Public Release - 1.01
by Iroh
Follow this guide to replace the Mid Plate in your Framework Laptop 16.
    • Remove the keyboard.
    • Remove the Input Module.
    Also here (like in the comment of step 9): ONLY LIFT UP, don't try to remove it.
    RoxJan - Open Reply
    Maybe you should also mention that we are NOT supposed to REMOVE the screws, just make them loose.
    For somebody that did some (albeit crappy) DIY laptop disassembly in the past, that fact is VERY easy to glance over. Usually, when told to loosen the screws, it is somewhat implicitly expected to remove them as well.
    I was wondering why the first screw I tried to remove just wouldn't come off even when loose (some of them do, some of them don't), and I hope that I didn't damage something by attempting to remove the loose screw by force (after rechecking multiple times that it is indeed loose).
    I even had a place prepared to put the screws into... 👀
    Templayer - Open Reply
    There's 16 captive screws to remove to loosen the mid plate. However screw 15 on the right is not highlighted on the image.
    Acre - Open Reply
  11. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  12. If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off. If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off. If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off.
    • If there's a blue liner on the thermal pad located on the bottom of the Mid Plate, use your fingers to peel it off.
    My 16-inch model is much newer (June 2026) and therefore doesn't have the blue foil, but it does have the grey thermal pad. Is that intentional?
    Markus Ursprung - Open Reply
    In my case there wasn't the blue liner and the thermal pad was on the SSD mount, not the mid plate. It's fine to just put it on the middle of the SSD and put the mid plate over.
    Artem - Open Reply
    My 16 is much newer (March 2026) so it doesn't have this thermal pad. I hope this is intentional.
    John - Open Reply
  13. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  14. Use your Framework Screwdriver to tighten the 16 T5 Torx captive screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 T5 Torx captive screws in order (starting with 2) to secure the Mid Plate evenly.
    • Use your Framework Screwdriver to tighten the 16 T5 Torx captive screws in order (starting with 2) to secure the Mid Plate evenly.
    Whoever worked on the graphics for this missed circling screw 15 😅
    ndrwd - Open Reply
  15. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  16. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
    This step is about installing the modules again, but the very first sentence mentions ".. to remove them...". That should say: "... to install them..."
    Thijs Marinussen - Open Reply
  17. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  18. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  19. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  20. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
8 other people completed this guide.
Iroh
108 Guides authored
220 Guides authored
2 Comments
There was no blue liner and it's still saying "input module connector board not connected"
Jim howard - Open Reply
Why is my mouse pad not working please help 😭
Cephas - Resolved on Release Reply
Past 30 Days: 4
All Time: 6,272
