Step Update - RAM Removal
by Iroh
  2. If there is black shielding over the RAM slots, do NOT remove it. These are necessary to reduce interference with Wi-Fi. Using your fingers, nudge the two metal clips away from one of the Memory modules just enough for the Memory module to pop up. The module will rise up at a 20-degree angle.
    • If there is black shielding over the RAM slots, do NOT remove it. These are necessary to reduce interference with Wi-Fi.
    • Using your fingers, nudge the two metal clips away from one of the Memory modules just enough for the Memory module to pop up.
    • The module will rise up at a 20-degree angle.
    • Gently pull the Memory out of the socket.
    • Repeat this on the second Memory module if you have two installed and want to replace both.
  3. Insert the Memory module into the Mainboard by aligning the notch on the Memory module with the notch on the socket. Once the module is fully inserted, it will rise up at a 20-degree angle. Gently press it down towards the Mainboard until the clips located at the top and bottom of the receptacle snap into place (see the red arrows in the third image).
    • Insert the Memory module into the Mainboard by aligning the notch on the Memory module with the notch on the socket.
    • Once the module is fully inserted, it will rise up at a 20-degree angle. Gently press it down towards the Mainboard until the clips located at the top and bottom of the receptacle snap into place (see the red arrows in the third image).
    • Note: If you are using one Memory module, place it in the right socket that is labelled “Channel 0."
    • Note: The first boot after installing a new Memory module will take longer than normal, as the system prepares itself for the new module.
  4. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  5. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  6. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    • Note that your first boot after installing new memory will take a while before the logo comes up on screen as the system does memory training. The more memory you've installed, the longer this could take (on the order of a minute or two with 64GB!)
22 other people completed this guide.
Jehan Suleman
17 Guides authored
238 Guides authored
9 Comments
@alve On my Laptop 13, the memory module on the right sits right-side up, while the one on the left is upside-down (or flipped over). So if the pins of the right-side memory stick are on the left edge of the stick, then the pins of the left-side memory module need to be on the right side of the stick, AND to be flipped upside-down. Imagine it like pages of a book - for the stick on the left, you start with it oriented like the page/memory stick on the right, and flip it over to the left. HTH!
Michael Cohen - Open Reply
I have 8GB of RAM in my Framework 13 in Channel 0. I want to add another 16GB. Is it fine to add the 16GB RAM into Channel 1, or do I need to switch them and put the bigger one in Channel 0 and the smaller into Channel 1?
Autumn - Open Reply
There are two ram slots for the 13 inch amd laptop.
Can both slots be used for 16GB of DDR5 RAM?
And when you buy 2 sticks of 16GB of ram, are they supposed to be different to fit both?
I have two different ram keys on my 13 inch AMD and for some reason, only one of my DDR5 rams fits. The other doesn't... really strange
chris - Resolved on Release Reply
Good morning,
I'm in the same situation. I checked, my two RAM sticks fit correctly in channel 0. But not in channel 1. I tried by putting it in at a more or less different angle, more or less crooked. I'm still missing a millimeter to be able to put it in place. What did I miss?
alve -
Just to make sure:
Did you rotate the module which appears not to fit 180°, that way "aligning the notch on the Memory module with the notch on the socket."?
The non-symmetric notch separates the pins to prevent inserting the modules the wrong way.
Ralf Martin Lebrecht -
Past 30 Days: 0
All Time: 29,941
