Asset Updates
by Iroh
    • Using the T5 bit in the Framework Screwdriver, unscrew the three fasteners on the battery.
    • Note: The screws will come loose after a few revolutions however they will remain attached to the battery.
    • Use your finger tips to gently lift the battery up and away from the bottom cover. Carefully lift it out and keep it in a safe place.
    • Warning: Handle the battery by the plastic frame, make sure not to bend, scratch, cut, or puncture it, and keep it away from heat sources
Finish Line
Sandy Qualey-Dobson
45 Guides authored
227 Guides authored
Past 7 Days: 1
Past 30 Days: 2
All Time: 101
