complete.
  3. Fedora works with Secure Boot out of the box. Fedora Live USBs will boot regardless of whether or not it is disabled. Users who intend to dual-boot with Windows should not disable Secure Boot! If a user has a reason to disable Secure Boot, such as specialized third party devices that require unsigned drivers: Boot into BIOS by tapping F2 just before the Framework splash screen.
    • Fedora works with Secure Boot out of the box. Fedora Live USBs will boot regardless of whether or not it is disabled. Users who intend to dual-boot with Windows should not disable Secure Boot!
  4. Boot to Fedora Live USB: Insert the USB drive into the powered-off machine, then power it on.
    • Boot to Fedora Live USB: Insert the USB drive into the powered-off machine, then power it on.
    • If Windows is currently installed, trying to boot a Linux Live USB can result in the "Device is Active" error. This will provide guidance to overcome this error.
    • Next select Start Fedora Workstation-Live 43. Hit the enter key.
    • The installer will start automatically after some time. How long depends on the speed of the USB drive.
  5. Select the keyboard language you'd like to use.  On the next screen, click on the Installation Destination button to choose the disk.  Note that you can install Fedora onto a USB drive or a Storage Expansion Card as an alternative to installing it onto your internal drive. If there is an OS already installed on the target drive, you'll need to follow the guided steps in the installer to resize partitions or delete the existing partitions.  This is out of scope of this guide, but Fedora has very detailed documentation: https://docs.fedoraproject.org/en-US/qui... Important for non-US keyboard users! Please open this link in a new tab and read carefully.
  6. Click on preferred language, again for your preferred keyboard. This begins the process of completing the initial setup of your Fedora installation. Connect to Wi-Fi or Skip. If you wish not to connect to wireless just yet, you can skip this and return to connecting to Wi-Fi later on. Choose your Privacy settings. Here you can decide if you would like to allow Location Services using Mozilla Location Service or not.
    • We're almost done. Please follow the links to your Framework Desktop.
    • Click here for the completion guide for Framework Desktop.
    • How to check the BIOS version. Go to and click upper left corner where you see the horizontal line, search terminal and launch it. Please follow this link to copy and paste the code into your terminal, then press enter. The output will tell you which Framework Desktop you have and also which BIOS version you're using.
    • The output will tell you which Framework Desktop BIOS version you're using.
    • Framework Desktop firmware update link.
Enjoy using Fedora on your Framework Desktop!
Matt Hartley
51 Guides authored
238 Guides authored
Past 30 Days: 1
All Time: 2,209
