Public Release - 1.0
by Iroh
Follow this guide to replace the secondary storage in your Framework Desktop.
Your Framework Desktop uses SSDs (Solid State Drive) for secondary storage. The Desktop supports M.2 2280 NVMe SSDs in the secondary storage's PCIe 4.0 socket.
For information on SSD compatibility, click here.
No parts specified.
    • Remove the Handle.
    • Remove the Top Panel screw.
  7. Use your fingers to grip the top of the Right Panel and slide it upward to release its clips. Remove the Right Panel. Remove the Right Panel.
    • Remove the Right Panel.
  8. Lay the left side of the Desktop on your work surface so the bottom of the Mainboard is facing upward. Lay the left side of the Desktop on your work surface so the bottom of the Mainboard is facing upward.
    • Lay the left side of the Desktop on your work surface so the bottom of the Mainboard is facing upward.
  9. Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD. The SSD and its heat spreader will pop up to an angle when its screw is fully loosened.
    • Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
    • The SSD and its heat spreader will pop up to an angle when its screw is fully loosened.
  10. While holding the heat spreader upright, grab the SSD by its edges and pull it out of its socket. Remove the SSD.
    • While holding the heat spreader upright, grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
  11. If your SSD comes with a pre-installed heat spreader, follow the next two steps. Otherwise this and the following step. While securing the secondary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it. While securing the secondary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
    • If your SSD comes with a pre-installed heat spreader, follow the next two steps. Otherwise this and the following step.
    • While securing the secondary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
  12. Lift the secondary storage heat spreader out of the Desktop and remove it.
    • Lift the secondary storage heat spreader out of the Desktop and remove it.
    • Follow the guide normally, making sure to ignore instructions that involve the secondary storage heat spreader.
  13. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  14. Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils. While holding the SSD heat spreader upright, align the SSD's gold contacts with its socket. Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • While holding the SSD heat spreader upright, align the SSD's gold contacts with its socket.
    • Lay the heat spreader back onto the SSD.
  15. Use your Framework Desktop Screwdriver to tighten the captive T5 Torx screw securing the SSD.
    • Use your Framework Desktop Screwdriver to tighten the captive T5 Torx screw securing the SSD.
  16. Lift the Desktop so it sits upright on your work surface. Lift the Desktop so it sits upright on your work surface.
    • Lift the Desktop so it sits upright on your work surface.
  17. Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place. There should be a small gap between the bottom of the Right Panel and the silver base. Push the Right Panel towards the base of the computer to engage the clips.
    • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
  18. Orient the Top Panel so its arrow is pointing towards the rear of the computer. While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch. There should be a small gap between the Top Panel and the front of the Desktop.
  19. While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips. While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  20. If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it. Place the Handle over the Top Panel screw holes.
  21. Insert the top panel screw into its hole and twist clockwise until it feels snug. Insert the top panel screw into its hole and twist clockwise until it feels snug. Insert the top panel screw into its hole and twist clockwise until it feels snug.
  22. Repeat the same procedure for the other top panel screw. Repeat the same procedure for the other top panel screw. Repeat the same procedure for the other top panel screw.
  23. Use your finger to close the two D-rings on the top panel screws. Use your finger to close the two D-rings on the top panel screws. Use your finger to close the two D-rings on the top panel screws.
You finished fixing your Framework Desktop!
Iroh
88 Guides authored
194 Guides authored
Past 7 Days: 8
Past 30 Days: 53
All Time: 719
