Step Update - RAM Removal
by Iroh
  2. If there is black shielding over the RAM slots, do NOT remove it. These are necessary to reduce interference with Wi-Fi. Using your fingers, nudge the two metal clips away from one of the Memory modules just enough for the Memory module to pop up. The module will rise up at a 20-degree angle.
    • If there is black shielding over the RAM slots, do NOT remove it. These are necessary to reduce interference with Wi-Fi.
    • Using your fingers, nudge the two metal clips away from one of the Memory modules just enough for the Memory module to pop up.
    • The module will rise up at a 20-degree angle.
    • Gently pull the Memory out of the socket.
    • Repeat this on the second Memory module if you have two installed and want to replace both.
  3. Insert the Memory module into the Mainboard by aligning the notch on the Memory module with the notch on the socket. Once the module is fully inserted, it will rise up at a 20-degree angle. Gently press it down towards the Mainboard until the clips located at the top and bottom of the receptacle snap into place (see the red arrows in the third image).
    • Insert the Memory module into the Mainboard by aligning the notch on the Memory module with the notch on the socket.
    • Once the module is fully inserted, it will rise up at a 20-degree angle. Gently press it down towards the Mainboard until the clips located at the top and bottom of the receptacle snap into place (see the red arrows in the third image).
    • Note: If you are using one Memory module, place it in the right socket that is labelled “Channel 0."
    • Note: The first boot after installing a new Memory module will take longer than normal, as the system prepares itself for the new module.
  4. Before closing up the laptop, make sure that the Touchpad end of the Touchpad Cable is fully seated in the receptacle. The cable should be inserted far enough that the white line almost touches the receptacle.
  5. Flip the Input Cover over the Bottom Cover so that the keyboard is facing up and attach it to the Bottom Cover by aligning the top and bottom edges of both covers. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again. Tip: The covers are magnetic and should fit into one another easily. If you feel any resistance simply lift the Input Cover up and try again.
  6. Close the Framework Laptop and turn it upside down to reveal the five fasteners on the Bottom Cover. Using the T5 bit in the Framework Screwdriver, screw all 5 fasteners back into the Bottom Cover.
    • Note that your first boot after installing new memory will take a while before the logo comes up on screen as the system does memory training. The more memory you've installed, the longer this could take (on the order of a minute or two with 64GB!)
21 other people completed this guide.
Jehan Suleman
17 Guides authored
8 Members
151 Guides authored
6 Comments
There are two ram slots for the 13 inch amd laptop.
Can both slots be used for 16GB of DDR5 RAM?
And when you buy 2 sticks of 16GB of ram, are they supposed to be different to fit both?
I have two different ram keys on my 13 inch AMD and for some reason, only one of my DDR5 rams fits. The other doesn't... really strange
chris - Resolved on Release Reply
Just to make sure:
Did you rotate the module which appears not to fit 180°, that way "aligning the notch on the Memory module with the notch on the socket."?
The non-symmetric notch separates the pins to prevent inserting the modules the wrong way.
Ralf Martin Lebrecht -
Okay, this was almost too easy. It also shows that often times you get what you pay for in a very good way. After the first upgrade, to 96GB of PC5-5600 memory, I couldn't be happier with my choice of a Framework13. The whole insides are very first rate. It did take a couple of seconds to find the memory as there is a thin black plastic cover over the sticks that didn't appear in the instruction; however, it is right where it is shown in the instructions.
John Lindsey - Resolved on Release Reply
Please show me how the memory module cover plate is put back on (replaced) on a laptop.
Wendy Daniels - Resolved on Release Reply
What model of laptop are you talking about? The FrameWork doesn’t have a “memory module cover plate” to put back.
Forge -
Past 24 Hours: 17
Past 7 Days: 124
Past 30 Days: 771
All Time: 24,629
