Public Release - 1.01
by Iroh
Follow this guide to replace or upgrade the primary SSD in your Framework Laptop 16.
Your Framework Laptop uses SSDs (Solid State Drive) for storage. The primary storage supports an M.2 2280 NVMe SSD.
No parts specified.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Use your Framework Screwdriver to remove the 2 mm‑long T5 Torx screw securing the SSD. The SSD might pop up at a shallow angle when you remove the screw.
    • Use your Framework Screwdriver to remove the 2 mm‑long T5 Torx screw securing the SSD.
    • The SSD might pop up at a shallow angle when you remove the screw.
  12. Grip the end of the SSD with the screw hole and slide it out of its socket. Remove the SSD.
    • Grip the end of the SSD with the screw hole and slide it out of its socket.
    • Remove the SSD.
  13. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  14. Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils. Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
  15. While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD. While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD. While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD.
    • While holding the SSD flat to the Mainboard, use your Framework Screwdriver to install the 2 mm‑long T5 Torx screw securing the SSD.
  16. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  17. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  18. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  19. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  20. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  21. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  22. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  23. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
4 other people completed this guide.
Iroh
112 Guides authored
238 Guides authored
Past 30 Days: 4
All Time: 1,602
