Public Release - 1.0
by Iroh
Follow this guide to reset the Mainboard in your Framework Desktop.
Resetting the Mainboard will set the Desktop's BIOS settings to their factory default. This might be necessary if your Desktop doesn't boot properly or if you're installing new hardware.
This procedure is irreversible. Make sure you have your BIOS settings documented if you want to restore them afterwards.
    • Remove the Handle.
    • Remove the Top Panel screw.
  7. Lay down the Desktop on its right side. Lay down the Desktop on its right side.
    • Lay down the Desktop on its right side.
  8. Press the white button labeled "CMOS RESET" next to the APU Fan connector and hold for 10 seconds. Press the white button labeled "CMOS RESET" next to the APU Fan connector and hold for 10 seconds.
    • Press the white button labeled "CMOS RESET" next to the APU Fan connector and hold for 10 seconds.
  9. Lift the Desktop so it stands upright on your work surface. Lift the Desktop so it stands upright on your work surface.
    • Lift the Desktop so it stands upright on your work surface.
  10. Orient the Top Panel so its arrow is pointing towards the rear of the computer. While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch. There should be a small gap between the Top Panel and the front of the Desktop.
  11. While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips. While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  12. If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it. Place the Handle over the Top Panel screw holes.
  13. Insert the top panel screw into its hole and twist clockwise until it feels snug. Insert the top panel screw into its hole and twist clockwise until it feels snug. Insert the top panel screw into its hole and twist clockwise until it feels snug.
  14. Repeat the same procedure for the other top panel screw. Repeat the same procedure for the other top panel screw. Repeat the same procedure for the other top panel screw.
  15. Use your finger to close the two D-rings on the top panel screws. Use your finger to close the two D-rings on the top panel screws. Use your finger to close the two D-rings on the top panel screws.
  16. Plug the Desktop back in. Turn on your Desktop—it should boot up normally. If your BIOS settings haven't changed, or if you're still experiencing issues, repeat the Mainboard reset procedure.
    • Plug the Desktop back in.
    • Turn on your Desktop—it should boot up normally. If your BIOS settings haven't changed, or if you're still experiencing issues, repeat the Mainboard reset procedure.
Iroh
112 Guides authored
238 Guides authored
Past 30 Days: 0
All Time: 1,268
