Asset Updates - Condensed Steps
by Iroh
    • Locate one of two pieces of black tape and carefully peel it back to reveal the black and red speaker wires.
    • Do not completely remove the tape from the Bottom Cover, peel it back just enough to reveal the wires.
    • Carefully lift the wires out of the wire routers and very gently pull the wires down so that they are free.
    • The speakers are now disconnected. You can lift both the left and right speaker out of the Bottom Cover.
    • Place both the Left and Right speakers in their respective spaces on the Bottom Cover by aligning the pegs with the rubber gaskets.
    • Note: You'll notice an L and R on both speakers to help you figure out the proper placement.
    • Peel the black tape back and place the wires under it. Cover the wires with same tape.
    • Place the wires into the wire router next to the other piece of black tape. Peel the tape back and place the wires under it. Cover the wires with same tape.
    • Route the wires through each of the wire routers. You can use your fingernail to secure the wires in place.
    • Make sure the Speaker is not touching the white or black antenna from the WiFi Module.
Finish Line
Jehan Suleman
17 Guides authored
180 Guides authored
Past 30 Days: 0
All Time: 20
