Prerequisite guide steps for Bezel - b
by Sandy Qualey-Dobson
The magnetic Framework Bezel is one of the easiest components to swap. No tools needed, just align it to the Display and you are all set. We plan on having more color options as we go so that you can further customize your very own Framework Laptop.
Tools
No tools specified.
    • Open the Framework Laptop 180 degrees to remove the Bezel.
    • The Framework Bezel is attached by magnets so you will not require any tools to remove it. Just use your fingernail and pry the Bezel away from the display from one of the top corners of the Framework Laptop.
    • Once the Bezel starts peeling off towards the bottom of the Display, lift it up using caution. You might feel a little resistance due to the adhesive at the bottom of the display.
    The bottom of the screen is held together by something absolutely indestructible . I found there's a way you need to wiggle and lift, but this instruction is not included in this spec
    Paul M Kovac - Open Reply
    Same as above, in my case three of the four bezel adhesevies were so stuck that they eventually remained on the screen frame. Wiggling or softly using the spludger in order to lift the bottom of the Bezel are two ways of removing it, but mind not to scratch the screen!
    Pascal Belin - Open Reply
    This is NOT true in my last screen replacement process, the bezel adhesive stuck to the display firmly and I used quite amount of wiggling to successfully separate the bezel and the (supposed to be fragile) bottom part of the display. The original display thankfully didn't end up damaged because of it, however, please be careful.
    林博仁(Buo-ren, Lin) - Resolved on Release Reply
  1. If installing a new Bezel, remove the liner pieces on the bottom of the Bezel to expose the adhesive (if present).
    • If installing a new Bezel, remove the liner pieces on the bottom of the Bezel to expose the adhesive (if present).
    Applying the bezel on the display can take multiple tries, especially if you encounter the problem(s) mentioned in the previous and the next section. Just in case you get worried about the glue drying or whatever, I placed and removed the bezel multiple times, as well as letting it sit for a good while with the adhesive covers removed, and nothing bad happened.
    Gelert - Resolved on Release Reply
    It seems almost all of the comments here belong in the next section about actually installing the bezel - only a few of them (if any?) are pertinent to removing the liner pieces to expose the adhesive on the bezel, which is the only action taken here. It's a bit bonkers there's 17 comments before mine in this section about removing liner pieces and only 4 comments at the time of writing in the next section about bezel installation, the latter of which is clearly an order of magnitude more difficult it seems.
    Richard Lloyd - Resolved on Release Reply
    There should be some mention of the removable plastic on the switches at the top of the input cover for (en/dis)abling the camera and microphone.
    David P - Resolved on Release Reply
    My bezel seemed to install well but the lower left hand corner ended up becoming quite stuck and warped for some reason (perhaps how a particular cable was positioned near the microphone).
    It jammed and was almost impossible to open. I have had to detach the lower hinge of the bezel for now and will need a replacement.
    Not the best experience.
    Nicholas - Resolved on Release Reply
    Also had issues with the left corner of the bezel. What happened was I was trying to route the left corner cable below the hinge! That was stupid of me, but it seemed like the appropriate place for the cable to go without much knowledge of laptop bezels. I did fully read and follow the guide, and had the right cable properly fitted; but for some reason it seemed the left cable was supposed to fit under the hinge.
    For anyone who might run into the same problem like I did, here is a picture of how the left cable is supposed to be properly seated:
    https://imgur.com/a/3JcA0xh
    Also, to be fair, the cable was already a bit seated under the hinge when I first opened the laptop, which led me to assume that was how it was supposed to be.
    Ciaran Sanders - Resolved on Release Reply
    the guide says "the ezel" instead of "the bezel" at the end of the 4th bullet point.
    Chickenman - Resolved on Release Reply
    For me this was really simple and took about 30 seconds.
    Richard Tango-Lowy - Resolved on Release Reply
    installed the bezel carefully, or so i thought, when i was finished closed the lid (top cover still off) and the captive screws levered the screen which caused the hinge cover at the bottom of the bezel to just shear off - awesome...i had to re-separate the bezel completely and install from the hinge cover first and then tip the laptop so the captive screws didn't catch in order to check the function again, working now but i've also got half a hinge cover separated from the bezel. Kind of took the shine off my laptop i've been waiting 4 months for
    RJ P - Resolved on Release Reply
    Surprisingly, the bezel was by far the hardest item to install for me. I found that it's easier if done without the top cover, however, be very careful to keep the screws fully seated in when moving the hinge - they can lodge themselves in the wrong spot and cause damage otherwise. This was also pointed out in a comment below, but it should really be a warning at the top of each guide.
    As many have noted, the difficult part is getting the lower corners to sit flush. After a lot of tries the best technique I found is:
    - release tension from the cables by taking them out from some of their holding brackets
    - route them so that, with the laptop sitting flat and horizontal, their highest point is no higher than the hinge's. The picture in the guide shows how to do that - the hinge edges are skinnier than the rest, and you're trying to wrap around that tiny bit of space that they leave.
    Even then it's not perfect and my bottom right corner wants to sit a hair higher than the others.
    Demetrio Girardi - Resolved on Release Reply
    I also had an issue when placing the bottom left of the bezel onto the screen. A cable connecting to the display was causing the the bezel to just not sit flush once it was closed. If you opened it with the cable misaligned it would cause the bottom left side of the bezel to jut out and really look like it would snap. If this guide could provide a picture on how the wiring of the bottom left should look it would be super helpful.
    I managed to figure out how to position it after some troubleshooting, I just removed the bezel and kept closing the lid with the cable in a new spot. When the cable didn't pop out the back I tried it with the bezel installed, then closed the lid, then checked the back of the casing. I still noticed the bezel wasn't flush but after just pushing it up against the case it managed to snap into position and now seems to work fine after opening/closing the lid.
    Vincent Becerra - Resolved on Release Reply
    I had problems with the cable on the left side which caused the lower left corner of the bezel to slightly stick out. You should definitely show a picture of how the left cable should be aligned. Similar to the picture for the Antenna and Camera.
    gbid - Resolved on Release Reply
    If the corners are not aligned. carefully lift up the part of the ezel and guide it into place.
    Can I get a comma and a "b" please... ;)
    Todd - Resolved on Release Reply
    If the new bezel being aligned was not black it would more clearly demonstrate how to attach the new bezel.
    I incurred two problems.
    When installing my new purple bezel, I removed the left adhesive completely from the bottom of the Bezel when removing the liner piece. I was able to REapply it as it was sticky both sides.
    I had more issues with the left hinge, in fact it snapped when I initially closed it. I was terrified but was thankfully able to dislodge it. I bloody well hope this will not effect the performance.
    Very poor quality indeed, cheap flimsy plastic.
    I did not trust myself to continue setting up my Framework Laptop 13 (13th Gen Intel Core) and put it away until I had more confidence.
    Loretta Bozelle - Resolved on Release Reply
    The bezel is cheap plastic and will break easy… if it happens to break it will start to cause issues. Will update with a pic, bezel definitely needs to be redesigned or done already assembled.
    Cameron W Downie - Resolved on Release Reply
    Two captive screws on the bottom of the laptop, near hinges, can mess with opening the screen fully if they are extended too far. Try to push them up (towards the motherboard) to avoid interference. In my case they even left a dent on the inner edge of the screen metal lid.
    https://imgur.com/a/IoeMZeK
    Andrew Bond - Resolved on Release Reply
    On your picture, you already have installed the keyboard, which would be the next step in the process. Do the screws still stick out without the keyboard installed?
    Jonathan Haas -
    Same issue here, it somehow fixed itself after pressing the bezel a bit. It does click when I open the lid, though. I think the wire might need some tape?
    Yochai Gal - Resolved on Release Reply
    I was having issues as well. Check the wires that are tucked in on each side and make sure they are flush with the hinge. There was some tension with the wires and you can use the flat chisel side of the screwdriver tool to gently press the wires down into the chassis grooves.
    Dwalla - Resolved on Release Reply
    The bottom right corner of my bezel is not fully pressed down along the display. It's only 1 or 2 mm raised, but it is noticeable when looking at the display from a side view.
    Do not be alarmed if this happens to you as it seems others have experienced something similar based on posts in the community. I spent way too long repeatedly taking off and placing off the bezel to try and resolve it. All other edges of the bezel lay perfectly.
    Sam Mikell - Resolved on Release Reply
    • Open the Framework Laptop 180 degrees to attach the Bezel.
    • Starting with the bottom of the Bezel which covers the hinges and cables, align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place.
    • We recommend feeling along each edge of the Bezel to make sure it is seated correctly before proceeding, if it doesn't seem to be sitting flush, lift it back up and try lowering it into place again.
    • Do not try to install the Bezel without first opening the Laptop fully, doing so could damage the Bezel and potentially the Display.
    • If the bottom of the Bezel doesn't seem to fit, lift it back off and check that the cables are seated correctly on both sides. If the Bezel doesn't seem to fit at all, please contact support and do not force it into place.
    I also had some issues w/ the bottom left corner of the bezel catching on the display cable, that didn't present any issues until I tightened the screws on the baseplate, but since I opted for the transparent bezel, I could see where the problem was and resolve it. Just make sure the cable is not on top of and to the side of the hinge, like the other side, and that the adhesive on the cable isn't sticking it to the bezel, pulling it up.
    Fair warning though, the transparent bezel is made of much more rigid and less flexible plastic than the normal one, and you will know when it's caught on something.
    Jonathan Divall - Open Reply
    Same issue on mine. Your comment was a big help
    Rick Vidal -
    We had four Laptop 13 Intel 13th Gen and now an AMD AI300 (Batch 4):
    All of them had the glue cable patch on the left hinge not attached, so you really need to check this! Otherwise you will break the bezel (best case), the cable, or the hinge (worst case).
    You have maximum force leverage at this point, so be really careful!
    Yes I wrote this to frame.work, after I was lucky to only break the bezel on our first framework laptop :-S
    Sad to see that this issue is still not fixed on their supply chain.
    Torsten Dörschel - Open Reply
    I join Lima Yankee on this unreported control, because of the cable, at the first opening, it unclipped me 1 good centimeter at the level of the Framework logo.
    ADAM - Open Reply
    Bottom right corner is weird for me. At 180 its ever so slightly not flush, but outside that angle it seems okay. Decided I could live with that (might be related to the issues I had in the previous step). Also had the left bottom corner issue but like other comments said just tuck the cable in.
    Babafunmise - Open Reply
    I also had lots of trouble with the lower left corner, my display cable had popped out of the little guides and kept the bezel from being seated. Really the only tricky part of the whole process!
    Toby Boyd - Open Reply
    The bottom-left of my bezel would not attach fully no matter what I did, and at one point it nearly snapped when trying to open the laptop and the lid would not open more than ~45-70 degrees. What I ended up doing is unfastening the bottom, gently removing the input cover, laying the laptop flat upside down for a while, and then re-opening it. I don't know why, but at this point I was able to remove the bezel (be gentle and do NOT try to force it as it's plastic). The reason my bezel would not sit flush is because the cable was routed incorrectly. It was underneath the hinge rather than above, and it also wasn't slotted into the red rectangle in this image. Make sure your cable is not sitting below or on top of the metal hinge and that it's correctly slotted here: https://imgur.com/a/TmDva6J
    Aleksandr Hovhannisyan - Open Reply
    Also struggling here but with the bottom left corner instead. Photos here. Haven't figured it out yet.
    Sam Burns - Resolved on Release Reply
    Even after dealing with the cable thing, the bezel would give me problems. Very often it would bulge on the center or the right of the bottom side, especially when bringing the display to a 90degree angle. I found that it is kind of flexible, meaning that, with the other corners fit, i gently dragged it like a rubberband towards the last corner, forcing it to stay flat on its sides while snapping. It takes multiple tries and patience, just be very careful not to drag it too hard because I can tell from other people that it breaks fairly easily.
    If the bottom right corner of the bezel won't click into place for you, or pops out of place when you open/close the lid, use the spudger end of your FW screwdriver to lift the webcam cable connecter over the righthand hinge, like this image. Don't worry about damaging the webcam cable, it's flexible, just be gentle.
    Dalton Wood - Resolved on Release Reply
    Just echoing the comments of David P and others below that a diagram and checkpoint on the display cable routing would be helpful here, as the cable routing arriving neat but passing the wrong side of the left hinge (ie on the input side of the hinge instead of the display side) ended up splitting the bezel on trying to close the laptop lid.
    Luke Rule - Resolved on Release Reply
    Second the cable routing check. Ours came with a bit of adhesive sticker on it, we removed and stuck it down behind the hinge.
    Harry Hart - Resolved on Release Reply
    If you have trouble getting the bezel to fit flush all the way around:
    If there's a consistent place the bezel is usually unable to sit flush, try seating that point first and working your way around the rest of the bezel. Be gentle, but don't be afraid to take the bezel off and try again (it took a good number of attempts for mine to seat nicely). Gentle force is okay, but if it's not seating take it off and try again
    Cris E - Resolved on Release Reply
    NOTE regarding clicking while closing:
    if the screws on the underside of the laptop, closest to the hinge, are held captive by the laptop body but dangling loose, when you try to close the laptop you may hear a crunchy click sort of sound as the bottom edge face of the bezel interferes with the screws. For me, picking up the laptop and orienting it so that the screws weren't dangling and sat more flush allowed me to close the laptop without issue, confirming this seemed to be my issue. You may also be able to screw in those screws ever so slightly so they're held more flush with the laptop body before putting the bezel on, but inspect the laptop and make sure you're not causing any problems before attempting, as this is not the recommend order of operations in the guide. You may not want to close the laptop all the way if you do this as the bezel may help to protect the screen
    I think adding a clear picture of how the bottom cables should be dressed, or a diagram, would be helpful. With black cables on a black frame, it's hard to see what is supposed to happen and you can break your bezel easily.
    Scott Thomphson - Resolved on Release Reply
    Before installing the bezel, check the display cable is routed correctly as per this picture.
    Lima Yankee - Resolved on Release Reply
    At the left hinge, the cable seems to belong on the side closer to the display. Mine was on the opposite side, causing the bezel not to fit well, and after closing and reopening the lid, the bezel tore in this corner. It took a lot of wiggling and adjusting to free the bezel and move the cable to its correct position before the lid could be closed and opened easily.
    I feel it's easier to start with the top of the bezel. It's easier to feel the corner with fingers and let the bezel snap into place, than having it taped to bottom first and potentially having misalignment at the top later.
    cyan - Resolved on Release Reply
    "Starting with the bottom of the Bezel which covers the hinges and cables, align the corners of the Bezel to the display and place it down. The Bezel is attached by magnets and should easily click into place."
    But the "bottom of the Bezel which covers the hinges and cables" is the bent/angled, part with the "framework" logo on it, no?
    abc - Resolved on Release Reply
22 other people completed this guide.
Sandy Qualey-Dobson
47 Guides authored
194 Guides authored
7 Comments
I was installing my Bezel for the first time w/ the DIY kit. The magnets snapped on quite easily and It looked like it was secure to my eye, and the 4 second video in this guide matched my experience. However when I closed the laptop and opened it for the first time, the bottom left side caught, breaking the bezel. I'm ordering a replacement, but I'm curious if anyone has another guide/tips for verifying that the Bezel is properly secured before closing and opening so I don't make this same mistake again.
Mikael - Open Reply
So I got my new bezel in and was able to replace it with no issues. The other comment from Fred Eisele was helpful, it turns out the display cable was not in it's channel routing properly. See the link they provided for an image:
Make sure the cable is routed on the proper side of the hinge as shown in Display Replacement Guide
The other thing I did was ensure that the bottom edge of the bezel (along red line) looked straight while the laptop was still open to 180 degrees. Then I folded it to 90 degrees and checked the back side to ensure the bezel was still straight. I had to press it in a bit more here. Then closed and re-opened successfully!
Mikael -
I had some issues with the routing of the cable around the hinges. Could you provide some images of proper routing of the cable?
Fred Eisele - Resolved on Release Reply
Fred Eisele -
This one caused more problems/annoyance for me, than initially expected. It becomes very easy however, after you get the hang of it.
1. The captive screws stick out when the top cover is removed, interfering with opening the display 180 degrees. It's best to open the device 180 degrees, whilst holding it bottom up in the air. This way the captive screws fall inside their holes, and don't interfere with the hinges anymore.
2. My display back-light didn't work, initially. Got it to work by gently pressing the on-screen side display connection, hidden under the bezel. So not the connector on the mother-board, but the other side of the cable where it connects to the screen. I'm a bit wary about this, but will see how long it lasts. So it's best to test if everything works, before installing the bezel!
3. Be careful when opening and closing the lid the first couple of times, the bezel could bend and break at the bottom of the screen if it isn't installed correctly.
TimDV - Resolved on Release Reply
Where did you press exactly, hard to see the connector to the screen.
Jim r33v3s -
This is absurdly simple. Excellent.
Reid - Resolved on Release Reply
Past 24 Hours: 10
Past 7 Days: 59
Past 30 Days: 323
All Time: 20,182
