Update images
by Nirav Patel
We ship a screwdriver in the box to let you explore the insides of the Framework Laptop even if you don’t need to upgrade or repair anything. This is a quick guide to walk you through how to do that.
No parts specified.
  2. Every module in the Framework Laptop has a QR code on it that you can scan with your phone to get to support information, guides, and replacement parts!
    • Every module in the Framework Laptop has a QR code on it that you can scan with your phone to get to support information, guides, and replacement parts!
  3. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  4. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  5. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    • Note that your first boot after installing new memory will take a while before the logo comes up on screen as the system does memory training. The more memory you've installed, the longer this could take (on the order of a minute or two with 64GB!)
17 other people completed this guide.
Nirav Patel
18 Guides authored
225 Guides authored
Past 7 Days: 1
Past 30 Days: 3
All Time: 11,505
