Public Release - 1.0
by Iroh
Follow this guide to remove and replace the Wi-Fi module in your Framework Laptop 16.
The Wi-Fi module is a modular card that enables Wi-Fi and Bluetooth functions. While the Framework Laptop 16 works with M.2 2230 Wi-Fi cards, Framework recommends replacing it with the same model of card that the system originally came with.
The Wi-Fi module has delicate antenna connectors. Be sure to follow the instructions carefully to avoid damaging them.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Use your Framework Screwdriver to loosen the captive T5 Torx screw securing Wi-Fi module. The module might pop up at a shallow angle when you loosen the screw.
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing Wi-Fi module.
    • The module might pop up at a shallow angle when you loosen the screw.
  12. Slide the clear plastic cover straight off the module and remove it. Slide the clear plastic cover straight off the module and remove it.
    • Slide the clear plastic cover straight off the module and remove it.
  13. While holding the Wi-Fi module down, insert the flat end of your Framework Screwdriver under one of the coaxial connectors, where the cable meets the metal head. Lift the screwdriver straight up to disconnect the coaxial cable. Repeat for the other coaxial cable.
    • While holding the Wi-Fi module down, insert the flat end of your Framework Screwdriver under one of the coaxial connectors, where the cable meets the metal head.
    • Lift the screwdriver straight up to disconnect the coaxial cable.
    • Repeat for the other coaxial cable.
  14. Grip the end of the Wi-Fi Module with the screw hole and slide it out of its socket. Remove the Wi-Fi Module.
    • Grip the end of the Wi-Fi Module with the screw hole and slide it out of its socket.
    • Remove the Wi-Fi Module.
  15. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  16. Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils. Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
  17. Hold the Wi-Fi module down with your finger. Position the white antenna cable connector over the left Wi-Fi module's coaxial socket. If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
    • Hold the Wi-Fi module down with your finger.
    • Position the white antenna cable connector over the left Wi-Fi module's coaxial socket.
    • If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
    • Repeat the procedure with the black antenna cable.
  18. Slide the clear plastic cover on the module and align its screw with the screw hole cutout. Slide the clear plastic cover on the module and align its screw with the screw hole cutout.
    • Slide the clear plastic cover on the module and align its screw with the screw hole cutout.
  19. Use your Framework Screwdriver to tighten the captive T5 Torx screw securing Wi-Fi module. Use your Framework Screwdriver to tighten the captive T5 Torx screw securing Wi-Fi module.
    • Use your Framework Screwdriver to tighten the captive T5 Torx screw securing Wi-Fi module.
  20. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  21. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  22. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  23. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  24. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  25. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  26. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  27. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
Iroh
112 Guides authored
238 Guides authored
Past 30 Days: 1
All Time: 455
