Asset Updates
by Iroh
    • Using the T5 bit in the Framework Screwdriver, unscrew the 4 fasteners connecting the Display to the Top Cover.
    • The Display is now fully unattached to the Top Cover, you can gently lift it up from the corner using your fingernail.
    • Be sure to only handle the Display by the side edges and avoid touching the bottom area.
Finish Line
Sandy Qualey-Dobson
47 Guides authored
194 Guides authored
Past 30 Days: 0
All Time: 35
