Public Release - 1.0
by Iroh
Follow this guide to replace or upgrade the storage in your Framework Laptop 12.
Your Framework Laptop 12 uses an SSD (Solid State Drive) for storage. The laptop supports M.2 2230 NVMe SSDs.
  • The Input Cover is the part that contains the keyboard and trackpad.
No parts specified.
  3. Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop. Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Flip your laptop over so it's face-up on your work surface.
    • Flip your laptop over so it's face-up on your work surface.
  5. Open the laptop lid so that both the screen and the base lie flat on your work surface. Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Use your fingers to grip the Input Cover in the hinge cutouts. Lift upwards to swing the Input Cover up from the base of the laptop. There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Use your finger to press down on the black SSD latch to unlatch the SSD. The SSD will pop up to an angle when it's unlatched.
    • Use your finger to press down on the black SSD latch to unlatch the SSD.
    • The SSD will pop up to an angle when it's unlatched.
  8. Grab the SSD by its edges and pull it out of its socket. Remove the SSD. Remove the SSD.
    • Grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
  9. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  10. Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils. Align the SSD's gold contacts with its socket.
    • Align the SSD's gold contacts with its socket.
  11. Use your finger to press down on the black SSD latch to keep it open. Use another finger to press the SSD down until it lays flat. If the SSD doesn't fit in the latch, you may need to insert the SSD further into its socket.
    • Use your finger to press down on the black SSD latch to keep it open.
    • Use another finger to press the SSD down until it lays flat.
    • If the SSD doesn't fit in the latch, you may need to insert the SSD further into its socket.
    • Use your finger to close the latch to secure the SSD.
    • You should hear a click, and the SSD should no longer pop up.
  12. Angle the bottom edge of the Input Cover towards the base of the laptop. Align and insert the bottom edge of the Input Cover into the base of the laptop. Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
  13. Close the laptop lid. Flip your laptop face-down on a clean work surface.
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  14. Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop. Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
Iroh
91 Guides authored
194 Guides authored
Past 7 Days: 22
Past 30 Days: 113
All Time: 1,736
