Ubuntu 24.04 Framework Laptop 13 Pro v1.02
by Matt Hartley
Once you have your Framework Laptop 13 Pro set up following the Quick Start Guide, you’re ready to install your preferred OS. Ubuntu 24.04 LTS works fantastically well.
NOTE: This is an Officially Supported Linux Distribution. Learn more here.
Tools
No tools specified.
  1. This guide is for the Ubuntu 24.04 Pre-Built model only. For regular Ubuntu guides, please check here.
    • This guide is for the Ubuntu 24.04 Pre-Built model only. For regular Ubuntu guides, please check here.
    • First boot: power on, you will see a fairly fast memory training screen, followed by the Framework splash screen.
    • Looking to disable secure boot? Please go to Step 2. If not, skip Step 2 and go to Step 3 instead.
  2. Secure Boot is optional on Ubuntu: Enabling secure boot is completely optional and not necessary for normal operation, it's a personal choice - but there are trade offs to be aware of. Follow this link if you wish to enable it before installing Fedora. More about secure boot here. You will find Ubuntu specific instructions here. If you have decided to disable secure boot. You will do so by booting into the BIOS menu: Power on, then tap F2 rapidly at the Framework splash screen
    • Secure Boot is optional on Ubuntu: Enabling secure boot is completely optional and not necessary for normal operation, it's a personal choice - but there are trade offs to be aware of. Follow this link if you wish to enable it before installing Fedora. More about secure boot here. You will find Ubuntu specific instructions here.
  3. Once you have reviewed the previous step, continue Power on the laptop, once you are past the Framework Splash screen, select the Restore Ubuntu to factory state option. Once booted into the GUI installation screen as shown, select the Install button.
    • Power on the laptop, once you are past the Framework Splash screen, select the Restore Ubuntu to factory state option.
    • Once booted into the GUI installation screen as shown, select the Install button.
    • Installer runs as normal, shows a slide show as it installs. When it is completed, it will reboot on its own.
    • Next you will be presented with a black screen indicating "We are preparing your system for you" screen. It will reboot on its own when completed.
  4. Once the reboot is completed, Ubuntu will greet you with this welcome screen. Select your appropriate system language. Click next. Now select your typing language. Click next.
    • Once the reboot is completed, Ubuntu will greet you with this welcome screen.
    • Select your appropriate system language. Click next.
    • Now select your typing language. Click next.
    • Now will be asked if you would like to connect to Wi-Fi. Connect.
    • Finally, you will be presented with the "All Done" screen.
  5. The next welcome screen provides you with a link to release notes. Click next. Ubuntu Pro enable screen. If you would like to enroll, please do so from here. If not, click skip. Decide if you want to help improve Ubuntu by sending error reports back to them. Click next.
    • The next welcome screen provides you with a link to release notes. Click next.
    • Ubuntu Pro enable screen. If you would like to enroll, please do so from here. If not, click skip.
    • Decide if you want to help improve Ubuntu by sending error reports back to them. Click next.
    • Finish Screen. Here you may either open the application center or click the Finish button.
  6. Let's setup fingerprint login. Click on the horizontal bar in the upper left, search for user. Choose Fingerprint Login. Then select Scan new fingerprint. Select your desired fingerprint. Carefully tap your finger tip on the sensor (power button). You may need to try a few attempts as everyone's prints are different.
    • Let's setup fingerprint login. Click on the horizontal bar in the upper left, search for user.
    • If you're experiencing issues getting your fingerprint reader working, please follow our help guide to get your reader working for you on Ubuntu.
    • Before updating to the latest firmware, let's make sure we verify which BIOS were running. Please follow this guide.
    • If you have Intel Core Ultra Series 3, you can check (Coming soon) for the latest firmware.
Enjoy using Ubuntu on your Framework Laptop 13 Pro! If you have any questions or run into any issues, we recommend bringing them to the Community in the Ubuntu 24.04 topic. Members of the Framework team participate in discussions there.
Matt Hartley
41 Guides authored
223 Guides authored
Past 30 Days: 0
All Time: 19
