Once you have your Framework Laptop 13 Pro set up following the Quick Start Guide, you’re ready to install your preferred OS. The Framework Laptop 13 is running some very recent hardware, and we’ve worked with the team at Fedora to improve support. CachyOS is one of the many communnity supported Linux distributions we recommend. It offers bleeding edge software enabling full hardware support with very little setup required, and the installer offers options for many popular GUIs.
As mentioned, CachyOS is often on the bleeding edge of software. More frequent updates mean more chances that you may run into bugs. It's extremely important that you report any bugs you run into when you are able. If you would rather have a system that stays in relatively the same place over a long span of time, you can use a more conservative distro like Ubuntu LTS.
Tools
No tools specified.
First, download the latest CachyOS release from the CachyOS website. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive.
Download balenaEtcher as a tool to create the USB installer from the ISO. balenaEtcher is available for MacOS. Install it.
Launch balenaEtcher. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the CachyOS iso that you downloaded. Click on "Select target" and choose your USB drive. Click "Flash" and wait a minute or two for it to complete.
Once the USB drive creation is complete, you can close balenaEtcher and eject the USB drive from your OS.
Download Rufus as a tool to create the USB installer from the ISO - select the top download option from the link provided. Rufus is available for Windows. Install it.
Launch Rufus. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the CachyOS iso that you downloaded. Click on "SELECT" and choose your USB drive. Click "START" and wait a minute or two for it to complete.
To install CachyOS, disabling Secure Boot is needed. This is required for some Linux distributions. Please refer to this link if you want to understand more before moving forward.
To disable secure boot:
Boot into BIOS by tapping F2 just before the Framework splash screen.
Arrow down to Administer Secure Boot. Press enter.
Arrow down to Enforce Secure Boot. Press enter, select Disabled, and press enter.
Press F10 to save and reboot. With Yes selected, press Enter.
Should you wish to enable it later in the future, repeat the above steps but select Enable this time.
Once you have reviewed the previous step, continue
Insert the USB drive into your powered off Framework Laptop 13, and then power on. If you have an existing OS installed on the Storage drive in your laptop, immediately after the power light comes on begin rapidly tapping (continuously ) the F12 key - you must begin tapping well before you see the Framework logo.
Select the USB drive. Press the enter key.
Next select CachyOS from the list (not the LTS version). Hit the enter key.
The speed of the flash drive will determine how quickly the live environment starts. It will boot directly to a KDE desktop in anywhere from a few to many minutes.
In the bottom right corner of the screen, use the WiFi icon in the system tray to connect to a network. The installer will not work without it.
The first thing to open on the live desktop is CachyOS Hello, a greeter window that provides links to a number of useful resources, an option to select language, and a button to open the installer.
Click "Launch installer" in the CachyOS Hello window after connected to the internet. If the window was closed for any reason, it can be reopened using the Application Launcher on the left side of the task bar.
When the installer opens, select a language, region (locale), timezone, and keyboard layout, clicking "Next" to progress through each slide.
Select a bootloader. The installer includes descriptions for each option. The installer defaults to Limine. GRUB is a very mature and well documented option that's also easy to get help with.
The default option is the Limine, this is a newer option intended to work well with the snapshots feature of the default filesystem.
GRUB is a traditional option that may be preferred by long-time Linux users.
Select the drive for install and choose to Wipe the whole drive. A filesystem for the root partition can also be selected.
The default option is btrfs, a filesystem with features like snapshots that allow users to revert the system to a previous state if, for example, an update fails.
Select a desktop environment. Most of them are well described and have visual demonstrations to help selection.
The default option is KDE. This option will be familiar to Windows users. It can be heavily customized to the user's comfort.
Mac users may find Gnome or Cosmic Desktop more familiar or comfortable.
There is an option selection for extra packages. While it isn't recommended to install multiple desktop environments or display managers, it is possible to do so.
This is where support for Printers can be installed
Set up the primary user by filling out the Name, Username, and Password fields with the relevant information.
Unchecking "Use the same password for Administrator account" allows a separate password to be set for the root account.
Review all the details on the Summary slide. This is the last chance to change install options and data is written to the drive.
After review, click Install then Install Now to finalize all selections and begin the install.
CachyOS allows for many different choices of desktop environment or window manager, so this guide will focus on the command line method for enrolling fingerprints.
Install the package
fprintdfor managing fingerprints if it is not already installed. This can be done by opening a terminal and runningsudo pacman -S fprintd. -
With
fprintdinstalled, fingerprints can be enrolled by running the command ``fprintd-enroll` which defaults to enrolling the right index finger. -
Other fingers can be chosen by adding
-fafter thefprintd-enrollcommand. Fingers are named in all lower case with dashes used in place of spaces. For examplefprintd-enroll -f right-middle-finger. -
After running this command tap and lift the finger repeatedly until enrollment is complete.
Further information on the
fprintcan be found on the Arch Wiki. -
If you're experiencing issues getting your fingerprint reader working, please follow our help guide to get your reader working for you on Fedora.
Click here for the completion guide for Framework Laptop 13 Pro.
Configuration of system settings will vary depending on the desktop chosen during install. Desktop environments like Gnome, KDE, and Cosmic tend to be fully featured and include the ability to configure most things in an app called "System Settings" or similar.
Go to and click upper left corner where you see the horizontal line, search terminal and launch it. Please follow this link to copy and paste the code into your terminal, then press enter.
If you have Intel Core Ultra Series 3, you can check (Coming soon) for the latest firmware.
Expecting different touchpad behavior? The touchpad help guide is here.
Need help? Please visit our troubleshooting guide first.
If you need additional help, feel free to visit our active support community.
Enjoy using Fedora on your Framework Laptop 13 Pro!
