Assets Updated
by Iroh
  2. Using the T5 bit in the Framework Screwdriver, remove the three fasteners on the silver bracket holding the Fingerprint Reader in place. Gently lift the silver bracket off the module and move it away. Gently lift the silver bracket off the module and move it away.
    • Using the T5 bit in the Framework Screwdriver, remove the three fasteners on the silver bracket holding the Fingerprint Reader in place.
    • Gently lift the silver bracket off the module and move it away.
  3. Disconnect the Fingerprint Cable from the Fingerprint Reader.  Flip the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out. Disconnect the Fingerprint Cable from the Fingerprint Reader.  Flip the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out. Disconnect the Fingerprint Cable from the Fingerprint Reader.  Flip the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out.
    • Disconnect the Fingerprint Cable from the Fingerprint Reader. Flip the black latch up using your fingernail or spudger end of the Framework Screwdriver and pull the cable straight out.
  4. Using the PH0 bit in the Framework Screwdriver unscrew the fastener on the Fingerprint Module. Your Framework Screwdriver has a double-sided bit!  One end is the T5 bit, the other end is the PH0 bit. To switch from the T5 bit to the PH0 bit, pull the bit out using your fingers, flip it around, and place it back into the screwdriver! Gently lift the Fingerprint Reader out of the Input Cover.
    • Using the PH0 bit in the Framework Screwdriver unscrew the fastener on the Fingerprint Module.
    • Your Framework Screwdriver has a double-sided bit! One end is the T5 bit, the other end is the PH0 bit. To switch from the T5 bit to the PH0 bit, pull the bit out using your fingers, flip it around, and place it back into the screwdriver!
    • Gently lift the Fingerprint Reader out of the Input Cover.
  5. Find the notch on the end of the Fingerprint Reader Module as indicated in the first image. Find the alignment notch on the Bottom Cover as indicated in the second image. Gently place the module on the Bottom Cover making sure to align the notch in the module with the notch on the Bottom Cover as indicated in the third image.
    • Find the notch on the end of the Fingerprint Reader Module as indicated in the first image.
    • Find the alignment notch on the Bottom Cover as indicated in the second image.
    • Gently place the module on the Bottom Cover making sure to align the notch in the module with the notch on the Bottom Cover as indicated in the third image.
  6. Using the PH0 bit in your Framework Screwdriver, screw the fastener into the Fingerprint Reader. Using the PH0 bit in your Framework Screwdriver, screw the fastener into the Fingerprint Reader.
    • Using the PH0 bit in your Framework Screwdriver, screw the fastener into the Fingerprint Reader.
  7. Make sure the black latch on the connector is flipped up so that you can slide the Fingerprint Cable into the connector. Slide the cable straight in until the white line is almost at the edge of the connector. Flip the black latch down to secure the cable.
    • Make sure the black latch on the connector is flipped up so that you can slide the Fingerprint Cable into the connector.
    • Slide the cable straight in until the white line is almost at the edge of the connector.
    • Flip the black latch down to secure the cable.
  8. Place the silver bracket over the Fingerprint Reader so that the three fastener holes align with the fastener holes on the module. Using the T5 bit in the Frameworks Screwdriver screw the three fasteners into place. The Fingerprint Reader is now completely installed.
    • Place the silver bracket over the Fingerprint Reader so that the three fastener holes align with the fastener holes on the module.
    • Using the T5 bit in the Frameworks Screwdriver screw the three fasteners into place.
    • The Fingerprint Reader is now completely installed.
  9. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  10. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  11. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
  • To purchase a Framework Laptop visit the Framework website.
  • Want to learn more about the Framework Laptop? Take a look at our blog.
  • If you have any questions or concerns, feel free to reach out to Framework Support.
8 other people completed this guide.
Jehan Suleman
17 Guides authored
9 Members
163 Guides authored
2 Comments
What changed with the 2nd release of this module for the 13 inch model?
Caleb Morche - Open Reply
How can I test (from the terminal, in linux (fedora)) that my fingerprint reader is installed and recognized? What is the driver name? Does the presence of lsusb` -> 'Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC' mean that the hardware is installed?
Fred Eisele - Resolved on Release Reply
Past 24 Hours: 8
Past 7 Days: 46
Past 30 Days: 218
All Time: 10,197
