Public Release - 1.0
by Iroh
Use this guide to remove and replace the Mid Plate Cable in the Framework Laptop 16.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Slide the flat end of the Framework Screwdriver under the Mid Plate Cable, near the ZIF connector, to separate the adhesive. Slide the flat end of the Framework Screwdriver under the Mid Plate Cable, near the ZIF connector, to separate the adhesive.
    • Slide the flat end of the Framework Screwdriver under the Mid Plate Cable, near the ZIF connector, to separate the adhesive.
  12. Use the flat end of the Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Mid Plate Cable ZIF connector. Use the flat end of the Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Mid Plate Cable ZIF connector.
    • Use the flat end of the Framework Screwdriver, or a clean fingernail, to lift up the locking tab on the Mid Plate Cable ZIF connector.
  13. Use your fingers to grip the black pull tab and slide the Mid Plate Cable straight out of its socket. Use your fingers to grip the black pull tab and slide the Mid Plate Cable straight out of its socket.
    • Use your fingers to grip the black pull tab and slide the Mid Plate Cable straight out of its socket.
  14. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  15. Use your fingers to grip the black pull tab and slide the Mid Plate Cable straight into its socket. Use your fingers to grip the black pull tab and slide the Mid Plate Cable straight into its socket.
    • Use your fingers to grip the black pull tab and slide the Mid Plate Cable straight into its socket.
  16. Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Mid Plate Cable ZIF connector. Press the cable to the Mid Plate to re-adhere it. Press the cable to the Mid Plate to re-adhere it.
    • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the Mid Plate Cable ZIF connector.
    • Press the cable to the Mid Plate to re-adhere it.
  17. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  18. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  19. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  20. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  21. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  22. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  23. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  24. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
Iroh
112 Guides authored
227 Guides authored
Past 30 Days: 0
All Time: 80
