Public Release - 1.0
by Iroh
Follow this guide to reset the Mainboard in your Framework Laptop 16.
Resetting the Mainboard will set the Laptop's BIOS settings to their factory default. This might be necessary if your Laptop doesn't boot properly or if you're installing new hardware.
This procedure is irreversible. Make sure you have your BIOS settings documented if you want to restore them afterwards.
No parts specified.
    • Remove the keyboard.
    • Remove the Input Module.
  11. Plug the laptop into a power source. The red status LED near the right Expansion Card slots should blink continuously. If this LED isn't blinking, the laptop isn't receiving power correctly—try another USB-C port.
    • Plug the laptop into a power source.
    • The red status LED near the right Expansion Card slots should blink continuously. If this LED isn't blinking, the laptop isn't receiving power correctly—try another USB-C port.
    • Don't proceed unless the LED is blinking.
  12. Locate the chassis open switch below the memory. This switch is a sensor that detects if the Mid Plate has been removed. It's a small silver block with a black toggle tab.
    • Locate the chassis open switch below the memory.
    • This switch is a sensor that detects if the Mid Plate has been removed. It's a small silver block with a black toggle tab.
  13. Use your finger or the flat end of a Framework Screwdriver to press the chassis open switch 10 times: Press and hold the switch down for two seconds. Release the switch and wait for the indicator LED to resume blinking.
    • Use your finger or the flat end of a Framework Screwdriver to press the chassis open switch 10 times:
    • Press and hold the switch down for two seconds.
    • Release the switch and wait for the indicator LED to resume blinking.
    • Repeat the process 10 times total.
  14. Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  15. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs. Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  16. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly. Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  17. Align the Mid Plate cable press connector over its socket and press down to connect it. Align the Mid Plate cable press connector over its socket and press down to connect it.
  18. Your Input Module(s) might be different, but the procedure to remove them is the same. Align the top edge of the Input Module with the top edge of the laptop. Lay the Input Module on the laptop and let the magnets pull the keyboard into place
  19. Align the top edge of the keyboard with the top edge of the laptop. Lay the keyboard on the laptop and let the magnets pull the keyboard into place Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  20. Place the Touchpad Module flat on its cutout so its clips are properly aligned. Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  21. Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly. Slide the Touchpad Spacer towards the top of the laptop to secure it. Repeat the same procedure for the other Touchpad Spacer.
  22. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them. Push the Input Module latches back into place to lock them.
Iroh
112 Guides authored
238 Guides authored
Past 30 Days: 0
All Time: 594
