Asset Updates
by Iroh
    • Using two fingers, slide the Speaker cable into the Mainboard using a straight motion and a slight amount of force.
    • Connect the Audio Board cable by gently sliding it into the Mainboard. Make sure the black latch on the connector is flipped up so that you can slide the Audio Board Cable into the connector. Slide the cable straight in until the white line is almost at the edge of the connector
    • Using your finger or the spudger end of the Framework Screwdriver, flip the black latch down towards the Mainboard to lock the cable in place.
    • Once the black latch is secure the Audio Board cable should not come loose.
    • Hold the pull tab on the Webcam cable and connect it into the Mainboard by aligning the pins from the cable with the socket pins on the Mainboard.
Finish Line
Sandy Qualey-Dobson
47 Guides authored
194 Guides authored
Past 30 Days: 0
All Time: 30
