Fedora 42 Framework Laptop 16 v5.3
by Matt Hartley
Once you have your Framework Laptop 16 set up following the Quick Start Guide, you’re ready to install your preferred OS. The Framework Laptop 16 is running some very recent hardware, and we’ve worked with the team at Fedora to improve support. Fedora 42 is one of the Linux distributions we recommend, as it has full hardware support with very little setup required, and it offers a great user experience overall.
Tools
No tools specified.
    • If upgrading from Fedora 41, we recommend backing up your home directory and doing a clean installation. If you decide you prefer to upgrade from 41, make absolutely sure your 41 installation is fully up to date first. Should you wish to instead, the DNF System Plugin method remains an option.
  2. First, download the latest Fedora release from the Fedora website. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive. New line.Download Rufus as a tool to create the USB installer from the ISO - select the top download option from the link provided. Rufus is available for Windows. Install it.
    • New line.Download Rufus as a tool to create the USB installer from the ISO - select the top download option from the link provided. Rufus is available for Windows. Install it.
    • Launch Rufus. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the Fedora iso that you downloaded. Click on "SELECT" and choose your USB drive. Click "START" and wait a minute or two for it to complete.
  3. Before we begin the installation process with the Live USB, let's make sure you have your Linux Audio Compatibility set to Linux in the BIOS. Explanation as to what this does can be found here. Power on the laptop, repeatedly tapping F2 in order to get into the BIOS. Note: If you're having trouble with this, try again, holding down the Fn key while rapidly tapping F2.
    • Before we begin the installation process with the Live USB, let's make sure you have your Linux Audio Compatibility set to Linux in the BIOS. Explanation as to what this does can be found here.
    • The next step is to install Fedora 42 at Step 4.
  4. Secure Boot is optional: Enabling secure boot is completely optional and not necessary for normal operation, it's a personal choice - but there are trade offs to be aware of. Follow this link if you wish to enable it before installing Fedora. More about secure boot here. If you have decided to disable secure boot. You will do so by booting into the BIOS menu: Power on, then tap F2 rapidly at the Framework splash screen
    • Secure Boot is optional: Enabling secure boot is completely optional and not necessary for normal operation, it's a personal choice - but there are trade offs to be aware of. Follow this link if you wish to enable it before installing Fedora. More about secure boot here.
  5. Once you have reviewed the previous step, continue
    • Insert the USB drive into your powered off Framework Laptop 16, and then power on. If you have an existing OS installed on the Storage drive in your laptop, immediately after the power light comes on begin rapidly tapping (continuously ) the F12 key - you must begin tapping well before you see the Framework logo.
    • Select the USB drive. Press the enter key.
    • Next select Start Fedora Workstation-Live 42. Hit the enter key.
    • After a few seconds, you're in! If you just want to try Fedora out, you can click on the Try Fedora button and browse through the live USB version of it without touching the internal storage drive. If you do want to install Fedora to the internal storage drive, go on to the next step.
  6. Select the keyboard language you'd like to use.  On the next screen, click on the Installation Destination button to choose the disk.  Note that you can install Fedora onto a USB drive or a Storage Expansion Card as an alternative to installing it onto your internal drive. If there is an OS already installed on the target drive, you'll need to follow the guided steps in the installer to resize partitions or delete the existing partitions.  This is out of scope of this guide, but Fedora has very detailed documentation: https://docs.fedoraproject.org/en-US/qui... Important for non-US keyboard users! Please open this link in a new tab and read carefully.
  7. Click on preferred language, again for your preferred keyboard. This begins the process of completing the initial setup of your Fedora installation. Connect to Wi-Fi or Skip. If you wish not to connect to wireless just yet, you can skip this and return to connecting to Wi-Fi later on. Choose your Privacy settings. Here you can decide if you would like to allow Location Services using Mozilla Location Service or not.
  8. To configure the touchpad to meet your needs:
  9. Let's setup fingerprint login. Click on Activities, search for user. Choose Fingerprint Login. Then select Scan new fingerprint. Select your desired fingerprint. Carefully tap your finger tip on the sensor (power button). You may need to try a few attempts as everyone's prints are different.
    • Let's setup fingerprint login. Click on Activities, search for user.
  10. Your Framework Laptop 16 with the NVIDIA dGPU module can operate in two primary graphics modes you will want to explore. You can switch between them in your laptop's BIOS settings.
    • Your Framework Laptop 16 with the NVIDIA dGPU module can operate in two primary graphics modes you will want to explore. You can switch between them in your laptop's BIOS settings.
    • To access this section of your BIOS: Tap F2 when you boot and see your Framework Splash screen (Framework logo). Arrow over to Setup utility. Click enter. Down arrow to Advanced on the left side. Right arrow to NVIDIA Mux. Enter key. Make your selection, press enter. Press F10 and press enter again to save changes and reboot.
    • The third option, Advanced Optimus, behaves like NVIDIA Hybrid Mode on Linux. So we will forgo it for this guide.
    • NVIDIA Hybrid Mode (Traditional Optimus): This is the default and most battery-efficient mode.
    • Power Behavior: The iGPU remains on at all times. The dGPU powers up only when needed and typically idles around 4–6 W (P8 power state). This is the most battery-efficient configuration.
  11. Your Framework Laptop 16 with the NVIDIA dGPU module can operate in two primary graphics modes you will want to explore. You can switch between them in your laptop's BIOS settings.
    • Display Path The dGPU drives the panel 100% of the time. The iGPU is fully disabled.
    • Power Behavior Highest power draw. The dGPU cannot power down and battery life is significantly shorter, even at idle.
  12. GPUMode is designed to provided extended functionality to EnvyControl, thus allowing GUI controls to manage GPU switching modes.
    • GPUMode is designed to provided extended functionality to EnvyControl, thus allowing GUI controls to manage GPU switching modes.
    • Download EnvyControl by following the COPR steps provided here. You only need steps 1 and 2 for the Fedora COPR section.
    • Install Extension Manager: Software Center, Search gnome extension manager Install it. Open Extension Manager from your applications: Search for "AppIndicator and KStatusNotifierItem Support" Install and enable the extension Log out and log back in. Need help or a better formatted flow how this works? Click here.
    • Download GPUMode for Fedora by downloading the RPM package here.
    • Install GPUMode by double clicking on the downloaded RPM package, then choose install. Once installed, close the Software Store. Reboot.
    • After rebooting, you will notice a new applet that appears in the upper right. Clicking on it, you will see what is shown in the image in this step. You're currently in hybrid mode.
    • Note: Switching to Integrated or back to Hybrid mode is automatic, but, the reboot needed is manual. You will receive a GNOME notification after 1 to 3 minutes when it's ready for you to reboot.
  13. The MUX settings in BIOS do not have an integrated (iGPU) mode to choose from. So you will almost always leave those BIOS setting as they are, which is set to Hybrid mode. GPUMode the Fedora application, powered by EnvyControl, does happen to have an effective method to switch to the iGPU only and blacklist NVIDIA entirely. This is a useful feature when you are detached from power and wish to maximize your battery life. As indicated here, the idle power draw when in integrated GPU mode is not bad at all. When you detach from power, you will receive a notification suggesting you switch to integrated GPU mode for the best battery life. Even if you choose not to do so, which is fine. Your tuneD power settings were already automatically switched to "power save" as well to give you every ounce of battery life possible.
    • The MUX settings in BIOS do not have an integrated (iGPU) mode to choose from. So you will almost always leave those BIOS setting as they are, which is set to Hybrid mode.
    • GPUMode the Fedora application, powered by EnvyControl, does happen to have an effective method to switch to the iGPU only and blacklist NVIDIA entirely. This is a useful feature when you are detached from power and wish to maximize your battery life. As indicated here, the idle power draw when in integrated GPU mode is not bad at all.
    • When you detach from power, you will receive a notification suggesting you switch to integrated GPU mode for the best battery life. Even if you choose not to do so, which is fine. Your tuneD power settings were already automatically switched to "power save" as well to give you every ounce of battery life possible.
    • Should you decide to take the advice from the notification and switch to integrated GPU mode. Simply use the pull down menu as shown in the image, select integrated GPU.
    • You will receive a GNOME notification the process has started and may take a minute. Do not reboot yet! Wait until you see the notification shown in the third image. Once you see that, reboot. After you rebooted, you will then be in Integrated GPU mode.
    • Wish to not be asked again to switch graphics profiles when disconnecting power from your laptop? Select the pull down menu, uncheck "Power Change Notifications"
  14. When you plug into power, you will receive a notification suggesting you switch to hybrid GPU mode for the improved GPU performance. Even if you choose not to do so, which is fine. Your tuneD power settings were already automatically switched to "performance" as well to give you full access to your other system resources like CPU. Should you decide to take the advice from the notification and switch to hybrid GPU mode. Simply use the pull down menu as shown in the image, select hybrid mode. You will receive a GNOME notification the process has started and may take a minute. Do not reboot yet! Wait until you see the notification shown in the third image. Once you see that, reboot. After you rebooted, you will then be in hybrid mode.
    • When you plug into power, you will receive a notification suggesting you switch to hybrid GPU mode for the improved GPU performance. Even if you choose not to do so, which is fine. Your tuneD power settings were already automatically switched to "performance" as well to give you full access to your other system resources like CPU.
    • Should you decide to take the advice from the notification and switch to hybrid GPU mode. Simply use the pull down menu as shown in the image, select hybrid mode.
    • You will receive a GNOME notification the process has started and may take a minute. Do not reboot yet! Wait until you see the notification shown in the third image. Once you see that, reboot. After you rebooted, you will then be in hybrid mode.
  15. To switch into NVIDIA only mode, we need to use the MUX settings located in BIOS. As you can see in the first image, it says NVIDIA mode: Use BIOS F2. So we will want to utilize the steps provided in step 12. To access this section of your BIOS: Reboot, at Framework Splash screen, tap F2 when you boot and see your Framework Splash screen (Framework logo). Arrow over to Setup utility.
    • To switch into NVIDIA only mode, we need to use the MUX settings located in BIOS. As you can see in the first image, it says NVIDIA mode: Use BIOS F2. So we will want to utilize the steps provided in step 12.
    • To access this section of your BIOS: Reboot, at Framework Splash screen, tap F2 when you boot and see your Framework Splash screen (Framework logo). Arrow over to Setup utility.
    • Click enter. Down arrow to Advanced on the left side. Right arrow to NVIDIA Mux. Enter key. Make your selection, press enter. Press F10 and press enter again to save changes and reboot.
    • After pressing F10 to save your changes and you are back and logged in again, pull down your GPUMode application menu. Notice how everything is grayed out and it is indicating you're in NVIDIA mode. This is correct. AMD iGPU is completely blocked and you are exclusively using NVIDIA for everything now.
    • To reverse this, and get back to Hybrid mode, simply follow the directions at step 11. Toggle back to hybrid mode, F10 to save.
    • Before updating to the latest firmware, let's make sure we verify which BIOS were running. Please follow this guide.
    • For Framework Laptop 16 AMD Ryzen AI 300 Series, you can check here for the latest firmware.
  16. Framework Laptop (7040 Series): If you are looking to run Steam games, please follow our guide links below.
    • Framework Laptop (7040 Series): If you are looking to run Steam games, please follow our guide links below.
    • Gaming on Steam with Fedora: One NVMe Drive Guide.
    • Gaming on Steam with Fedora: Two NVMe Drives Guide.
    • Framework Laptop (AI 300 Series): If you are looking to run Steam games, please follow our guide links below.
    • Gaming on Steam with Fedora; One or Two NVME Drives Guides.
    • With the proprietary NVIDIA driver installed, Steam games work with the dGPU without any extra work.
    • If you are unsure if something is using the dGPU, install and run nvtop. Look to the GPU section to see which is running during game play. You can alt-tab key to access this from within a game.
Enjoy using Fedora on your Framework Laptop 16!
Matt Hartley
29 Guides authored
194 Guides authored
Past 7 Days: 12
Past 30 Days: 54
All Time: 1,844
