Asset Updates
by Iroh
    • Insert the Expansion Cards of your choice into any of the empty bays.
    • Plug the USB-C power cable into the USB-C Expansion Card.
    • Turn the Framework Laptop over, open it, and press the power button. If you're using Windows, you may need to re-activate Windows after you replace the Mainboard.
    • The first boot will take longer than normal as the system does memory training. The more memory you've installed, the longer this could take (on the order of a minute or two with 64GB!)
Finish Line
Sandy Qualey-Dobson
59 Guides authored
9 Members
163 Guides authored
Past 30 Days: 0
All Time: 18
