Public Release - 1.01
by Iroh
Follow this guide to replace the secondary SSD in your Framework Laptop 16.
Your Framework Laptop uses SSDs (Solid State Drive) for storage. The secondary storage supports an M.2 2230 NVMe SSD.
No parts specified.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Use your Framework Screwdriver to remove the 2 mm‑long T5 Torx screw securing the SSD. The SSD might pop up at a shallow angle when you remove the screw.
    • Use your Framework Screwdriver to remove the 2 mm‑long T5 Torx screw securing the SSD.
    • The SSD might pop up at a shallow angle when you remove the screw.
  12. Grip the end of the SSD with the screw hole and slide it out of its socket. Remove the SSD.
    • Grip the end of the SSD with the screw hole and slide it out of its socket.
    • Remove the SSD.
  13. If you have a secondary SSD installed, follow the next two steps. Use your Framework Screwdriver to remove the 2 mm‑long T5 Torx screw securing the secondary SSD.
    • If you have a secondary SSD installed, follow the next two steps.
    • Use your Framework Screwdriver to remove the 2 mm‑long T5 Torx screw securing the secondary SSD.
  14. While pulling up on the black tab underneath the SSD, use your finger to slide the SSD out of its socket. Avoid touching the gold contacts. Only press on the top label or the edges of the SSD. Avoid touching the gold contacts. Only press on the top label or the edges of the SSD.
    • While pulling up on the black tab underneath the SSD, use your finger to slide the SSD out of its socket.
    • Avoid touching the gold contacts. Only press on the top label or the edges of the SSD.
  15. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  16. Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils. Align the SSD's gold contacts with its socket. Insert the SSD partially into the socket at a shallow angle. You should still be able to see most of the gold contacts.
    • Align the SSD's gold contacts with its socket.
    • Insert the SSD partially into the socket at a shallow angle. You should still be able to see most of the gold contacts.
    • Press the SSD flat to the Mainboard.
  17. While keeping the SSD flat to the Mainboard, push it into its socket until its golden contacts are completely covered. While keeping the SSD flat to the Mainboard, push it into its socket until its golden contacts are completely covered.
    • While keeping the SSD flat to the Mainboard, push it into its socket until its golden contacts are completely covered.
  18. Use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD. Use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD.
    • Use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD.
  19. Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils. Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
  20. While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD. While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD. While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD.
    • While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD.
  21. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  22. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  23. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  24. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  25. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  26. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  27. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  28. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
4 other people completed this guide.
Iroh
112 Guides authored
227 Guides authored
Past 30 Days: 5
All Time: 1,972
