Public Release - 1.02
by Iroh
This guide shows how to replace the Speakers in your Framework Laptop 16, make sure not to skip the last step of reinstalling the Framework Driver bundle as this will calibrate the newly installed Speaker Kit.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the battery. Use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the battery.
    • Use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the battery.
  12. Grip the black pull tab at the top of the battery and lift to disconnect the battery connector. Remove the battery. Remove the battery.
    • Grip the black pull tab at the top of the battery and lift to disconnect the battery connector.
    • Remove the battery.
  13. Lift the speaker cable connector by its black pull tab and disconnect it. Lift the speaker cable connector by its black pull tab and disconnect it.
    • Lift the speaker cable connector by its black pull tab and disconnect it.
  14. The speaker cable is routed along the bottom edge of the laptop. The next three steps will demonstrate how to unclip it. Starting at one speaker, use the flat end of a spudger, or your fingers, to lift the speaker cable out of its rubber clips. Starting at one speaker, use the flat end of a spudger, or your fingers, to lift the speaker cable out of its rubber clips.
    • The speaker cable is routed along the bottom edge of the laptop. The next three steps will demonstrate how to unclip it.
    • Starting at one speaker, use the flat end of a spudger, or your fingers, to lift the speaker cable out of its rubber clips.
  15. Slide the speaker cable out from under its screw hole peg in the frame. Slide the speaker cable out from under its screw hole peg in the frame.
    • Slide the speaker cable out from under its screw hole peg in the frame.
  16. Repeat the last two steps across the length of the speaker cable until it's completely unclipped. Repeat the last two steps across the length of the speaker cable until it's completely unclipped.
    • Repeat the last two steps across the length of the speaker cable until it's completely unclipped.
  17. Use your Framework Screwdriver to remove the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total). Use your Framework Screwdriver to remove the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total).
    • Use your Framework Screwdriver to remove the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total).
  18. Lift the speakers off their alignment pegs and remove them. Lift the speakers off their alignment pegs and remove them. Lift the speakers off their alignment pegs and remove them.
  19. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  20. Align the speakers over their alignment pegs and press them down into place. Align the speakers over their alignment pegs and press them down into place. Align the speakers over their alignment pegs and press them down into place.
    • Align the speakers over their alignment pegs and press them down into place.
  21. Be very careful replacing these screws, as it's easy to damage their posts and prevent the screws from fully tightening. Don't overtighten the screws—just tighten them until they're snug. Use your Framework Screwdriver to install the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total).
    • Be very careful replacing these screws, as it's easy to damage their posts and prevent the screws from fully tightening. Don't overtighten the screws—just tighten them until they're snug.
    • Use your Framework Screwdriver to install the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total).
  22. Use the flat end of your Framework Screwdriver to push the speaker cable back into its clips along the bottom edge of the laptop. Use the flat end of your Framework Screwdriver to push the speaker cable back into its clips along the bottom edge of the laptop. Use the flat end of your Framework Screwdriver to push the speaker cable back into its clips along the bottom edge of the laptop.
    • Use the flat end of your Framework Screwdriver to push the speaker cable back into its clips along the bottom edge of the laptop.
  23. Press the speaker cable connector onto its socket to connect it. Press the speaker cable connector onto its socket to connect it.
    • Press the speaker cable connector onto its socket to connect it.
  24. Align the battery connector over its socket and lay the battery into its well. Lightly press the battery down to connect it. Lightly press the battery down to connect it.
    • Align the battery connector over its socket and lay the battery into its well.
    • Lightly press the battery down to connect it.
  25. Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the battery. Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the battery.
    • Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the battery.
  26. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  27. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  28. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  29. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  30. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  31. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  32. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  33. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
    • After installing a new Speaker Kit, you will need to reinstall the Framework Driver Bundle from here.
    • Running the Framework Driver Bundle will properly calibrate the new Speaker Kit in your Framework Laptop 16. We do not recommend skipping this step as one or both of the Speakers may not work without calibration.
3 other people completed this guide.
Sandy Qualey-Dobson
45 Guides authored
238 Guides authored
Past 30 Days: 0
All Time: 1,218
