Public Release - 1.01
by Iroh
Use this guide to remove and replace the ventilation plate in your Framework Laptop 16.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Lift the interposer door by its black pull tab and let it rest upright. Lift the interposer door by its black pull tab and let it rest upright.
    • Lift the interposer door by its black pull tab and let it rest upright.
  12. If you have the Graphics Module installed, your interposer will have four screws. If you have the Expansion Bay Shell installed, you'll have three screws instead. If you have the Graphics Module, use your Framework Screwdriver to loosen the four captive T5 Torx screws securing the interposer.
    • If you have the Graphics Module installed, your interposer will have four screws. If you have the Expansion Bay Shell installed, you'll have three screws instead.
    • If you have the Graphics Module, use your Framework Screwdriver to loosen the four captive T5 Torx screws securing the interposer.
    • If you have the Expansion Bay Shell, use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the interposer.
  13. Lift the interposer by its pull tab and remove it. Lift the interposer by its pull tab and remove it.
    • Lift the interposer by its pull tab and remove it.
  14. Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the module in the Expansion Bay. Close the interposer door before continuing. Close the interposer door before continuing.
    • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the module in the Expansion Bay.
    • Close the interposer door before continuing.
  15. Close your laptop and flip it over. Slide the Expansion Bay Module out of the laptop and remove it. The module should slide out easily. If you feel any resistance, check if the screws holding it in place are fully loosened.
    • Close your laptop and flip it over.
    • Slide the Expansion Bay Module out of the laptop and remove it.
    • The module should slide out easily. If you feel any resistance, check if the screws holding it in place are fully loosened.
    • Reopen your laptop and flip it over.
  16. Use the flat end of a spudger, or a clean fingernail, to lift up the locking tab on the fingerprint sensor ZIF connector next to the memory. Use the flat end of a spudger, or a clean fingernail, to lift up the locking tab on the fingerprint sensor ZIF connector next to the memory.
    • Use the flat end of a spudger, or a clean fingernail, to lift up the locking tab on the fingerprint sensor ZIF connector next to the memory.
  17. Use tweezers, or your fingers, to grip the blue pull tab and slide the fingerprint sensor cable straight out of its socket. Use tweezers, or your fingers, to grip the blue pull tab and slide the fingerprint sensor cable straight out of its socket.
    • Use tweezers, or your fingers, to grip the blue pull tab and slide the fingerprint sensor cable straight out of its socket.
  18. The fingerprint sensor cable is lightly adhered to the laptop's frame. Use your fingers to peel the fingerprint sensor cable away from the frame and separate the adhesive. Use your fingers to peel the fingerprint sensor cable away from the frame and separate the adhesive.
    • The fingerprint sensor cable is lightly adhered to the laptop's frame.
    • Use your fingers to peel the fingerprint sensor cable away from the frame and separate the adhesive.
  19. The ventilation plate is held in place with magnets. Lift the bottom of the ventilation plate and pull it away from the laptop until the magnets release. Remove the ventilation plate.
    • The ventilation plate is held in place with magnets.
    • Lift the bottom of the ventilation plate and pull it away from the laptop until the magnets release.
    • Remove the ventilation plate.
  20. The fingerprint reader cover screws are marked 1–3. You don't need to follow this order, but you can use it to help keep track of the screws you've removed. Use your Framework Screwdriver to remove the three 2.0 mm‑long Phillips screws securing the fingerprint reader cover.
    • The fingerprint reader cover screws are marked 1–3. You don't need to follow this order, but you can use it to help keep track of the screws you've removed.
    • Use your Framework Screwdriver to remove the three 2.0 mm‑long Phillips screws securing the fingerprint reader cover.
  21. Use the flat end of your Framework Screwdriver to lift the fingerprint reader cover and remove it. Use the flat end of your Framework Screwdriver to lift the fingerprint reader cover and remove it. Use the flat end of your Framework Screwdriver to lift the fingerprint reader cover and remove it.
    • Use the flat end of your Framework Screwdriver to lift the fingerprint reader cover and remove it.
  22. Lift the fingerprint reader out of its slot in the ventilation plate and remove it. Lift the fingerprint reader out of its slot in the ventilation plate and remove it. Lift the fingerprint reader out of its slot in the ventilation plate and remove it.
    • Lift the fingerprint reader out of its slot in the ventilation plate and remove it.
  23. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  24. Place the fingerprint reader into its slot in the ventilation plate. Place the fingerprint reader into its slot in the ventilation plate.
    • Place the fingerprint reader into its slot in the ventilation plate.
  25. Place the fingerprint reader cover over the back of the reader. Place the fingerprint reader cover over the back of the reader.
    • Place the fingerprint reader cover over the back of the reader.
  26. Use your Framework Screwdriver to install the three 2.0 mm‑long Phillips screws securing the fingerprint reader cover. Use your Framework Screwdriver to install the three 2.0 mm‑long Phillips screws securing the fingerprint reader cover.
    • Use your Framework Screwdriver to install the three 2.0 mm‑long Phillips screws securing the fingerprint reader cover.
  27. Lay the ventilation plate along the top edge of the laptop and let its magnets pull into place. Lay the ventilation plate along the top edge of the laptop and let its magnets pull into place.
    • Lay the ventilation plate along the top edge of the laptop and let its magnets pull into place.
  28. Use tweezers, or your fingers, to grip the blue pull tab and slide the fingerprint sensor cable straight into its socket. Use tweezers, or your fingers, to grip the blue pull tab and slide the fingerprint sensor cable straight into its socket.
    • Use tweezers, or your fingers, to grip the blue pull tab and slide the fingerprint sensor cable straight into its socket.
  29. Use the flat end of a spudger, or a clean fingernail, to press down the locking tab on the fingerprint sensor ZIF connector. Use the flat end of a spudger, or a clean fingernail, to press down the locking tab on the fingerprint sensor ZIF connector.
    • Use the flat end of a spudger, or a clean fingernail, to press down the locking tab on the fingerprint sensor ZIF connector.
  30. Press the fingerprint sensor cable to the frame to re-adhere it.
    • Press the fingerprint sensor cable to the frame to re-adhere it.
  31. Align the Expansion Bay Module with its slot in the laptop. Check that the module sits evenly with the rail on the outside edges of the slot.
  32. While keeping the module level with the laptop, slide it into its slot. The module should slide in easily. If you feel any resistance, pull the module out and realign it. You should hear an audible "click" when the module's clips snap into place.
    • While keeping the module level with the laptop, slide it into its slot.
    • The module should slide in easily. If you feel any resistance, pull the module out and realign it.
    • You should hear an audible "click" when the module's clips snap into place.
  33. While keeping the shell level with the laptop, slide it into its slot. The shell should slide in easily. If you feel any resistance, pull the module out and realign it. You should hear an audible "click" when the shell's clips snap into place.
    • While keeping the shell level with the laptop, slide it into its slot.
    • The shell should slide in easily. If you feel any resistance, pull the module out and realign it.
    • You should hear an audible "click" when the shell's clips snap into place.
    • This example shows inserting the Expansion Bay Shell.
  34. Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Expansion Bay Module. Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Expansion Bay Module.
    • Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Expansion Bay Module.
  35. Place the interposer over its spot between the Mainboard and the module. Depending on if you're installing a Graphics Module or the Expansion Bay Shell, the interposer should be oriented so either rubber grommets or metal tabs cover the Expansion Bay screws.
    • Place the interposer over its spot between the Mainboard and the module.
    • Depending on if you're installing a Graphics Module or the Expansion Bay Shell, the interposer should be oriented so either rubber grommets or metal tabs cover the Expansion Bay screws.
  36. If you have the Graphics Module installed, your interposer will have four screws. If you have the Expansion Bay Shell installed, you'll have three screws instead. If you have the Graphics Module, use your Framework Screwdriver to tighten the four captive T5 Torx screws securing the interposer. If you have the Expansion Bay Shell, use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the interposer.
    • If you have the Graphics Module, use your Framework Screwdriver to tighten the four captive T5 Torx screws securing the interposer.
    • If you have the Expansion Bay Shell, use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the interposer.
    • Close the interposer door.
  37. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  38. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  39. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  40. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  41. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  42. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  43. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  44. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
Iroh
112 Guides authored
232 Guides authored
Past 30 Days: 2
All Time: 546
