Arch Linux Framework Desktop v2.0.2
by Jesse Darnley
Once you have your Framework Laptop 12 set up following the Quick Start Guide, you’re ready to install your preferred OS. With the latest release of Arch Linux, everything works pretty smoothly. You can check our Linux page for additional Linux compatibility notes.
No parts specified.
  1. First, download Arch Linux from Arch's website. Arch Linux has a detailed installation guide that you can follow.  We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive. Open the Terminal app. Run the command diskutil list to list the storage devices the system sees. The flash drive should be listed as external.
    • First, download Arch Linux from Arch's website. Arch Linux has a detailed installation guide that you can follow. We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive.
    • Open the Terminal app.
    • Run the command diskutil list to list the storage devices the system sees. The flash drive should be listed as external.
    • Be absolutely certain the command is typed correctly as this can result in loss of data.
    • Use dd to write the downloaded Arch Linux iso to the flash drive: dd if=/path/to/arch-linux.iso of=/dev/diskX bs=8m status=progress
    • Be absolutely certain the paths are correct before running this command with sudo, it will result in loss of data if the wrong disk is chosen.
    • Once the USB drive creation is complete, close the terminal and safely eject the USB drive.
  2. First, download Arch Linux from Arch's website. Arch Linux has a detailed installation guide that you can follow.  We'll go through the steps in this Guide assuming you have a simple installation scenario of a fresh install on a blank drive. New line.Download Rufus as a tool to create the USB installer from the ISO - select the top download option from the link provided. Rufus is available for Windows. Install it.
    • New line.Download Rufus as a tool to create the USB installer from the ISO - select the top download option from the link provided. Rufus is available for Windows. Install it.
    • Launch Rufus. Insert your USB drive (8GB or larger). Click on "Flash from file" and select the Arch Linux iso that you downloaded. Click on "SELECT" and choose your USB drive. Select "GPT" as the Partition scheme. Click "START" and wait a minute or two for it to complete.
  3. Enforce Secure Boot must be Disabled: While Arch Linux can be configured to support Secure Boot, the Live ISO does not ship with a signed bootloader by default.  Information about Secure Boot on Framework Computers can be found here.
    • Enforce Secure Boot must be Disabled: While Arch Linux can be configured to support Secure Boot, the Live ISO does not ship with a signed bootloader by default. Information about Secure Boot on Framework Computers can be found here.
    • Information about implementing Secure Boot with Arch Linux can be found on the Arch Wiki.
    • Insert the USB drive into the powered off Framework Desktop, and then power on. If an existing OS is installed on a Storage drive in the desktop, immediately after the power light comes on begin rapidly tapping (continuously ) the F12 key - begin tapping well before the Framework logo is visible.
    • If there is no internal storage drive installed or it is blank, the desktop will boot to the USB drive directly.
    • Hit Enter again to boot into and install Arch Linux.
    • This is a distribution of Linux that is intended to be built from a relatively minimal state. Refer to the Arch Wiki for more detailed information.
    • To fast track the install process with a text-based user interface, there is a helper library called archinstall designed to speed up the process.
  4. If using an Ethernet Expansion Card, the Live Environment will automatically connect to the internet. If using WiFi, begin by entering iwctl
    • If using an Ethernet Expansion Card, the Live Environment will automatically connect to the internet.
    • If using WiFi, begin by entering iwctl
    • Enter station wlan0 scan then enter station wlan0 get-networks
    • Enter station wlan0 connect "NetworkName" replacing NetworkName with the name of the desired network shown by get-networks, then enter the network password when prompted.
    • Exit iwctl by entering either exit or quit
    • Test the connection to the Arch Linux servers with ping -c3 archlinux.org
    • Sync the system clock with the network by entering timedatectl set-ntp true
  5. List the disks currently recognized by the system and their properties by running fdisk -l This guide assumes the first NVMe drive recognized by the system is being used for installation. This process will wipe the drive being targeted and the loss of all data on it. Run fdisk /dev/nvme0n1
    • List the disks currently recognized by the system and their properties by running fdisk -l
    • This guide assumes the first NVMe drive recognized by the system is being used for installation. This process will wipe the drive being targeted and the loss of all data on it.
    • Run fdisk /dev/nvme0n1
    • Initialize the disk with a new partition table by typing g and pressing enter.
    • Create the boot partition by typing n then pressing enter. Press enter to select the default Partition Number. Press enter again to select the default First Sector. Finally enter +700M as the selection for Last Sector.
    • Enter t to change the Partition Type. Enter 1 then press enter to change the partition type to EFI System.
    • Create the root partition for the system by again typing n and pressing enter. This time press enter 3 times to make the default selections. This will use the rest of the available storage on the targeted drive.
    • Enter w to write the changes to the drive and exit fdisk.
  6. Format the boot partition in FAT32 by running the command: mkfs.fat -F32 /dev/nvme0n1p1
    • Format the boot partition in FAT32 by running the command: mkfs.fat -F32 /dev/nvme0n1p1
    • For the root partition, almost any filesystem can be used, but this guide will use EXT4. Format the root partition in EXT4 by running the command: mkfs.ext4 /dev/nvme0n1p2
    • First mount the root partition using the command: mount /dev/nvme0n1p2 /mnt
    • Now create the folder that the boot partition will mount to with the command: mkdir /mnt/boot
    • Next mount the boot partition to this newly created folder with: mount /dev/nvme0n1p1 /mnt/boot
  7. The first step of installation once the storage is prepared is to install the base system and packages. This is done by running the command: pacstrap /mnt base linux linux-firmware intel-ucode After the previous step completes, the system needs a configuration file that tells it what storage to use in the system and how. This file can be generated automatically by running the command: genfstab -U /mnt >> /mnt/etc/fstab
    • The first step of installation once the storage is prepared is to install the base system and packages. This is done by running the command: pacstrap /mnt base linux linux-firmware intel-ucode
    • After the previous step completes, the system needs a configuration file that tells it what storage to use in the system and how. This file can be generated automatically by running the command: genfstab -U /mnt >> /mnt/etc/fstab
    • At this point the system is prepared for the rest of the install process. This is done from within the freshly installed system without restarting by running the command: arch-chroot /mnt
    • Install a few more essential packages that will be used to complete installation by running the command: pacman -S base-devel networkmanager wireless-regdb vim nano
    For some reason pacstrap gave me an error in this step, saying that /etc/vconsole.conf was not found, and that the "image may not be complete". I copied the vconsole.conf file from /etc/vconsole.conf to /mnt/etc/vconsole.conf and ran the pacstrap command again, and it all succeeded.
    Joshua DeBeer - Open Reply
  8. Folders containing lists of supported options for setting the system's timezone can be listed by running the command: ls /usr/share/zoneinfo/ For the purposes of this guide, the US/Eastern timezone will be used as an example. Set the system's timezone to the United States' Eastern Time by running the command: ln -sf /usr/share/zoneinfo/America/New_York /etc/localtime
    • Folders containing lists of supported options for setting the system's timezone can be listed by running the command: ls /usr/share/zoneinfo/
    • For the purposes of this guide, the US/Eastern timezone will be used as an example. Set the system's timezone to the United States' Eastern Time by running the command: ln -sf /usr/share/zoneinfo/America/New_York /etc/localtime
    • Finally, set the hardware clock of the system by running the command: hwclock --systohc
  9. The file locale.gen needs to be edited in order to set language support. To open the file for editing, run the command: nano /etc/locale.gen Use the arrow keys to scroll down and find the line with the appropriate locale, and remove the # from the start of that line. For example, to set the locale to US English, locate the line that reads #en_US.UTF-8 UTF-8 and change it to en_US.UTF-8 UTF-8
    • The file locale.gen needs to be edited in order to set language support. To open the file for editing, run the command: nano /etc/locale.gen
    • Use the arrow keys to scroll down and find the line with the appropriate locale, and remove the # from the start of that line.
    • For example, to set the locale to US English, locate the line that reads #en_US.UTF-8 UTF-8 and change it to en_US.UTF-8 UTF-8
    • After making edits, press Ctrl+O and Enter to save the changes, then Ctrl+X to exit nano.
    • Now generate the system locale by running the command: locale-gen
    • Finally, create the locale configuration file. This can be done quickly using the command echo LANG=en_US.UTF-8 > /etc/locale.conf
    • To use another language, replace en_US.UTF-8 with the locale of choice as it appears in /etc/locale.gen
  10. Set the hostname of the system. This is the name that the computer is seen as by other devices on the network. The limit for the hostname is 253 ASCII characters. This guide will use "framework" as an example. This can be done in a number of ways, including running the command: echo framework > /etc/hostname Edit the hosts file to include the hostname. This helps to ensure reliable networking. To do this edit, run the command: nano /etc/hosts While in this file, add a line that links your hostname to the localhost address. The line should look something like: 127.0.1.1    framework.localdomain    framework
    • Set the hostname of the system. This is the name that the computer is seen as by other devices on the network. The limit for the hostname is 253 ASCII characters. This guide will use "framework" as an example. This can be done in a number of ways, including running the command: echo framework > /etc/hostname
    • Edit the hosts file to include the hostname. This helps to ensure reliable networking. To do this edit, run the command: nano /etc/hosts
    • While in this file, add a line that links your hostname to the localhost address. The line should look something like: 127.0.1.1 framework.localdomain framework
    • Press Ctrl+X, then Y, then Enter to save the edits and exit nano.
    • Enable NetworkManager by running the command: systemctl enable NetworkManager
  11. Create a new user with administrator privileges by running the command: useradd -m -G wheel,input -s /bin/bash username username can be replaced with any combination of 32 or fewer lower case letters and numbers. Special characters should be avoided. Set a password for this new account by running the command: passwd username
    • Create a new user with administrator privileges by running the command: useradd -m -G wheel,input -s /bin/bash username
    • username can be replaced with any combination of 32 or fewer lower case letters and numbers. Special characters should be avoided.
    • Set a password for this new account by running the command: passwd username
    • Enter the desired password twice when prompted. The password will not be set it both passwords do not match.
    • Set up administrator access for users by installing sudo by running the command: pacman -S sudo
    • Set permissions for sudo by editing the sudoers file. This can be done by running the command: EDITOR=nano visudo
    • Use the arrow keys to scroll down and find the line that reads # %wheel ALL=(ALL:ALL) ALL and alter it to %wheel ALL=(ALL:ALL) ALL before pressing Ctrl+X then Y, then Enter to save and exit.
  12. There are many options for a bootloader in Linux. This guide will focus on bootctl which is included with a base install of Arch Linux. Install the bootloader to the boot partition by running the command: bootctl install
    • There are many options for a bootloader in Linux. This guide will focus on bootctl which is included with a base install of Arch Linux. Install the bootloader to the boot partition by running the command: bootctl install
    • Edit the loader configuration file by running the command: nano /boot/loader/loader.conf
    • The first line of this file is for setting the default boot selection. So it should look like: default arch.conf
    • The second line of this file is for setting the timeout, or how long the bootloader is visible for in seconds. It should look like: timeout 3
    • Press Ctrl+X, then Y, then Enter to save and exit.
  13. Now that the bootloader is installed and configured, the file arch.conf for the default boot entry that was set earlier. This file can be created by running the command: nano /boot/loader/entries/arch.conf The first line of this file is to set the title for the boot entry. This is the text displayed when the bootloader is displayed during early boot. It should look like: title   Arch Linux
    • Now that the bootloader is installed and configured, the file arch.conf for the default boot entry that was set earlier. This file can be created by running the command: nano /boot/loader/entries/arch.conf
    • The first line of this file is to set the title for the boot entry. This is the text displayed when the bootloader is displayed during early boot. It should look like: title Arch Linux
    • The second line of this file is for selecting the Linux image that is loaded by this bootloader entry. It should look like: linux /vmlinuz-linux
    • The next lines of this file are for setting system specific files to be loaded by the Initial RAM Disk that is loaded during boot. There can be multiple lines for initrd. Press Ctrl+X and enter after making the changes to save and close the file.
    • For this example, the first initrd line should be for loading processor specific microcode. The line should look like: initrd /amd-ucode.img
    • The second initrd line in this particular entry file is for loading the Initial RAM Filesystem. It should look like: initrd /initramfs-linux.img
    • The last line is for setting the kernel options. This includes indicating the root filesystem. To add the ID for the root filesystem to the entry file, run the following command: echo 'options\troot=PARTUUID=$(blkid -s PARTUUID -o value /dev/nvme0n1p2) rw' >> /boot/loader/entries/arch.conf
    Also the unary ' should be replaced with double ", otherwise $-part is pasted as-is, without execution (and also for some reason \tis pasted verbatim without turning it into tabulation symbol)
    Mark Ipatov - Open Reply
    The initrd /amd-ucode.img should be initrd /intel-ucode.img for now. The only Framework 12 available is using intel for now.
    Rafael Hurpia da Rocha - Resolve in next release Reply
  14. Swap is absolutely essential to maintaining good performance in a Linux system. Even when there is unused physical RAM, memory is often reallocated for the purposes of optimizing for system responsiveness. ZRAM compresses a section of RAM instead of using system storage for this purpose. Install it by running: pacman -S zram-generator Create a configuration file for ZRAM by running: nano /etc/systemd/zram-generator.conf
    • Swap is absolutely essential to maintaining good performance in a Linux system. Even when there is unused physical RAM, memory is often reallocated for the purposes of optimizing for system responsiveness. ZRAM compresses a section of RAM instead of using system storage for this purpose. Install it by running: pacman -S zram-generator
    • Create a configuration file for ZRAM by running: nano /etc/systemd/zram-generator.conf
    • This configuration file consists of five lines. The first line is the name of the ZRAM device. For this example, the line will be: [zram0]
    • The second line sets the size of the ZRAM device. Typically this should be one quarter to one half of the system's physical memory. For this example, it will be set to half by adding the line: zram-size = ram / 2
    • The third line determines the algorithm used to compress the memory used to make the ZRAM device. On modern systems, zstd is fast and compresses well. Set it by adding the line: compression-algorithm = zstd
    • The fourth line sets swap priority, which determines how often the system will use swap. The default setting is the same as adding the line: swap-priority = 100
    • The fifth and final line is used to set the filesystem type. This should be automatically set correctly, but to be safe add the line: fs-type = swap
    • Press Ctrl+X, then Y, then Enter to save your changes and exit.
  15. To install the Intel graphical drivers run the command: pacman -S mesa vulkan-intel intel-media-driver libva-intel-driver intel-gpu-tools xorg-xrandr To install drivers related to input devices, run the command: pacman -S xf86-input-libinput iio-sensor-proxy
    • To install the Intel graphical drivers run the command: pacman -S mesa vulkan-intel intel-media-driver libva-intel-driver intel-gpu-tools xorg-xrandr
    • To install drivers related to input devices, run the command: pacman -S xf86-input-libinput iio-sensor-proxy
    • To install audio related packages, firmware, and drivers, run the command: pacman -S pipewire pipewire-alsa pipewire-pulse pipewire-jack wireplumber sof-firmware alsa-utils alsa-firmware
    • To install Bluetooth related packages, run the command: pacman -S bluez bluez-utils blueman iwd
    • Enable Bluetooth after installing these packages by running: systemctl enable bluetooth
    • To install power management related packages, run the command: pacman -S tuned tuned-ppd
    • Enable the `tuned` service to enable power management by running: systemctl enable tuned
    • To install webcam and expansion card related packages, run the command pacman -S v4l-utils udisks2 gvfs-mtp gvfs-gphoto2
    Do we need the xorg-xrandr package? In the end, it is recommending people to use Gnome/KDE, and both use Wayland by default.
    Do we need the iwd? It is for wireless, and this tutorial is not showing how to change it (so, even if we install it, we would still be using the default wpa_supplicant
    And about the tuned tuned-ppd, are these good recommendations? In Gnome, the most common is use the power-profiles-daemon, and I don't know about the KDE. But maybe replace these 2 by something more dedicated to the desktop environment?
    Rafael Hurpia da Rocha - Open Reply
  16. Arch Linux has an extremely wide range of graphical interfaces for users to choose from. This guide will focus on installing either Gnome Desktop or KDE.
    • Arch Linux has an extremely wide range of graphical interfaces for users to choose from. This guide will focus on installing either Gnome Desktop or KDE.
    • To install Gnome and its related packages, run the command: pacman -S gnome gnome-tweaks gnome-software firefox
    • When given an option for fonts, selecting 2 for noto-fonts will ensure maximum compatibility across languages.
    • To enable Gnome to start up automatically, run the command: systemctl enable gdm
    • To install KDE and its related packages, run the command: pacman -S plasma kde-applications firefox
    • When given an option for fonts, selecting 2 for noto-fonts will ensure maximum language compatibility.
    • To enable KDE to start up automatically, run the command: systemctl enable sddm
    • Arch Linux is a very barebones system and does not come with some packages included as part of the base system. To add some of these tools to the system, run the command: pacman -S cups git wget btop
    • Cups is the print server for Linux. If this system will not be used with a printer, the cups package can be skipped. If a printer will be used with the system, enable cups after installing it by running the command: systemctl enable cups
    • At this point, the system should have a functional Arch Linux installation on it with either Gnome or KDE as a desktop environment. Exit the chroot environment by running the command: exit
    • Unmount the partitions that were used for installation by running the command: umount -R /mnt
    • Reboot the system and remove the Live USB drive.
    • The Arch Wiki Framework category from the Arch Community.
    • This serves as a place holder. Once additional details on Framework Laptop 12 populate in the wiki, this page will be updated. Information on the Intel-based Framework Laptop 13 may be applicable to the Framework Laptop 12.
    • Before updating to the latest firmware, make sure you verify which BIOS were running.
    • Framework Laptop 12 firmware update link will appear here when it's ready.
Enjoy using Arch on your Framework Laptop 12! If you have any questions or run into any issues, we recommend bringing them to the Community in the Linux Arch topic. Members of the Framework team participate in discussions there.
Matt Hartley
29 Guides authored
194 Guides authored
One Comment
The automatic (?) translation into German also translated some Linux commands, which means they no longer work - e.g. "tuned" -> "abgestimmig".
Ewald Holste - Open Reply
Past 24 Hours: 8
Past 7 Days: 54
Past 30 Days: 225
All Time: 3,997
