Initial Release
by Iroh
    • Before beginning, make sure to shut down your Framework Laptop.
    • If the system is still powered on, you will see the chassis intrusion lights flashing red and blue when the Touchpad and Input Modules are removed.
    • In order to remove the Input Modules from the Framework Laptop 16, begin by opening the Input Deck Latches on each side of the Laptop.
    • When the latches are open you can see the red printed on the latch.
    • To remove the Touchpad Spacers, slide them down and then they will lift away easily.
    • If there is resistance, make sure that the Input Deck Latches are open (see previous step).
    • After removing the Spacers, the Touchpad module can be removed in the same way. Gently slide it downwards from both sides and then lift away as shown.
    • To remove the Keyboard lift from the bottom using the pull tabs, and once lifted up the Keyboard module should lift out without resistance.
    • If your pull tabs are no longer attached, you can carefully use the spudger side of the Framework Screwdriver to lift the module away.
    • Remove your Input Modules or Spacers in the same way as the Keyboard, lifting from the bottom using the pull tabs as shown.
    • Remember to power off the system and unplug the USB-C power cable before you open the Interposer Door.
    • You can access the Interposer and change the Expansion Bay Module without removing the Mid Plate.
    • Flip open the Interposer Door using the pull tab provided.
    • Make sure that the door is closed again before closing the Laptop lid to avoid any risk of damage to the display.
    • Loosen the 4 captive fasteners which attach the Interposer for the Graphics Module. 2 of these might be hidden under the pull tab.
    • Once the fasteners are loosened, the Interposer can be lifted out using the pull tab as shown.
    • The Interposer should be easy to remove. If it feels stuck, make sure all 4 fasteners are fully loosened, and do not force it.
    • With the Interposer removed, loosen the 2 captive fasteners holding the Graphics Module in place.
    • With the Interposer installed, close the Interposer Door.
    • With the Framework Laptop 16 closed, turn the Laptop over and gently slide the Graphics Module up from the Expansion Bay slot as shown to remove it.
    • If the Graphics Module seems stuck do not force it. Make sure that the captive fasteners are correctly loosened (see previous steps).
Finish Line
3 other people completed this guide.
Iroh
88 Guides authored
194 Guides authored
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 110
All Time: 2,191
